Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
KitchenAid KSCS25INSS00 I can't get my ice maker to make any ice. There is a red blinking light that blinks twice. I just bought this from a guy and it has been sitting unused in a garage for a few months. The water dispenser works but the water isn't very cold. Any suggestions?
  • 4,070 Answers
Is the freezer cold enough? Should be close to 10 degrees. Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start. If it does dump the ice but don’t refill with water. ICE MAKER NOT GETTING WATER Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Posted on Jul 12, 2010
  • jmashman Jul 12, 2010
    I don't have a diagram of the lines. So I am not sure how to switch the lines as you suggest. The freezer is cold enough... I have other things frozen in it.
Ice maker will not make ice. Red light blinks
I have a kitchenaid with the same problem. Red light blinks twice when open is normal. Hold the flap down and the red light will be on.= normal= optics are working. If the ice rakes rotate, module is probably fine. Check the simplest solutions first, defrost the freezer in case the icemaker water nozzel might be frozen. That solved my problem. I then increased my freezer temp by a couple of degrees and so far, no problems.
Good luck.
Jan 30, 2010 | KitchenAid Superba Architect KSCS25INSS...
Have kitchen aide fridge ice maker stoped working, replaced ice maker still not working, red light blinks twice? Help
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hkhjkd
Jan 06, 2010 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Fridge, Ice maker not working - red light blinking
Replace the icemaker . The laser receiver (on right side ) is supposed to blink twice then pause then twice repeatedly .Normal. Also clean the coils under fridge .
Aug 02, 2009 | KitchenAid KSCS25FKSS Side by Side...
Red light blinking on ice maker and ice maker not making ice
the red blinking light is normal . it sounds like you have a whrilpool,kitchenaid or kenmore made by whirlpool. if your ice-mkr fingers are not resting in the 2 o'clock position, then your
I/M motor/module is broken. use part#8201515
Jul 16, 2009 | Refrigerators
Red light on ice maker blinking twice, no ice.
I would assume you are referring to the ice level sensor that is on the center divider. It is normal for it to blink if the door is open. You can test out this theory by holding the flap on the left side closed but not blocking the sensor. The light should go steady. If the ice maker is not working then you either need to change the lazer sensor or the ice maker itself.
Feb 01, 2009 | KitchenAid KSRG25FK Side by Side...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
411 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
