Question about HP PSC 2210 All-In-One InkJet Printer
The cartridges are stuck to the right and the door won't lock?
    Scholar:
  • 103 Answers
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Posted on Jul 12, 2010
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
I have a Pentair MiniMax NT. I am getting ERR on the display but I can't seem to get the door open. I have tried turning the single screw that locks the left and right door but it won't unlock.
sometimes the door is just stuck. try pulling the door as you turn the locking screw. sometimes you need to use a flat head screw driver to help the door open as you turn the screw back and forth
Jun 11, 2011 | Pentair Minimax NT Heater
Our printer states printer jam but after examining it numerous times it does not have any paper stuck inside. What could be the problem?
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Dec 16, 2010 | Brother MFC 240C All-In-One InkJet Printer
Carriage gets stuck, Won't print. Power button starts flashing "red"
Check the following steps for fixing Hp Carriage Jam Error :
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Nov 09, 2010 | HP Photosmart 7450 InkJet Printer
Papper got stuck . spongy peace 9"x1/2" came out ,
Nov 04, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Piece of paper stuck inside my HP printer
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Oct 21, 2010 | Office Equipment & Supplies
2006 chev.colora the door lock on the front right side won`t work
Common for the door lock solenoid to go bad and your going to need to replace it. You may hear it clicking but it's to weak for it to lock and unlock the door.
Thank you for using fixya and good luck
Apr 26, 2010 | 2006 Chevrolet Colorado
Not locking have to manuely lock from inside the car
the wires in the trunk lid are broken. this model has poorly designed electrical. there is a wire bundle on the right hand side of the trunk lid open the bundle up and resplice the 4 wires. this will correct the doors and remote trunk opener.
Feb 16, 2010 | 2000 Buick Century
Unable to remove black cartridge, it is really stuck. Help
I just changed my black toner this past week, and finally figured out why the cartridges get stuck like this.
First, you must eject the toner cartridge on the front-panel menu:
Menu->Replace Toner->Eject Toner->Black(K)
It will say "Rotating to Black Toner(K)" and then say "Black Toner(K) Ready to Eject"
Now, open the front panel and you'll see the black toner cartridge in front. You can also open the top panel if you want more light on your work area.
Lift the lock handle on the old toner cartridge to the "unlock" position, and here's the part that the Dell instructions don't have:
There are two channels for the toner cartridges -- one on each side. Run your finger down the channel on the right, and you'll feel a small, spring-loaded catch. This catch often gets sticky and won't release the cartridge without some help. Don't force it, but gently move it towards the back of the printer and it should release.
Now the old cartrdige should slide right out, and you can finish per the instructions that came with the new cartridge.
Jan 27, 2010 | Dell 3100cn Laser Printer
Wont read ink cartidrige
first try taking out the cartrage and try uninstalling the printer off your computer then reinstalling it. before putting in your cartrage make sure your computer detects it and your computer should tell you that it detcets no ink then try replacing it. if the problem consists make sure youave the right cartgae for that printer. Then check that nothing (paper, pen, anything) is stuck or jamming the computer blocking the cartage sensors,
Jan 17, 2009 | Epson PictureMate Photo Printer
HP PSC 2210 All-In-One InkJet Printer Logo
64 people viewed this question
Seeker5211
Seeker5211
