picture dosn't work but sound comes on. after a rew min, the pic comes on. if i change the channel the picture shuts off but the prijectors still have a dime lightpicture dosn't work but sound comes on. after a rew min, the pic comes on. if i change the channel the picture shuts off but the prijectors still have a dime light
You can't post conmments that contain an email address.
Go to your TV menu and see if there is an audio delay setting under the audio section or the setup menu. Some menus you can still see video while changing the delay setting until it appears synced.
hi,
if you are connected the S video output of ur dvd to ur tvs s video input , the u should connect another two RCA cable fo audio.S video connection is only for video input. connect the audio out put of ur dvd to the corresponding S video audio input, using a stereo RCA chord.
ok.
Your cable box most likely has a setting for audio HDMI such that HDMI sound is turned ON etc. rather than standard audio. Also check the TV settings for HDMI audio being set to ON. This should be a simple fix. HDMI audio usually is just a user setting adjustment and nothing more. Somewhere in your on-screen menus you should find the place to adjust HDMI audio.
Try going through the menus and check to see if speakers are turned on. otherwise its probably cheaper to buy a small component system to monitor audio.
No sir, there is not such switch in menu to change input from S video to HDMI or something. Here is one suggestion, Use 3 RCA pins cable (Audio L/R & Video) to connect both unit and check/ remember TV input and same should be selected in TV menu.
