Question about Car Audio & Video
The green lights on my 500/1 amp trun on but barley no sound comes out of it
Turned up the gain yet?
Posted on Apr 20, 2008
Low independence light comes on and a humming sound what is causing this?
Humming from subs? If from inside amp, your experiencing a problem with a driver board. It makes transistors latch on and loads down the transformer, causing light to come on. And vibrations "hum" from transformer.
Oct 16, 2012 | Jl Audio 500/1V2 Car Amp
The Ground wire is hooked up right but the red light wont go off and stay green so the amp will work. It is very frusterating all the cables are the right size its is a 1000 watt amp. I have two 500 watt...
Sounds to me like the amp is going into protection mode. Try placing one sub on the amp with very little gain. One of the biggest reason why this happens is because the subwoofers are wired wrong. What is the brand and model number for your amp?
Apr 14, 2011 | Car Audio & Video
My amp jl audio 500/1 i connect it and the green light turn on then i turn in the sterio and it sounds but when i turn off the sterio and when i wanna turn it on again the amp dont turn on i dont know why
Check the remote lead and see if it is getting power at the amp when it won't come on that way you know if the issue is with the head unit or the amplifier.
Mar 08, 2011 | Jl Audio 500/1 Car Audio Amplifier
My jbl gto75.4 red light is staying on and no sound what can the problem be.
check the cord from deck to amp when you trun on the deck it should go from red to green some of amps you do need to run a blue wire from deck to amp. that the remot wire.. so you don,t need it going bysingle from the rca cable... I hope this help you out ty
Feb 19, 2011 | JBL GTO75.4 Car Audio Amplifier
My Jl Audio 500/1, power light comes on but no power to subs
maybe it dont have enough to push it ,,did you try it before you buy it?
Mar 01, 2010 | Jl Audio 500/1 Car Audio Amplifier
My hp pavillion dv000 wont trun on, when i press p[ower buttin , lights comes on, no fan noise, dvd drive make litlle noise, green light on and off, after20 seconds alllights trun off, please help
mother board repair or replace disc check and bios is still coming up but the part that kicks on fans for cpu isnt working hope fully it didnt damage cpu but its possible
Nov 07, 2009 | HP Computers & Internet
Trun singles
Assuming that each signal only had two wires, it sounds like you are missing a ground on the side that makes all the lights flash. With 12vdc system, when you are missing a ground, the lights that are missing the ground will use the other lights on the circuit to ground themselves.
Sep 28, 2009 | 2004 Suzuki GS 500 F
JL Audio 500/1 Amp, The green power light is on but no sound!
Check to be sure you are on the correct outputs on the head unit, and be sure the outputs do not have a separate volume control.
Mar 06, 2009 | Jl Audio 500/1 Car Audio Amplifier
Psp wont start
Might be the memory card inserted on your psp causing the issue, try to turn on your psp while the memory card is not inserted.
Sep 28, 2008 | Ubi Soft Asphalt: Urban GT 2 for PSP
Jl 500/1 no sound, green light
This is an indication that the MOSFETs are ok but the driver stages may have a problem. Get a schematic find the pre-amp stages and test the voltages levels there as compared to the schematic. I do believe that you will find the problem in the pre-driver pre-amp atages.
Sep 03, 2007 | Jl Audio 500/1 Car Audio Amplifier
Car Audio & Video Logo
57 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
