Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
No spark form high tention wire chain saw will not start
    Brigadier General:
  • 4,088 Answers
Try a fresh plug gapped at 0.020". If no help, remove the cover from the flywheel side of the engine so that the flywheel and ignition module are exposed. Remove the ignition switch wire from the module and try for spark again. If nothing, then check the gap between the flywheel magnets and the module poles with a thin business card--insert the card into the gap and allow the module to snap to the magnets when the screws are loosened and then tightened. Rotate the flywheel somewhat to work out the card. Recheck for spark again--if still nothing, replace the ignition module using the same procedure as above for installation (don't forget the ignition switch wire). Hope this helps!
Posted on Jul 14, 2010
How to remove a fly wheel
Intermittent spark, new spark plug, no start
...chain saw cs 38cc smh038ub24ra em. u.s. epa ph-1, 95-98 ca. emissions regulations for ulge's. d048 Remove your flywheel cover then unhook the small wire from the magnito (coil). Tuck this wire out of ...
Oct 07, 2015 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Replace chain onchainsaw
As you do not say what model this is we will talk about generic replacment, start by making sure the chain brake ( if fitted ) is off, do this by pulling the hand guard fully back to the top handle, next remome the nut/nuts holding the side cover on, wind the chain adjuster screw fully back and remove the side cover, loop the chain over the nose of the bar and take away, loop the new chain over the sprocket and lay around the guide bar, making sure it is in the bar groove,the sharp edge of the cutters on the top of the bar should face away from the saw ( as you look at the saw the chain turns clockwise ) if the bar adjuster pawl is in the crankcase make sure it sits through the hole in the guide bar, if the adjuster pawl is in the side cover make sure this enters into the hole in the guide bar as you re fit the side cover, re fit the side cover nut/nuts finger tight, turn the adjuster so as the chain touchea all the way around the guide bar, with a gloved hand pull the chain around the bar, now re tention the chain if required, now lift the nose of the guide bar and fully tighten the nut/nuts, run the saw, there will be an initial stretch, so re tention as required, do not over tention the chain, it should pull around the bar by hand readily but touch the bar rails, not sag on the bottom of the bar.
Feb 11, 2012 | Garden
Where do u tighting up the chain on the chain saw.
Depends on what model, however there are two main locations for the adjuster screw, the most common is at the very front of the saw, running inline with the guide bar , you may well have to clean the dirt and saw dust from the front of the saw to see it,it will be close to the inside edge of the bar, it will be a normal screw driver head screw, turn clockwise to tention the chain, the other type will be in the side cover, at right angles to the saw, again it will be a normak screw driver head, turn clockwise to increase the chain tention.
Mar 20, 2011 | McCulloch Garden
I have a Poulan ES 350 and need to know how to put chain back on and tighten.
Start by removing the cover securing nut, remove the side cover,wind the chain adjuster screw at the front of the saw anti clockwise, until the old chain becomes lose, pull the guide bar out and off the adjuster pawl, should now be able to remove the old chain, loop the new chain over the sprocket, and into the guide bar rails, make sure the cutting edge of the chain on the top of the bar is facing away from the saw ( the chain rotates clockwise as you look at it )make sure the bar is still located on the adjuster pawl, re fit the side cover, re fit the securing nut finger tight, now turn the adjuster screw with a flat blade screw driver, until the chain sits snugley in the bar rails, there should be no sagging on the bottom of the bar, now lift the tip of the bar and fully tighten the securing nut, run the saw for a couple of minutes, now re check the tention. The correct tention is so you can lift clear two of the drive teeth out from the top of the bar.
Mar 14, 2011 | Poulan ES350 16" Chain Saw
Can't start my Chain Saw Husqvarna 350.
The fuel may have been replaced, but is the fuel filter clean or is the fuel line cracked? Even though you cleaned the spark plug, did you check to see if it has a spark? If not, maybe a new spark plug or check the wire to make sure there is nothing blocking where the wire and spark plug connect. Is the air filter clean? Just a few more things to check out...
May 14, 2010 | Husqvarna Chain Saw 20" Bar
Cuts out on high revs 240 chain saw
Many saws made today are using electronics for engine control. If the engine rpm's starts to rev to high, the electronics in the coil will start to 'cut out' some of the spark. This is normal in this senerio.
But, now the real problem causing the senerio;
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 10, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna chain saw rancher 55
Try this get back to us with the results.
Ignition Coil Test
http://www.youtube.com/watch?v=L7WNBDRG4C4&feature=PlayList&p=3789DC1EE87C8098&playnext=1&playnext_from=PL&index=21
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode. HTH
Lou
Oct 02, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna mod 41 chain saw wont start
If checking spark make shore the out side if plug is earthed to chain saw.
Fresh clean fuel, clean fuel filter filter pull exhaust off and check piston is ok. Than check for flooding. start there.
Jan 03, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
293 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
