Question about Kenmore Refrigerators
It's warm inside doesn't get cold - Kenmore Refrigerators
  • 1,557 Answers
If the light is still working then the first place to start looking for the problem is to check the thermistate. if that is ok then check to see if the pba plug on the generator has burned out.
Posted on Jul 12, 2010
Electric heater problems.
Plug in a ceramic 120 volt or oil type space heater to keep trailer warm. Most travel trailers are propane only, they do not have electric heat strips. I would bet that is why it only blows cold air.
Jan 28, 2014 | Open Range 2011 Mesa Ridge MR243F
Why tracker transmission lock in cold weather?
You have valves inside the transmission and electronic controls inside the transmission. When cold, valves do not work because the fluid is too thick. Once warm the fluid thins out and allows tranny to shift OK. You can burn your tranny up by not letting it warm up.
Feb 18, 2013 | 2002 Chevrolet Tracker
I have a 1993 mercury grand marquis and reverse doesn't work after it warms up. It does work when cold.
You can check with a local transmission shop, but usually the problem is a worn band or a weak pump. The reverse band also affects low gear.
There may also be a solenoid involved.
Sep 15, 2012 | 1993 Mercury Grand Marquis
1997 oldsmobile cutlass stuck in park until car warms up
There is a safety switch inside the gearshift assy. (below where you shift the gear handle) this safety switch locks the gearshifter in park until you press the brake pedal. pressing the brake pedal is supposed to release it. obviously it's not, so there's soda, coffee, or other substances making it sticky, or it could be just worn out. Take the cover plate off & look for this plastic piece attached to a cable(covered in black plastic) if it needs cleaning, use alot of warm water & a shop-vacuum. if cleaning doesn't help, then replace the cable (may be part of the shifter mechanism.)
Aug 10, 2012 | 1997 Oldsmobile Cutlass
Freezer side works fine, Refrigerator side is too warm
Hello.
The leading problem when freezer works yet the refrig. section doesn't get cold is going to a problem with a automatic defrost system defect. Do ya see a bunch of frost inside of the freezer on the back wall?? if yes ya do see that frost build up ist defiently not defrosting and this tip i wrote covers what to check when it doesn't defrost http://www1.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Oct 04, 2011 | Jenn-Air JCD2389G Side by Side...
Refrigerator not cooling. doesn't seem like fan is blowing. freezer still working
all that happens is the cold air from the freezer gets blown into the fridge section by the evap fan motor brhind the inside back wall of the freezer so if you open the freezer door and don't hear the fan blowing i would say that yes you do have a bad evap fan motor and that's why the fridge section is warm.next time send the brand name and model number so i can help you better
Sep 17, 2011 | Refrigerators
Cold air doesn't circulate on either side - top of both sides is warm and bottom is cold...what should I check?
Hello, Thank You for using FixYa. I will be helping you today.Check the fan behind the inside panel in the freezer. If its getting 120v and not working its bad and should be replaced.If there is frost all over the back of freezer and fan is working its a defrost issue.The most common defrost failure in this unit is the defrost thermostat.
Thank You and please rate my answer if it was helpful..
Jun 15, 2011 | Frigidaire FRS26H7 26 Cu. Ft. Side By Side...
Very slow cold water flow
soundslike either your cold water supply is not turned on all the way or the inlet valve is clogged w/debris. try removing cold water hose and checkin inside the valve, sometimed youll be able to remove sediment adn debris from valve from screen, if thats not the case youll need to replace the vavle itself
Apr 17, 2008 | Maytag MAV2755A Top Load Washer
No cold water on cold settings
Try switching you hot cold inlets to the washer on the back....If that doesn’t work let me know...
cbinny1
Jan 04, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
