Question about Whirlpool Duet GHW9150P Front Load Washer
Washing machine i have a washer/dryer single unit with the dryer on top. the dryer works but the washer wont. the water wont run to fill or anything. Plz help!
  • 101 Answers
Check the filter on the inlet holes, if that is good. Replace the water valve. hop this will help you.
Posted on Apr 22, 2008
Older maytag stackable washer and dryer combo washer fills , washes and spins but water wont pump out
check for the pump belt broken or off,clogged pump or sock or small item clogging the tub outlet to pump hose. the pump pulley may have become loose on the shaft also
Feb 28, 2013 | Maytag LSE7806A Top Load Stacked...
Kenmore washer wont do anything but fill with water
Possible that the program controller unit is a suspect. you need to check the voltage to confirm the case. remove the inlet valve and check. check the warter level sensor as unless it triggers the motor will not start.
Jun 11, 2012 | Kenmore 22422 Top Load Washer
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Kenmore stackable washer wont work on Cold cycle only hot water
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine2_bing.gif Problems No Water
Washing Machine Fix Washing Machine No Water
May 07, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washing machine keeps filling and draining at the same time and wont fill enough to move on to the next cycle
The drain hose is too low and the water just runs right out...The highest point of the drain hose needs to be higher then the top of the washer before it goes back down into the drain. Also if the hose is sticking into water it can create a siphon which pulls the water out of the washer... make sure that you also have an air gap...
Mar 10, 2010 | Frigidaire FGX831C Top Load Stacked Washer...
Machine fills but wont do anything else
try the Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse. or your motor coupling could have broken!
Jan 09, 2010 | Washing Machines
Washer doesn't work and the water doesn't come on.
Check the water valves work, fill then wash, then drain then spin, if it doesn't fill it won't wash
Nov 12, 2009 | Maytag LSE7806A Top Load Stacked...
Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
Won't do anything
no, you need a lid switch. when the switch fails it wont do anything but fill. replace switch to fix problem
Nov 18, 2007 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Duet GHW9150P Front Load Washer Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal De
