Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
On the freezer side the coil inside in the lower back is bright orange and water is dropping on it making a hissing sound. Is this normal?
  • Kenmore Master
  • 2,605 Answers
Hi, Welcome to FixYa. It is indeed normal for frost free fridges. You are witnessing the defrost process taking place actually. Once it defrost's for approx. 15-30 minutes, the unit will cycle back to cooling. Hope that answers your question and puts your mind at ease. Thank you for choosing FixYa and I hope you will now take a moment and rate the info you received here favorably. macmarkus :)
Posted on Jul 12, 2010
I've never noticed this before today and I'm not sure if it's normal or not but there is water dripping onto something on the freezer side. It makes a sizzling sound when it hits it. I...
when in defrost there's a heater under the evap coil in the freezer,all you're hearing is the water from the frost melting off of the coil and hitting the heater,this is a normal thing so don't be worried,you might even see an orange glow in there through the holes or at the bottom of the back inside freezer panel,it's just the heater doing it's thing,then the water goes into the drain and down near the compressor where it will evaporate,
Sep 04, 2011 | Refrigerators
I have a model ED2CHQXKB05, series SR4452983 from November 2004. Freezer on the left side. The freezer drips into a vented area in the back: I can see the drips when I open the door, and each drop makes a...
What you are describing is the normal sounds it makes when it goes into defrost. The frost melts, and the resulting water will fall onto the heater which then makes your hissing noise. You dont mention that there is a problem, such as not cold or water leaking on your floor, so it sounds like all is working as it should. But you also mention you taped IT ( what is it?) to the wall in a circle.
Oct 12, 2010 | Whirlpool Freezers
I have a Maytag MSD2651HEW refridgerator--it's about 4 years old. Tonight I opened the freezer and I can hear and see water dropping onto the metal coil inside the freezer--so it makes a hissing sound. ...
You just happened to catch the freezer in the defrost mode... that is very normal and it should stop in a half hour or so and go back to normal operation...
heatman101
Sep 02, 2010 | Maytag MSD2651 HE Side by Side...
We have a Kenmore side by side refridge serial #55251 that was making a hissing sounds. We looked at the bottom of the inside freezer and there appeared to be an element that was very red and water was...
Your fridge is fine it was in defrost mode during this an element heats up to melt any frost and ice in the freezer. But yes the hissing sound does sound alarming but is perfectly normal. hope you have a nice day
Aug 15, 2010 | Kenmore Refrigerators
Bright glowing coil is this normal?
Yes, it is the defrost heater, that's why your fridge is frost-free.
Feb 16, 2010 | GE Profile PFS22 33" Artica French Door...
We have a TFX25JR side-by-side with ice maker and water dispenser; had water leaking on floor on freezer side of bottom left corner. Comes under tray, cleaned the coils and seemed to work, but 2 weeks...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Orange glow in freezer, what is it?
Your refrigerator is a frost free unit. The derost cycle in a refrigerator is controlled by a timer or an electronic control. When a unit goes into defrost, the fans and compressor are turned off and a heater in the freezer is energized. This is the glow that you see, and the hissing sound is the water droplets, from the melting frost, making contact with the heater. This is perfectly normal.
Apr 27, 2009 | Refrigerators
Glowing light and warm air freezer side
HI thanks for your question. you found your freezer in a defrost cycle, which is normal function.the defrost cycle happens every day every 10 hrs. on for about 20 min. then resumes the cooling cycle. so its normal. thanks the appliance doc, please rate my answer. thanks.
Oct 12, 2008 | GE Monogram ZICS360NRRH C... Bottom...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
112 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
