Question about Nikon Coolpix S210 Digital Camera
Lens error. I took my camera to a water park and accidentally someone splashed water and since then the lens is out,and i' unable to close the lens. It says lens error. Please suggest a best possible way to salvage my camera. Thanks
    Sergeant:
  • 420 Answers
It may have caused damage to the lens or the dirt in the water may have got stuck in the joints which makes it jammed. keep it to dry and then blow air over it..
Posted on Sep 11, 2010
When I turn off my CoolPix S6 the lens would close completely. When I turn on my camera the lens is completely open and the screen just says lens cover error.
The lens is damaged and needs to be replaced. Sometimes with use or maybe an accidental hit to the lens can cause a malfunction to the camera resulting in that error. Also if you for example took the camera to the beach, getting something like sand in the camera can jam up the lens and prevent it from fully extending or retracting.
Mar 24, 2011 | Nikon COOLPIX S6 Digital Camera
My camera turns on then beeps 3 times then shuts off is it broken or is there a reset button?
The three beeps mean that the lens motor is unable to extend the lens assembly.
This could be due to a low battery situation, but the most likely cause is the lens drive train stuck or jammed. You'll find generic instructions on solving some cases of jamming here.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Unfortunately, more serious cases (due to falls, shocks, and most of all, the camera being turned on while some resistance prevents the lens from extending: e.g., if the camera accidentally turns on while in a pocket) require the repair shop.
Apr 27, 2010 | Samsung Digimax S730 Digital Camera
Canon A630 lens error and black photos
hi u need to get the lens repaired the railing in the lessystem is no correct so pleas dont try to doit or push in .... it will be permanent damage ....get to the shot5 the camera is not broken need small fix....
Aug 30, 2009 | Canon PowerShot A630 Digital Camera
E 18 problem
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jan 12, 2009 | Canon PowerShot A400 Digital Camera
I Have a Canon powershot A410 and I cant get it to work anymore. The lense will not open and it beeps at me and then E18 shows up on the bottome left hand side of the screen. I can still down load all my...
The "E18" or "Lens" error message indicates an error that involves the lens unit or lens cover.
This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution
Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area:
  • Hold the camera so that your fingers do not touch the lens unit when you are shooting.
  • Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service
Oct 21, 2008 | Canon Cameras
Coolpix lens opens retracts opens then closes again and lens error appears
Hello
When you turn the camera on the lens comes out and has parameters when extending to focus, if the lens does not open fully it sees a problem and then closes.
there are tiny plastic gears inside and may have chipped or a piece of sand got in causing the lens to jamb. "very fragile"
one solution is to ask a camera repair shop how much a lens mechanism would be to replace. (if cost is more than 1/2 of what you paid dont bother)
another solution is to have someone sell your camera on an auction site for parts, to make some money towards another camera purchase
Aug 26, 2008 | Nikon Coolpix L11 Digital Camera
Sanyo VPC-E760 Lens not closing
THis is really easy to fix. just pull the lense out so it is alligned. it might seem like your breaking the lens but its just jammed.
Feb 17, 2008 | Cameras
Lens error Help please
The Lens Error usually means the lens has sand or another obstruction stopping it from retracting.
Nov 07, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens error, restart camera
Your Camera is full of sand and you can try blowing it out and banging it out. But I'd say it's time for a new camera. Regards Thestreeker
Sep 18, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Salt water splash....
I hope by now you've taken it to a repair shop - salt water is deadly to any camera after 2 or 3 days it'll be uneconomical to repair.
Jun 26, 2006 | Canon PowerShot S500 IXUS 500 Digital...
Nikon Coolpix S210 Digital Camera Logo
85 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
