Question about Garmin nuvi 1350 Car GPS Receiver
Garmin nuvi 1350 screen black cracks
My Garmin nuvi 1350 looks like it has black cracks (screen not actually broken) on the screen which is only white. Will make sounds when I touch it, but cannot see anything on the screen. What's wrong?
  • 1,557 Answers
It sounds like the unit has been dropped and has cracked on the inside of the screen. we see this a lot with mobile phones. you may need to have the internal screen replaced.
Posted on Jul 12, 2010
Tip
Garmin Nuvi 1350 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1350 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1350 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1350 Manual Download
Garmin Nuvi 1350 QuickStart Download
Garmin Nuvi 1350 Webupdate
Garmin Nuvi 1350 Favorites Backup
on May 15, 2010 | GPS
Tip
Garmin Nuvi 1350 Favorites Backup and Restoration Procedure Models: Nuvi...
Would you like to back up a copy of your Garmin Nuvi 1350 Favorites and Waypoints?
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
I hope that helps.
Tip
Download Garmin Nuvi 1350 Quickstart Manual
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1350 GPS?
Would you like a digital copy of the Garmin Nuvi 1350 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1350 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
Tip
Download Garmin Nuvi 1350 Manual
Have you lost your Owner's Manual for your Garmin Nuvi 1350 GPS?
Would you like a digital copy of the Garmin Nuvi 1350 Users Guide for easy searching of terms and quick reference?
The Nuvi 1350 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
Tip
Garmin Nuvi 1350 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
on May 15, 2010 | Garmin nuvi 1350 Car GPS Receiver
Tip
Garmin Nuvi 1350 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
I hope that helps.
Tip
Garmin Nuvi 1350 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1350 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Tip
I hope that helps.
Tip
I hope that helps.
Tip
I hope that helps.
Garmin nuvi 1350 Car GPS Receiver Logo
787 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
