Question about Canon LASER SHOT LBP-2900 Printer
How many pages for this printer for one toner
  • 1,219 Answers
Abaut 2500 prints, wich is calculated with coverage of 5% on A4 paper. These applys on genuine crg.
Remanufactured crg. quantity depends on guy wich is filled the crg.
Posted on Jul 12, 2010
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Jam at exit open door a
Could be a fuser problem, but could also be very poor quality toner cartridge(s). If a remanufacturer/compatible maker uses the wrong toner powder, it can have the wrong characteristics.
I've seen these printers with poor quality cartridges able to print a page with very little toner coverage OK, but jam EVERY page that has much real 'density' of toner. Even the configuration page on these printers has a solid band of red 5mm or so wide across the lower part of the page. Poor toners - where the fusing temperature is incorrect for this printer will cause the page to jam in the same place in the fuser EVERY TIME.
The cure - Genuine Xerox toners, or GOOD QUALITY remanufactured toners from a reputable source.
Aug 19, 2014 | Xerox Phaser 6180 MFP/D laser toner
Laxmark e260dn laser printer printing blank page
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint.You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer.This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter.A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Jan 05, 2012 | Lexmark Office Equipment & Supplies
Am confused,i want to buy a colour laserjet printer and left with only two options which one should i buy btn hp1600 and cp1525
hiii
Its depends on your printing needs.Printing quality almost same these two printers. If u buy hp 1600 u will get more pages than cp 1525.But u should think about the toner cost. Check your local market price for each toners.Here i will give u the toner model numbers for ur required printers.
hp 1600 - q6000- black,q6001,q6002,q6003 each three colours.- Page yield 2500 pages for black ,2000 pages each colours.
hp cp1525- ce-320a(128a),ce321,ce322,ce323- Page yield -2000 pages for black,1300 each colour pages.
So I am sure hp 1600 toner very costly than 1525 toner.If u dont have huge volume printing better i suggest u buy cp 1525 model.Also this model offering wirless printing .
U can refill this toners lowest cost and getting good results.
sooooooo cheeeeeeers up........select your new printer. best wishes..........
Jun 14, 2011 | HP Color LaserJet 2600n Printer
My Brother HL2140 printer was running fine and all of a sudden the toner light is on and it stopped printing. Just yesterday when i printed out the status for the drum and toner it showed more than 80 %...
636 is a lot of pages and depends on the toner coverage you may need to replace the toner.. 80 - 75% (is that used is remaining ??) any way check your waste toner basket first (see you manual for instructions) chances are its filled and needs cleaning or replacing (see your manual for instructions) If its fine then change your toner .. If you have the demo toner (toner shipped with machine) these contain less toner than a new cartridge and will finish faster ...
Jul 26, 2010 | Brother HL 2140 Laser Printer
Black Toner issue
Does your toner cart have any little clear plastic windows?
HP printers shine a light through this window to ***** toner level.
Cover one of the windows with tape & the printer will think the cart is full.
Sep 03, 2009 | HP LaserJet 4600dn Color Printer
Printer hp 4600 dn consumes a huge quantity of toner material especially magenta and black. Toner is exhausted after 3000 copies with mostly copies without pictures. Can it be possible that starting the...
the toners are rated for a certain number of pages based on 15% coverage on the page. print a supplies usage page from the control panel on printer if available to show you how many pages you printer and what the coverage was.
calibration does use ink, but should not be that much.
If you are using non-HP toner, this may be why you don't full life out of them. Try HP toners and see if problem remains.
Sep 02, 2009 | HP LaserJet 4600dn Color Printer
Toner Saver.
Using the Toner Save Mode
The Toner Save mode allows the printer to use less toner on
each page. Selecting this option will extend the life of your toner
cartridge and reduce your cost per page, but will reduce print
quality.
There are two ways to enable the Toner Save mode:
From the Control Panel
Press the Cancel button on the control panel. The printer must
be in Ready mode (On Line/Error green LED is on).
• If the Toner Save LED is on, the mode is enabled and the
printer uses less toner to print a page.
• If the Toner Save LED is off, the mode is disabled and the
printer prints in the normal mode.
From the Printer Properties
You can also enable the Toner Save mode in the Graphic tab of
the printer properties. For details, see Software User’s Guide.
Jun 30, 2008 | Samsung ML 2010 Laser Printer
Toner all over the page with bubles
REPLACE THAT BAD RECYCLED TONER CARTRIDGE
Jun 18, 2008 | HP LaserJet 4350 Printer
Hey m8
  • Buxie, first off you have voided your warrenty, secondly
  • If marks repeatedly appear on the printed side of the
    page at even intervals:
    • Clean the inside of the printer. See “Cleaning the
    Inside of the Printer” on page 5.7. After cleaning
    the inside of the printer, if you still have the same
    problems, install a new toner cartridge of the
    problem color. See “Replacing Toner Cartridges” on
    page 5.3.
    • Parts of the printer may have toner on them. If the
    defects occur on the back of the page, the problem
    will likely correct itself after a few more pages.
    • The fusing assembly may be damaged. Contact a
    service representative.
  • If horizontally aligned color or black streaks or
    smears appear:
    • A toner cartridge may be installed improperly.
    Remove the toner cartridge and reinsert.
    • A toner cartridge may be defective. Install a new
    toner cartridge.
    • If the problem persists, the printer may require
    repair. Contact a service representative.
  • SXPRESS- It is normal to have to replace it after that because the starter cartridges are rated for 1500 pages but that is at only 5% page coverage and most people print alot higher coverage than that, and the replacements cover 2000 pages again @ 5% page Coverage
May 20, 2008 | Samsung CLP 300 Laser Printer
Canon LASER SHOT LBP-2900 Printer Logo
75 people viewed this question
old marine
old marine
