Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE PSS26NSWA SS side by side and the ice maker is not working properly. Water comes in and makes ice but it will not dispense into the bucket. if i put it into diagnostic mode the ice dispenses the one time. The ice maker refills with water and again makes ice but it will not dispense again unless you put it in diagnostic mode again.
  • 26 Answers
SOURCE: Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Posted on Mar 18, 2008
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Posted on Dec 19, 2008
SOURCE: water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Posted on May 22, 2009
  • 19 Answers
SOURCE: water dispenser not working ice maker is fine
The refrigerator has a dual water valve. The water dispenser side of the valve may be defective, but, my experience has shown the problem to be in the water reservoir, located in the bottom of the fresh food section, which, might be frozen or the water line through the freezer door is frozen. Scenario #1: Remove the kick panel, disconnect the water line from the fitting. Have someone depress the water actuator, while, holding a cup to collect any water which may come through the line. If water comes through the tube. The problem is a frozen water line in the door. My best advice for this problem is to remove any frozen goods from the door. Take a piece of cardboard and seal the freezer section of the refrigerator with any kind of tape. Make sure you tape the door switch in the closed position, so, the refrigerator will continue it's normal operation. The frozen goods will remain frozen and the fresh food section will be okay. Leave the freezer door open. You might want to put a towel under the door. The water line will thaw. It might take 15 minutes. It might take 3 hours. Periodically check the water dispenser operation. When the water flows remove the cardboard. Scenario # 2:if, after disconnecting the water line and depressing the water actuator there is not water. The reservoir is frozen. Use a hair dryer to that the reservoir. You will have to remove at least a couple of crisper drawers to perform this action. The cause of a reservoir freeze is too little stuff in the drawers or too low a temp in the crisper drawer area.
Posted on Jun 18, 2009
SOURCE: Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Posted on Jul 30, 2009
Why is my GE (ZFSB23D SS) side by side refrigerator leaking at the back corner, near the rear wheel where the plastic water line goes in?
If the tubing is plastic it could have cracked when you moved the tubing to install the filter. If the tubing is OK then possinly the filter isn't all the way in or is leaking.
Jul 31, 2014 | Refrigerators
Ge profile refrigerator leaking water from bottom when pressing dispencer
The water dispenser tube is getting leaked form in between or its got loose from its actual line.Inspect water dispenser tube from water valve to the end of where the water is getting dispensed.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ge side by side water will not come out of door dispense
The water switch went bad or the water valve. Switch the two wires on the water valve on the back of the ref. Press water switch on door if water fills ice maker valve is bad,if not,door switch is bad.
Jan 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram ZISS480DMCS Ice Maker Problem
i would first check water supply to ref. measure the resistance of coil either open or resistance. if all this is ok then exit side of line needs to be checked for water.
Sep 22, 2008 | GE Monogram ZISS480DRSS Stainless Steel
check to see if your on/ off switch is green on the im 1st. 2nd make sure that you have properly seeded the dispenser tray by using the cross method. the auger arm at the back of the tray turn vertical and the auger mtr gear in the rf turn horizonal then insert the tray in the machine
May 31, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Check and make sure that the float arm in the ice bin is down and able to swing. This arm should be down until the bin is full of ice which would raise the arm and stop any water flow until ice cubes are removed, and allows the arm to drop again to start the cycle all over again, to replace the ice that was used. The arm has a spot to snap in and be held where it would be in a position all the way raised, to allow the bin to come out for cleaning or all of the ice removal from the bin, such as to dump the ice in a cooler. The arm should be gently pulled down to hang freely and will slowly raise on its own as the bin fills with ice.
Jan 02, 2008 | GE Monogram ZISS480DRSS Stainless Steel
GE (PSS26MSRSS) Side by Side Refrigerator Logo
299 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
