Question about Mitsubishi WD-62531 Projection Television
Picture is dark
I have a 62 WD-62531. The picture seems really dark. I have to manually raise the brightness to max to get a decent picture.
  • 1,557 Answers
The problem is that the lopt is loosing power this can be due to a leak. in it there fore you will hear a hissing sound or the lopt is simply past its time. and will need to be replaced ( the lopt is a unit that sends power to the screen or in this case the globes the less the power the duller the picture)
good luck hope this helps
Posted on Jul 12, 2010
On my WD-60C9 60 DLP HDTV the picture is really dark, colors are still ok but the entire picture is dark
Have you tried changing the brightness and contrast with the picture controls? If that doesn't solve the problem, it's possible the lamp box and lenses in front of the bulb need cleaning.
Feb 20, 2017 | Televison & Video
Mitsu wd 62531 colors are rather dark. Any solutions
check you brightness level , if that does not fix it it sounds as if you may need to replace the bulb, you can get just the bulb or bulb in housing, if you are the least bit handy save the money and just buy the bulb, be sure not to touch the front of the bulb as oils on your skin can damage the new bulb or at the least shorten its life, this is easy to do just fallow the directions in your manual
Jun 15, 2011 | Mitsubishi WD-62531 Projection Television
I have a 62 inch mitsuibishi dlp you hear the sound but the picture is off were can i buy a wd-62531 lamp cartridge
Hi
Thanks for using FixYa. You can buy the lamp from this link:
Mitsubishi wd-62531 Parts
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 25, 2010 | Mitsubishi WD-62531 Projection Television
Tv has picture but it is dark with settings set to brightest settings
First thing to do id replace the lamp. If that doesn't help then the light engine needs replaced.
Dec 09, 2009 | Mitsubishi WD-62531 Projection Television
Screen discoloration
try going to this link - http://www.retrevo.com/support/Mitsubishi-WD-62531-TVs-manual/id/564ag724/t/2/ all tips and tricks in troubleshooting your HDTV you may find it here. Hope this Helps...
Nov 03, 2009 | Televison & Video
Mitsubishi WD-62531 Replaced lamp 2 weeks ago. Red light flashing again. Same problem but the lamp is fine. Sound but no picture.
You have either a bad ballast (it powers the lamp) or a bad DMD board. Either one of those will result in a no lamp fire issue. Have a technician look at it...
Oct 17, 2009 | Mitsubishi WD-62531 Projection Television
WD-62627 dark pic, contr. and bright. @ full..newer bulb.
You could try to INITIALIZE the tv by doing the following:
1) turn on TV
2) from the remote press MENU 2,4,7,0 then ENTER
3) TV will state that is INIATIALIZING
4) press the RESET BUTTON on front of TV.
5) hopefully it's fixed.
Sep 20, 2009 | Mitsubishi WD62627 62" HDTV
Mitsubishi WD-62531 Projection Television Logo
248 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
