Question about Makita 10" Miter Saw LS1030N
Hi I hae a Makita Drop Saw and changed the saw blade but can't get the safety cover back on.Can you please email intructions to vjlomsargis@hotmail.com Its an LS1045 MODEL 1650WATT thanks
  • 271 Answers
SOURCE: how do you ulock the saw to pull up the blade so you can put the wood underneath to cut
push down gently on the arm and reach around to the rear of saw with your right hand and pull retainer pin the arm should release and allow usuage of your saw.
Posted on Oct 24, 2008
jyackle5
  • 8197 Answers
SOURCE: Makita 10" Compound Miter Saw LS1040 manual?
Here you go.
This is the ls1040
http://www.makita.com/en-us/Assets/images/Products/LS1040/owners_manuals/LS1040.pdf
This is the ls1040f
http://www.makita.com/en-us/Assets/images/Products/LS1040F/owners_manuals/LS1040.pdf
Posted on Mar 12, 2009
VtToolMan
  • 704 Answers
SOURCE: Unable to lift the saw blade Makita Miter Saw
Look at the pivot point on the rear of the miter saw for the push/pull locking pin. The pin is there so you can lock the saw in the down position for easier carrying. To unlock the saw, simply pull the locking pin out (Makita calls this the "stopper pin"). Then you can use the saw and easily raise and lower it for cutting.
As you might find it helpful to have, I have included a link from the Makita web site for a free copy of the owners manual that you can print or save for future use and reference. It has some handy info on use and care of your saw.
http://makita.com/en-us/Assets/images/Products/LS1030N/owners_manuals/LS1030N.pdf
Hope you find this Very Helpful and best regards!
Posted on Sep 20, 2009
fisherman816
  • 66 Answers
SOURCE: blade stuck in makita 4351 jig saw cant remove
Take the set screw that holds the blade all the way out.
Then take a ice pick or small flathead screewdriver and work the broken blade out.
Posted on Nov 07, 2009
rowdy45176
  • 2176 Answers
SOURCE: how do I install the spring after changing the
what spring? do you mean the one in the guard? if so you don;t have to remove it to change the blade, give me the exact model number or you can go to makitatools.com and download a breakdown that shows the reassembly of the guard, it is not that hard, and also you can download an owners manual that shows the proper blade replacement procedure.
Posted on Jan 19, 2010
What is the spring for in the 2000w makita circular saw
Other than carbon brush springs, the only other spring that I know of on a circular saw is for the blade guard so that it will automatically return to cover the blade after you make the cut. There should be a hook or a bend in each end of the spring and each end has a certain spot where it hooks so that it pulls the blade guard back in place.
Jul 13, 2014 | Makita Saws
Change blade Makita LS1030 10-Inch Compound Miter saw
There is an 8mm bolt on the front of the guard. Loosen/remove this and the central guard mount will drop slightly. Behind the metal guard is a slide lock for the blade spindle. Push the lock bar and turn the blade untill it catches and is held solid. Then remove the blade fixing bolt and bobs your uncle. Alternativly, with all mitre saws, you can just pop an old bit of wood on the work base and then use the spannrer/allen key supplied to turn the blade so it bites into the wood as if you are trying to cut it. This will hold the blade steady and you will also be turning the bolt in the right direction.
Jul 23, 2012 | Makita 10" Miter Saw LS1030N
Any guard blade for a saw miter
Yes, Did you buy it new? It has two heavy plastic seen through plate that are attached to each other. This safety shield is gravity fed. That mean as one pull down the saw the safety guard will pivot into the upper shield. As the saw go back up after cutting a piece of wood. The safety shield will drop back into it safety position covering the 12" blade. GB...stewbsion
Aug 23, 2011 | Bosch 12" Dual - Bevel Compound Miter Saw...
How do I replace the blade guard on my 10" Makita
If you want to replace the plastic cover there is a screw towards the front of the saw that must be removed and then the bolt at the back loosened and the guard will pull off. If you need more info get back to me with the other questions and I will try and help
Jul 10, 2011 | Makita 10" Miter Saw LS1030N
How do I assemble the blade guard for my Makita Miter Saw Model LS1030? I accidentally disassembled the guard it when changing to a new saw blade. I cant figure out how to get the tension spring back in...
lay the spring into the plastic safety cover, you will see a catch for one portion of the spring, the cover plate goes over it and there is a tab on it to catch the loose end and then the center plate which screws on to hold everything in place, check by turning the plate that holds it onto the saw for free movement. You can go to makitausa.com and in the header area on the right type in your model number ls1030n and you can download or look at a breakdown to see what I am talking about. Let me know if you need more assistance, just found your question.
May 01, 2011 | Makita 10" Miter Saw LS1030N
While replacing the blade, the spring on the safety cover came off. I can`t figure how it goes, to place it again on its place. Any advice? Thanks Emilio
Hello. Here is the link to the Parts Breakdown of your unit. It should show what you need to know to reassemble your saw. If not, use the contact information to speak to customer service and they should be able to assist. If this is helpful, please rate it a four-thumbs up, Thank You.
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=370
Apr 05, 2011 | Makita 10" Miter Saw LS1030N
How do I change the blade on my Makita MLT100 table saw?
take the top cover off where yr blade is, make sure blade is in the highest position, take the 2 wrenches it came with and undo the nut.
May 19, 2010 | Garden
The spring for the blade cover has come off how do you fix it? my dad has given me his saw to fix the spring that brings the blade safety cover around, how do you fix it the the mounting post. When I do...
if it a Makita saw it will rub on the guard slightly, What is the model number or you can go to Makitatools.com and type in your model number to see a breakdown for this tool. The post is on the back side of the upper guard and there is a hole in the guard itself for the other end.
Oct 03, 2009 | Makita Saws
Replacing the saw blade
my husband had trouble replacing the spring that goes in the plastic safety cover....he just eliminated the spring and it works just fine...thankyou for responding....L Martinez
Sep 27, 2008 | Makita 10" Miter Saw LS1030N
Makita 10" Miter Saw LS1030N Logo
56 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
