Question about Kenmore 72055 Air Conditioner
My in wall air conditioner is blowing black specks onto my furniture
My frigidaire Air Conditioner model Lra074at7 is not blowing cool air. Its very hot in the room I have it in. Not sure what to do??
Hello friend, thank you for your inquiry!
I understand that your Frigidaire air conditioner is not blowing cool air. There could be many possibilities to why your appliance is not cooling properly.
· Check to make sure the air vent is not in the open position.
· Make sure there is nothing blocking the airflow of the appliance.
· If your appliance is turned on in a hot room it could take additional time to remove "stored heat" from walls, ceilings, floors, and furniture.
Is your appliance under warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your air conditioner and the procedures to any potential remedy. I hope this is helpful. -Matt
Aug 19, 2014 | Electrolux FRIGIDAIRE LRA074AT7 6500BTU...
It doesn't take the humidity out of the air. It alsocausesdampness in the air and cloth furniture, etc. When I first bought the airconditioner it removed the humiidity and cooled my apartment just fine...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 27, 2011 | Kenmore 76081 Wall/Window Air Conditioner
My frigidaire air conditioners spit dirt all over the floor. My window unit and my through the wall unit in a sleeve both do the same thing. I called Frigidaire two years ago and they told me there were no...
1. Turn units off
2. Remove Filter
3. Spray a foaming cleaner on the coils (Dow Bathroom Cleaner)
4. Use a spray bottle filled with plain water
5. Replace Filter and Grill
May 25, 2011 | Frigidaire FAC124 wall/Window Air...
How do I hide the excess power cord on my Fridgidaire thru-the-wall air conditioner model FAH126S2T
mcdevito75 here, I would use a same color tape as the cord to hide excess cord. Never bury excess cord under a rug or furniture.
Aug 19, 2010 | Heating & Cooling
Pilot lights but won't stay on in my older style vulcan space heater. thermo couple was replaced last year.any ideas that i could try thanks
Most common cause of pilot light problems is air movement. If your space heater exhausts gas through the roof, ensure the cap is on and level. If not, outside air movement will blow out the pilot. If you do not have an exhaust gas duct, check that the unit is positioned so that it does not blow air back onto itself from walls, furniture, etc, and ensure no other devices that move air are aimed towards the unit. The unit also needs to be placed away from central ducting, including return vents.
Hope this helps!
Aug 09, 2010 | Vulcan AUW230A Heater
I have a Desa propane gas fireplace VSGF28PTC/CSGF28PTC S# 8510272 and it puts off so much fumes that it sets off the CO detector and gives use head aks. and dros.
You need to have a technician come out and do a couple of things. First determine if the oriface on the burners is the correct size for the type of gas (Natural or Propane) then he should adjust the gas outlet pressure. Also is this a vented or vent free set up. Good luck and please give me a Fixya rating.
Feb 22, 2009 | Desa International Wall/Window Air...
Kenmore ac blowing black peices all over room.
that is foam insulation around the seal of the evaparator box pull the unit from the wall remove the cover to get to it and clean or replace it
May 10, 2008 | Kenmore 70088 Air Conditioner
Kenmore 73259 wall unit a/c blowing out black particles
remove the filter aand run it and see what happens, the filter still could be causing the issue
Apr 25, 2008 | Kenmore 73259 Air Conditioner
Kenmore 72055 Air Conditioner Logo
470 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
