Question about HP Compaq Presario V2000 Notebook
Compac v2000 my computer turned off one day... i dont know.. why i try to turn it on it says safe mode safe mode... safe mode.... last good configuration and start as normal i tried all of them they take me to a blue screen that only stays up about 5 seconds. its not up long enough for me to read it i dont know what to do. help!
  • peterpark Apr 20, 2008
    I had a same problem. It began this morning. When the battery out, I connected the AC adapter to an outlet. Then, it continued starting, down, starting, down, on and on....
    I called the customer service and paid 49.99 for one time service in the hope to save my data saved there...their answer is only "reinstall"...
    Please let me know if there is any way to save the data even though I reinstall Windows XP.
    Thanks in advance.
    Problem Solver:
  • 14 Answers
Only other time I have had this problem when I cloned my v5000 hd and I had a error on resizing the partition. I was moving it to a larger hd. It would do the same thing.
There are some data recovery applications so long as the install has not overwritten those sectors however they are not free.
http://www.windowsdatarecovery.com/ is ok but I have never used it after a reinstall only a bad partition becoming corrupted.
Posted on Apr 22, 2008
Starting up computer
u can do two things....1) either restore the system to some previous day when it was working fine..2) or go to safe mode and boot with last known good configuration..
Jun 10, 2009 | HP Compaq Presario V2000 Notebook
My HP Pavillion slimline won't get out of "start up repair"
Re-boot, keep on tapping F8, enter in, choose
"last known good" there, leave to re-boot,
Or
re-boot, F8 again, safe mode this time,
System restore then once booted into safe mode.
restart it.
Regards.
Apr 07, 2009 | HP Compaq Presario V2000 Notebook
My computer wont boot anymore
Try going into safe mode by hitting F8 upon startup. If it lets you get into safe mode then choose "Last Known Good Configuration" on the menu. If that does not work then let me know, there are a couple of other choices.
Mar 19, 2009 | HP Compaq Presario SR1303wm PC Desktop
My Compaq Presario V2000 will not start.
Ok, this makes sense. If this was a legit dvd, then it most likely had extra content on it (like wallpaper, sounds, etc) that installed something that crashed a driver.  If it wasn't legit, then the "player" that was used to play the movie installed something that crashed a driver.
If you can. I would reinstall some drivers to start.  Have you tried the "Last known good configuration" option?
Then if reinstalling drivers doesn't work, I would just restore the Windows OS.  But remember to BACKUP YOUR FILES.....once you restore it will be erased.
That compaq is a good machine unless you really want another PC this is fixable.
Feb 15, 2009 | HP Compaq Presario V2000 Notebook
I want to install xp on existing vista,also wanted to remove vista on hp dv2000 labtop
If Vista it is working well on Safe Mode, you have to check it out what is going wrong there instead of downgrade the system to XP.
Remember: Which was the last program that you've installed?
When was the last time that the system started normally?
You can try uninstalling the last programs
Also clean the computer and be sure that your pc is not virus or spyware infected.
Nov 07, 2008 | HP Compaq Presario V2000 Notebook
Laptop compaq v2000
This is called the Blue Screen of Death (BSoD), as scary as the name sounds if your laptop isn't ancient you more than likely can save it. depending what you were doing on your pc last, installing a game or whatever, start it in 'safe mode'. it should start up just like a normal computer but with a few changes like anti virus disabled. From here you can unistall whatever you were last doing on the computer, clean it up and try get her running again, the usual stuff, try defrag the computer, right click the drive in my computer>tools>defrag now, theres also other options in there like clean up and error checking both will help. Try and save it yourself, if all this fails your computer fixing person will probly have to wipe your hard drive, in which you will loose all your data and start a fresh laptop.
It would also help to know what you last did on it, on the net? downloading stuff? installing something?
Aug 17, 2008 | HP Compaq Presario V2000 Notebook
Dell compter shutting off
The problem is the NT user file on your computer has got corrupted. Since you have already tried restarting your computer a couple of times Last know good configuration feature of Xp would not work
Steps you can take :
When you power on the system and dee the Dell logo, tap on the F8 key slowly 5-8 times , you would see windows advanced options menu.
Select Safe mode and hit enter .
In case the system goes into safe mode , try doing a system restore .
Otherwise u need to repair windows through the disks that Dell might have sent you.
Apr 12, 2008 | Dell Inspiron 1100 Notebook
Help my stupididty.
try last known good configuration.
Jan 29, 2008 | Sapphire RADEON X1650, (512 MB) Graphic...
After turning it on it reads "press f1 to resume ;f10 to set up"
Hi I'm sorry, what is the message it shows? If it says "press F1 to continue" then do so, hit F8 and try "safe mode"
Really need to know what the message is.
Good luck
Dec 20, 2007 | HP Compaq Presario V2000 Notebook
Windows XP fails to load and Computer will not start up.
Boot from startup floppy disks or CD-ROM, choose repair option during setup, and run Recovery Console. When you are logged on, you can run FIXMBR command to fix master boot record. This should solve your problem.
Sep 20, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
44 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
