Question about Aiwa AV-S17 Receiver
My receiver is stuck on Eco mode, can't even turn the receiver on in order to get to Multi jog to turn eco mode off. What specifically do I do?
3 Suggested Answers
SOURCE: AV-S17 - Clock Display won't stay on?
Check the internal memory battery if there is one, then reset the sleep setting? Check the manual regarding memory back up.
Sonic Doctor
Posted on Mar 28, 2009
SOURCE: AIWA AV-D58 receiver ECO problem
Hi, I've found the problem. There was a closure in the Sorround Amlifier, and the protect circuit stopped the whole receiver. Br., csdombi
Posted on Jan 07, 2010
Honda 3000is runs great on eco but hesitates and either stops the load source or stops running itself when under load.
Sounds like the throttle control motor is not adjusting the engine speed to compensate for the load. Does the generator rev up to full speed if you turn OFF eco with NO load?
Funny thing, I have one on my workbench that is doing pretty much the same thing. Runs on eco, revs up with eco off with no load, coughs, sputters and dies with a load in either mode. I will update with what I find when I figure it out in the next week or so. Have a new carb on order.
I swapped the carb and it made no difference. Still backfiring (rather dramatically) and won't stay running. I see on some other posts that Valve lash will cause this. It makes total sense as the exhaust valve gap actually tightens as the engine wears which would keep the exhaust valve slightly open when it ain't supposed to be allowing raw fuel to enter the muffler.
With this one I can believe it as it has a ton of hours on it and I know they have never been adjusted.
I will try to get a chance to do it over the weekend and update this post when I do.
Apr 01, 2015 | Honda EU3000iS Inverter Generator
My kyocera rise is stuck in eco mode and my screen won't come on
In order to help, I need to ask you some questions. Did you tried to disable ECO mode and after that there was no change to the quality of print? Or you don't know from where to change this setting? Which screen "won't come on"? Do you refer to the printer display or the PC one? You can disable ECO mode directly from printer driver, from Printing Preferences.
Jan 23, 2015 | Kyocera Office Equipment & Supplies
How do I turn on eco mode for toyota camry 2012 hv ?
Check your fuses in the fuses, box especially the relay.
Jan 22, 2015 | 2012 Toyota Camry
Peugeot 206 eco mode problem
please visit an alarm shop for reprograming.
Jul 13, 2012 | Peugeot 405 Cars & Trucks
How do i turn off eco mode in panasonic cordless
You cannot turn off the ECO mode manually.
Intelligent ECO mode (select models)
Power consumption is automatically reduced when the handset is close to the base unit for extended talk time. Battery life on Talk is up to 13 hours when in ECO mode.
https://panasonic.ca/english/telecom/telephones/features.asp#eco
Jun 25, 2012 | Panasonic KX TG4021 Cordless Phone
I have an AV-S17 and it's stuck on eco mode. I have tried doing what the form has said for me to do and it doesn't help.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Aiwa-AV-S17-Receivers-manual/id/1076ag804/t/2/
Page 7:
To cancel the ECO mode
1 Press the ECO button to display ECO MODE while the unit is turned on.
2 Within 4 seconds, press the ENTER button.
3 Within 4 seconds, turn the MULTI JOG to select ECO OFF.
The mode will be automatically set after 4 seconds. It will also be set if the ENTER button is pressed within 4 seconds after step 3.
Mar 29, 2011 | Aiwa AV-S17 Receiver
HOW DO I TURN OFF IDLE STANDBY
That should be in your Menu under Power Settings or Options.
Dec 02, 2010 | Sony Televison & Video
My Aiwa cx-nma545 keeps turning off.
Your system is in 'Eco' mode. If you are in this mode, and go 10 minutes without playing a CD or cassette, it will automatically turn itself off.
Here's how you get out of 'Eco' mode:
1) Go to the jog wheel assembly
2) Press 'Eco'
3) Press 'Enter'
4) The display will show "Eco Mode On"
5) Immediately turn the jog wheel, to turn the status from 'On' to 'Off'
Feb 08, 2010 | Aiwa NSX-DS55 CD Shelf System
I cannot set the date on my Citizen SkyHawk Eco-Drive
Just pull the crown out, turn it so that the bottom analog display is set on "CAL" and push crown back in. Voila!!
Mar 16, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Won't come out of eco mode
if the receiver is on, you can press the "Eco" Button and then, you have to rotate the "Multi-Joy" in the next 3 seconds to change Eco-Mode to Off. When you selected it, you have to confirm with enter.
Aug 13, 2008 | Aiwa AV-D58 Receiver
Aiwa AV-S17 Receiver Logo
305 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
