Question about GE Dishwashers
GE PROFILE model number PDW8980N00SS , normal
GE PROFILE model number PDW8980N00SS ," normal" cycle won't come on in the push button electronic control panel . however all other buttons/cycles work . whats keeping the "normal" cycle from running ?
SOURCE: "Clean light" keeps blinking; dishwasher won't start new cycle
Check to see how it's loaded. If something is obstructing either of the spray arms it will not start. I had this same problem and checked to see if there was something impeding the arms - I found there was. Reloaded the unit and it's running like a champ now!
Posted on Feb 09, 2008
It says in the manual to check the heating element.
Posted on Sep 10, 2008
  • 111 Answers
SOURCE: Buttons won't work on GE Profile PDW7980N10SS
You have the control lock activated. Press and hold the heated dry pad for 5 seconds and it should unlock it
Posted on Dec 18, 2008
SOURCE: dishwasher door will not open.tried
The plastic latch release inside the door handle is broken. Most likely one of the pins holding it in place has broken.
First go to your local dishwasher supplier and look at a similar brand (GE Profile in my case) and see how the mechanism works. Next, get a thin pair of siccors, pull the dishwasher handle down and slid the siccors into the opening above the handel and push the tab holding the door closed up so it will release.
Once the door is open, remove the inside of the door to get to the latch. Remove the plastic latch release and order a new one.
Posted on May 30, 2009
SOURCE: Regarding Maytag Dishwasher, model # mdb4651aww3.
I have same problem with my Maytag. Had a repair guy come out and he said it's the 'controller card', not the button touchpanel. The controller card is $127 and not in stock and there's a 'several month wait'. I'm not going to wait, going to buy something used for less than the price of a new controller card. Maytag's quality has really deteriorated in the past few years. They used to have a 5yr warranty on pretty much everything - now it's only 1yr. (and of course, mine failed just a few weeks after the 1 yr time.
Posted on Jul 31, 2010
Why does the dishwasher stop mid-cycle when I use the normal cycle
You need to provide a brand/model number and more info--does the unit fill with water and run? Does it drain the water out? Does the problem only occur on the normal cycle or on any of the cycles? Is the cycle select an electronic push button type or is it the older, mechanical, rotary knob type? This extra info will help narrow down the issue.
Aug 12, 2015 | KitchenAid Dishwashers
How to set temperature on GE Profile PSS26NGPA WW?
Press and hold temp up button then press quick freeze button at the same time, your temp settings will be displayed on display for fridge and freezer, fridge temp is + and freezer -, cycle by pressing quick freeze, set temps by up and down temp buttons, once done, push vacation button. your temps are now set, turn the unit off for 2 mins the turn on. reaction is now set and normal. regards Russ
Jul 03, 2012 | GE Refrigerators
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Owners manual for GE phone model no. 27958GE1-A
    http://www.home-electronics.net/USER-GUIDES/27958_DOM_ES_CL_IB.pdf
    Aug 21, 2010 | GE 27958GE1 Cordless Phone
    GE profile top loader, agitator and spin start and stop
    Is this a newer model washer? I have one of the newer models and it does the same thing. It is supposed to do that.
    May 23, 2017 | GE Profile Prodigy WPSE4200A
    The f7 number keeps beeping on my GE profile range. i am assuming the oven is no longer working as nothing happens when i push the bake button. the most annoying problem is that f7 beeps all the time; it...
    F0 or F7 Shorted Clear/Off Key due to membrane switch, control or connector Shorted key panel membrane switch; Check Electronic Range Control (ERC)
    you have a stuck button on the key pad you will need a new control board to fix this.
    goto http://lartoday.com/order_parts.htm , enter your full model number and search for control
    levi
    Lebarchrigen Appliance Repair
    Mt. Holly, NJ 08060
    www.lartoday.com
    Dec 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE Profile washer won't spin cloths after wash or rinse cycle
    My GE washer model number WLSR2000G3WW washes and pumps water out but will not spin...can someone help me to solve my problem PLEASE?
    Jan 23, 2009 | GE WBSR3140DW Top Load Washer
    Nov 15, 2008 | GE Profile PDW8400J Built-in Dishwasher
    GE Profile-electric oven
    Copper, F3 means oven temp sensor is open. You need to replace the probe. Easy job. Part number I have for this is WB23X5340, but double check your model number. Look it up on the net to see what you are going after...Catriver..post back
    Sep 19, 2006 | GE Profile JTP18 Electric Single Oven
    Dishwashers Logo
    71 people viewed this question
    Top GE Dishwashers Experts
    Mike
    Oloyede Monsuru
    Are you a GE Dishwasher Expert? Answer questions, earn points and help others
