Question about Garden
John deere L120 riding mower quit. No spark at the plugs. Replaced with new plugs and engine started so I began mowing. After 10 minutes engine sputtered and quit. Again no spark at the plugs. Why are the spark plugs burning out?
I am wondering what kind of spark plugs do this mower take i cant seem to fine were it said it
Posted on Apr 01, 2014
3 Suggested Answers
  • 61 Answers
SOURCE: pto clutch will not engage
ck fuses, and switch, for 12 volts
Posted on Sep 07, 2009
  • 66 Answers
SOURCE: My John Deer L120 riding mower is shutting down
Two things to consider....fire and fuel. Lets start with the simplest....check and replace the fuel filter, drop bowl off the bottom of carb to make sure float is working properly. If this dosen't work...your looking at a new coil. Some coils will go quickly where others are gradual. As they heat up...they will stop working until allowed to cool down again. www.nnyparts.com
Posted on May 30, 2010
Mower blades stops running
check bearings in the spindles and check belt tensions.
Jun 15, 2013 | John Deere Garden
John Deere L120 runs for 15 minutes, bogs down and dies. A few minutes later starts right up, runs for a few minutes and dies again. I have changed the fuel filter, all fuel lines, air filter, cleaned the...
Is this an older machine ? If so try finding the points its usualy on the front lower part of the engine behind the cover, if you see that then it needs its condensor replaced, lookes like a round battery.
If this is newer or you can also try changing the spark plug sometimes they heat up and fail.
Sep 17, 2012 | John Deere Garden
John deere l120 will crank but not start. Has fuel pressure and spark
check for operation of the solenoid on the bottom of the carb they loose power from bad safety switches they stick closed from bad fuel and sometimes they just go bad
Jun 17, 2012 | John Deere 22HP VTwin 48" Riding Mower
John Deere L120 gets hot and shuts down after mowing for short time
remove the top cover and see if there is a nest or grass build up on top of the fins or are you loosing spark when it gets hot then remove the cover and check the coil
Apr 11, 2012 | John Deere Garden
John Deere LT 133 lawn tractor quits running after about 10 minutes.
Will it restart right away or does it have to cool down? If it has to cool down, then run it until it quits. Next remove the plug, reattach the plug wire, and ground the plug to the block. Finally try to start it with the key. If you get no spark or very weak spark then the ignition coil needs to be replaced.
Let me know how it goes.
Aug 18, 2011 | John Deere Garden
May 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
JD L120 riding mower keeps dying on me
Loosen fuel cap 1 turn to see if it will stay running.Theres a tank breather hole/vent in the cap and when it becomes plugged no air can get into fuel tank when fuel is used,can also be a plugged fuel filter.
Apr 21, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John deere L120 riding mower with IntekV twin 22hp
Try replacing the gas in the fuel system. The manufacturers are telling us that gas over 30 days is considered bad gas.
Good day.
Nov 02, 2009 | John Deere Garden
John Deer riding mower
http://www.deere.com/specsapp/CustomerSpecificationServlet?sbu=CCE&pciModel=L120%20GX&displayModelName=L120%20Lawn%20Tractor&tM=HO&pNbr=SKU20346
Here is a link to John Deere website for this model, it states that it has a 16 amp charging system. It also has the phone numbers listed for contact, and requesting the manuals for this mower.
Sep 18, 2008 | Garden
Garden Logo
264 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
