Question about Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool front-loading Duet washer has a F-5 code. What does it mean and how can i fix the problem.
  • 5,911 Answers
"F05" is an NTC Heat Sensor error. This is an indication that the heat sensor is either defective, or the interconnecting wiring has come loose. The following link explains:
http://www.fixya.com/support/r3608669-f05_error_code
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If the model number is correct, the part number for the heat sensor is 8181705 and is listed as item 24 under the "Tub and Basket Parts" listing.
NOTE: For an explanation of all the error codes, each one of these appliances come with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and let me know if you have any further questions. I hope you find this information helpful.
Posted on Jul 12, 2010
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Whirlpool duet washer fills with water washes for about 12 min then code hf
The FH error code means that the washer has not detected any water entering it. This tip i wrote relating to the FH code covers what to checkto fix it.
http://www1.fixya.com/support/r10423905-fh_code_means_duet_epic_front_load
GENE
Oct 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Get the code F-01 on the whirlpool duet front loading washer, not sure what this code means
Click this link directly:--- http://mymoremoney.blogspot.com/2011/01/whirlpool-duet-ghw9150p-front-load.html --------------- In this there is instructions and procedure mentioned to resolve the issue. If any part checked out faulty then you can get it from www.repairclinic.com .----------- Thanks.Helpmech.
Jan 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet front load washer is giving a F 11 error.
power failure--------unplug the unit for 5 minutes and see if it clears that code
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does f-24 mean?
inside the machine should be repairmans instructions. this includes explanations for all the error codes.
you will have to remove the front access panel
May 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have an F26 code and my washer won't do anything and cannot find code in the manual what does it mean? It's a whirlpool duet ht
Hi, This F26 error means "door switch error" If the door has not been opened for three consecutive cycles or the door switch is open while the door is locked for more than 5 seconds
Do the following to fix the problem:
Open and close the door
Verify CCU operation by running a Diagnostic test or any cycle
Push the door and check if its completely closed
Apr 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer displaying a fault code.
check your manual. it will tell you what it means and what to do
Apr 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport ~ E28 Error Code
serial communication error between central control and motor control.
Check connections at ccu (top front right corner) and mcu (bottom by motor), check belt drive for wear.
Did motor run ? Any other codes in diagnostic? (any one modifier button 4 sec on 4 secs off 5 times.) F codes are failures and C codes are portions of test cycle(automaticly run)
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer not spinning/draining and it's showing me a code (F21)
clean the drain -here are a few postings i used to fix my Whirlpool ****-eettt (Duet)10 minutes ago. google whirlpool duet there is a 5 min video by jim that walks through the whole gig. 3 screws a twist & you're done your correct so lets fix it...take bottom acess panel of ..theres three screws,,,ok ready clean that pump filter it right in front of you twist it out always unplug first unplugged good,,now while your down there with the filter out,,check booth black hose to make sure theres no coin or hair clips while you have it open,,onthejob
Mar 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
