Question about Lamaqq 56k v.90 SGS External USB Data/Fax Modem (MDMLAM56KUSB)
Need to know how di i install a usb dial up modem- external? It is just called a usb fax modem but has a disk but no instructions for set up. I want to set it up to have a dial up internet connection
  • 206 Answers
Turn on the pc. then put the cd in the drive. now just plug-in the modem the system will detect it and ask for the drivers then say automatic! and it will automatically get installed!
or else
u can go to control panel-> phones and modems-> modems tab and then click add the system will guide u through the installation!!
any further support feel free to reply and do rate me!
Posted on Jul 12, 2010
Fax from computer
First, you will need a USB fax modem. Then you use Windows Fax & Scan program to create/forward new fax documents, or even send a file as a fax or email.
Setting up your external modem to work with an internet telephone line is simple. Simply put a 2 way splitter into the internet modem telephone jack. Plug your telephone into one input and the external fax modem into the other. Then you can even dial from your computer routine telephone calls too.
Need more explanation? Let me know.
Mar 14, 2014 | Brother MFC-7460DN
Can't send or recive Faxes
Try resetting the machine to it's defualt settings.
Jun 18, 2008 | HP Photosmart C6100 All-In-One Printer
NEW Pavilion Slimline & NEW HiRO V.92 56K External USB Data Fax Voice Modem Windows 7 Vista XP 32 64 bit. Installed drivers as per instructions. I can see drivers in device manager & under control...
SOP - Standard Operating Procedure for MS OS's (NT, 2k, 2k3, XP, Vista, Win7) - why load
drivers for devices that are not present. If you want to use the modem,
turn it on before powering up the PC.
Also please post the full version number of your driver. Not all of them are fully 7 compatible.
Jan 12, 2011 | Computers & Internet
Is it possible to setup faxing from the dell dimension 8400 pc desktop
Yes, it is possible if you install a printer/fax software, assuming that you already have a dial-up modem (not DSL modem, an old one for dial-up connections). Note that on Windows XP disk there is one simple fax program available. Is is not installed by default, you need to add it manually after the modem's installation.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 20, 2010 | Dell Dimension 8400 PC Desktop
HP USB Modem does not break dial tone
If the information connected to your post is all correct (56k V90 usb), and you are using one line for both the internet and the fax, you should hang up from the internet before you try to dial out the fax.
You have not indicated your PC model, so I don't know what operating system you are using. For XP and newer versions, you have to set up and configure the fax using the wizard or configuration software. If you have not done that yet, you need to.
In xp, go to start, Programs , Accessories , Communication , Fax , and then click Fax Console.
You said your computer is new. Win 7 and Vista are much the same:
1.Click the Start button , click All Programs, and then click Windows Fax and Scan.
2.At the bottom of the left pane, click Fax, and then click New Fax on the toolbar to launch the Fax Setup wizard.
3.Click Connect to a fax modem and follow the instructions.
You also need to make sure that your fax/modem is correctly listed in the control panel. In XP, start, control panel, printers and devices. If you do not have a fax printer listed, you need to "install a local fax printer."
The installation wizard should work in both OS without much trouble. If you do have difficulty, Microsoft and adobe both have "virtual printers" you can use. Look in Microsoft office or online.
Also check control panel of 7 to make sure that your modem and fax are listed correctly. Thanks for using Fixya.
Jan 01, 2010 | HP (56K V90 USB) Modem
How do I use the fax without going thru my computer just as a fax
Issue: How do I connect a telephone, answering machine or computer modem to my machine?
Solution: Connecting the telephone line and external devices to the MX310
Preparing the Machine for Faxing title-bar.gif Typical examples of connecting the machine are described below. The machine cannot send/receive faxes if the connection is incorrect. Connect the machine correctly.
i_important.gif Important
If the Power Disconnects Unexpectedly
If there is a power failure or if you accidentally disconnect the power cord, the date/time settings as well as all documents stored in memory will be lost. User data and speed dialing settings are retained. If the power disconnects, the following will apply:
bullet_s.gif You will not be able to send or receive faxes or make copies.
bullet_s.gif If a telephone is connected to the machine, you can receive voice calls.
bullet_s.gif Whether you are able to make voice calls depends on the type of your telephone.
sikaku.gif Methods of Connecting External Devices bullet.gif Connecting to an Analog Line t_01522.jpg
(A) Telephone line (analog)
(A) Telephone or Answering machine
Do not connect the machine and external devices in parallel to the same telephone line using a splitter (A) . The machine may not operate properly.
bullet.gif Connecting a Telephone or Answering Machine via a Computer t_01724.jpg
(A) Computer
(B) Telephone or Answering machine
sikaku.gif Methods of Connecting the Various Lines The following are some basic connection schemes that apply when you are connecting to a non-analog telephone line. These are examples and are not guaranteed to suit every connecting conditions. For details, refer to the instruction manual supplied with the network device (control devices such as an xDSL modem, terminal adapter, or dial-up router) you are connecting to this machine.
(A) Digital Subscriber Line
(B) Splitter
(C) xDSL modem (splitter may be built-in to the modem)
(D) Computer
bullet.gif Connecting to an ISDN Line For details on ISDN connection and settings, see the manuals supplied with your terminal adapter or dial-up router.
Please be informed that you can access Canon's online support site for your printer by clicking here. You can find many solutions to your problems by searching their database once you have navigated to the support page for your model.
I hope this information allows you to resolve this issue. If not, reply back with a comment to this thread.
If so, please take just a moment to rate this post. Thanks!
Apr 03, 2009 | Canon PIXMA MX310 All-In-One Printer
How do get a dial tone when using the data fax modem?
try bypassing their modem and see if you get a dial tone,,,if you do then you know thats where the problem is
Feb 26, 2009 | Computers & Internet
Missing modem
what is XE3 circa 2002, 15 years young. wow.
XP is now 3 years dead, at microsoft.
why not at least upgrade to Win7. be wise to do that.
XP must have SP3, if not it will fail, and even with it it fail.
lots of USB devices for example will fail. here.
dial up, you dont run DSL.
ive not see dial up in 20 years. why dial up.?
if compelled to use dial up, you need a modem that XP understands
most of them it does not. nor will it ever,
there are 2 classes of modem. (DIAL up to POTS)
1: software modem (99% software, and a box) they SUX. all do.
2: hardware modem, best is USB. by
and A good dial up program,. windows dial up software stinks.
https://www.cdw.com/shop/products/Hayes-ACCURA-World-Approved-V.92-56K-External-USB-Mini-Modem/1651998.aspx
i see this is HP supported (was) modem
Agere systems soft PCI
it needs the HP.com driver to run that modem
does the number you dial buy hand (using a POTS phone)
dial up and answer and squeal? if not its hopeless that number
you need to pay for superscription service, and with a pass word.
LIKE HERE
http://www.earthlink.net/dialup/
THE PROBLEM IS HP NO LONGER SUPPORTS YOUR PC
SO THERE ARE NO DRIVERS. now.
why not get 10 year or newer PC, or get DSL to home
or cable modem with only 1 channel active, (slow like dialup)
for cheap. (im using 16channel now, as i type)
or buy a new modem and connect it and use the new modems
disk to install a nice dialer for you.
but finding one is not easy now.
the best modems, are Hayes, there hardware modems are like rock. i used them back in the ARPnet days and on amocat.
Apr 20, 2017 | HP XE3 SYSTEM BOARD WITH MODEM & LAN HP...
USB modem HiRo model H50113 will not complete phone connection
Yes you're right! What you have to do is:
  1. Right click My Network Places
  2. Select Properties
  3. Select the Advanced menu
  4. Uncheck "Operated-Assisted Dialing"
Jan 30, 2008 | Hiro V.92 56K AGERE Chipset PCI Fax Voice...
Lamaqq 56k v.90 SGS External USB Data/Fax Modem (MDMLAM56KUSB) Logo
117 people viewed this question
Top Lamaqq Computers & Internet Experts
David Payne
David Payne
Are you a Lamaqq Computer and Internet Expert? Answer questions, earn points and help others
