Question about Kodak i65
My kodak scan i65 flash eight times and stop for 3second and restart to flash what's this
Just fixed this on one at our company. There are two screws on the output side of the ADF, these hold the cover on. Remove the screws, pull the cover off of the ADF. Where the paper goes in, you will see a small black plastic piece with a spring and a small switch that dangles down, just to the left (as seen when looking into the ADF from the paper's point of view). A tiny straight screwdriver into the slots just below the black plastic piece will release the clips holding it in place. Check the spring. On ours, it had popped loose from the hanging switch. This apparently the paper sensor (documentation on this machine is insanely hard to find). There is a tiny notch at the top of the sensor arm, the straight piece of the spring should rest inside this. The other end should rest below the post that holds the spring. After getting all of this straightened out, our scanner started working again, but of course fixing one problem usually reveals another problem lurking behind....
Posted on Mar 17, 2011
  • jrgossma Apr 04, 2011
    I have had this same issue with our i65. Is it possible to purchase a new paper sensor?
  • RabidAlien Apr 06, 2011
    I haven't found one online, no. You might check Ebay or Craigslist for a damaged/non-working one, and cannibalize the sensor out of that.
Can i by pass the anti theft on a 2006 jeep liberty
never.
if the immobilizer lamp is on, ? or flashing
the IMMo cuts fuel ! then spark. will run for 3 seconds, using the 3second, ASD relay logic rules. The IMMO lamp dont lie.
have 2 keys<> try both yet>? if not why not? never have just 1 key. ever. (or go broke soon).... tow, the dealer fixes. etc.
so if the IMMO acts up , with both keys
we scan it,
if you scan it IT WILL SAY WHY ! ( with DTC errors related)
Apr 27, 2015 | 2006 Jeep Liberty
Pride Elite Traveler Plus occasionally stops and flashes eight times. Turning off and on corrects for a short time.
Hi, right it normally one of two things:
1. the connection to the rear axle, remove rear axle and clean the four connectors, gently, make sure there is a good contact.
2. The connection of the battery pack to the frame, again clean and make sure there is a good connection.
Regards
Jan 20, 2013 | Pride Health & Beauty
Is there a wia driver for Windows 7 for the Kodak i65 Scanner?
Well I too HAD this problem. Upgraded to Win7 64 bit and was unable to install the existing 32 bit drivers (of course) that operate in WinXP and Vista. Called Kodak and there wonderful answer was Buy a New Scanner.
Well this was just not an option. SO I searched and searched for alternatives, to creating a WinXP Virtual machine with VMPlayer or VirtualBox to remote controlling an older WinXP laptop connected to the scanner. None were solutions I felt I could live with.
Then I found VueScan at www.hamrick.com. A small chea scanning software that you can try before you buy. I read through everything on the site including the specific scanner notes for the Kodak I65, then downloaded the trial version.
Once installed you follow the instructions from the site to use VueScans own driver to run the Kodak scanner and lo and behold I got my ORIGINAL Kodak scanner menu to work on Win7 64bit. Then I used the VueScan software to scan a document and it worked like a charm. Albeit with the VueScan watermark.
Now I could have stopped there and called it a success, but I then, tried scanning with my Nitro PDF Pro software and was amazed to get a Perfect scan without the watermark.
Now NOTE, I did not buy the VueScan software at this time, as I don't need it's ability. I just used their driver and driver installation instructions from the website specifically for the Kodak I65. Most likely going to buy the basic version of the software anyway, as I think the guy deserves something for saving my EXPENSIVE I65 from becoming a paperweight.
An Elegant and Complete solution to Kodak's total support failure!
N
Jun 08, 2011 | Kodak i65
It does'nt support with windows 7
I'm afraid there are no drivers running under Windows Seven for this unit.
If you have the W XP install disc , you could install a virtual version of W XP on your HDD ( http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 )
You could also partition your HDD ( http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one .
Otherwise , you will have to buy a new scanner .
Regards .
Dec 28, 2010 | Kodak i65
Kodak ESP9 all-in-one printer. unable to scan to doument
how do you scan your document are you using the buttons on the printer or are you using the computer and the home center software?
If your using the printer buttons I strongly suggest use the computer and its software the home center. Now if still not scanning and it takes time to scan. restart the computer and while the computer is restarting unplug the power cable of the printer., then do again the scanning if yur computer is ready.
If the troubleshooting did not solve it means the software or the home center is having a problem call kodak for assistance for the software toll free 1 800 421 6699., GudlucK
Nov 01, 2009 | Kodak ESP9 All-in-One w/USB Cable & 4x6...
Kodak esp-3 unable to scan from home center,but able to print
If you are getting a 1-2036 error then there maybe an conflict between the Kodak TWAIN driver and another TWAIN device, most of the time it is with a flat bed scanner. If you have another All in One printer or scanner connected unplug it and uninstall its drivers. If the issue continues uninstall the Kodak software and unhook the kodak printer. Then download the kodak clear utility from HERE
After the utility runs and you restart your computer Re-install the Kodak Printer software and select WEB install to get the latest version.
Hopefully that will solve your Home Center scanning issue.
Jul 13, 2009 | Office Equipment & Supplies
Will not scan kodak easyshare 5100
For WINDOWS VISTA/XP Operating Systems:
  1. Go to:
    • C:>Windows>twain_32>Kodak>Kds_aio5000
    • C:>Windows>twain_32>Kodak>Kds_aioesp
  2. Confirm the folders Kds_aio5000 and Kds_aioesp are available in C:>Windows/twain_32/Kodak.
    NOTE: If these folders are missing, the following error codes will be generated:
    • 1-2036 when scanning
    • 1-2037 when printing
If the error condition continues:
  1. Right-click the KODAK AiO Home Center icon.
  2. Click Properties, then select the Compatibility tab.
  3. Clear all checked boxes.
  4. Click Apply, then OK.
  5. Scan a document from the Home Center.
Jun 03, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Can't scan with Kodak Easyshare 5300 printer
My Scanner (Barely used, not even through the first set of ink cartridges yet) was working beatifully. Then all of the sudden the same thing happened to mine...blinking lights...Power light flashing Yellow...I contacted Kodak and they had me do the same old thing...Unplug, uninstall, reinstall, restart. Nothing works...They also try and have you redownload firmware (But Hello....You cant if the printer isnt ON!) So I went back to them again to say none of it worked. They said its the print head and they are sending me another one. Ive read a lot of terrible reviews of this printer just because of the crappy print head...You would think they could fix that by now, or have 5 extras in the package when you buy it.
Feb 27, 2008 | Office Equipment & Supplies
Go to Control Panel
Double Click on Printers and Other Hardware
Double Click on Scanners and Cameras
Double Click on Kodak 5100 AiO
Click Next
Read and follow directions
It ain't rocket science
Feb 08, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
I 65 scanner sensor
go here and scroll down, you will see the feed module for $31
replace that
hope this helps
thanks for your rating
Jan 08, 2008 | Kodak i65
Kodak i65 Logo
178 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
