Question about JVC Televison & Video
It will not record color in vhs or svhs.
JVC H-RS 7300 It will not record color in vhs or svhs. No chroma on record. Playback color OK
  • JVC Master
  • 17,130 Answers
It is the failure of the chroma processing IC that works with a biasing when the recording is activated. Failure of this frequency which has to be generated within or around these circuits wil result in the colour signals being out of sync. You will need a good signal trace with an oscilloscope to get to the real issue. I believe you will need to bench test this to get to the final point of trouble. You can check for head cleaning,resolder the joints of the chroma section, solderr any section looking mushy. hope this helps. Good day
Posted on Jul 15, 2010
How do I copy(to DVD) my SVHS tapes using my JVC MV-40
It all depends on what kind of connections you are using. In most cases you set the dvd recorder to input 1. Then use the yellow,red & black or white out puts from the vhs player to hook up to the number 1 input on the dvd recorder. hit play on the vhs & record on the dvd recorder at the same time. Do not forget to put a blank dvd in the dvd recorder? also for the best copy set your dvd recorder to XP for a 1 hour recording for a 1 hour or longer recording set the dvd recorder speed to SP. You should have the dvd recorder hooked up to a Tv so you can monitor the recording progress. This should work out as long as the recording you are copying is not copy protected. Good luck.
Feb 07, 2015 | JVC Televison & Video
I bought a panasonic cassette adaptor for my vhs-c tapes . it says svhs adaptor on the front of the box .will the ordinary vhs-c tapes fit in it and does the door open on the front or is it loaded from the...
You don't specify the adapter you have, but most load from the top. The main thing here is that VHS and VHS-C are both the same size of tape. Whether they are recorded in SVHS mode or not will not affect the adapter, just whether or not you get a picture. Theadapter only allows you to put a compact cassette (VHS-C) into a standard VHS VCR. The adapter will require batteries to allow it to place the VHS-C cassette tape into the proper position for use in the VCR.
Dan
Nov 24, 2010 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
VHS to DVD recording
OK connect the AV Out Yellow, Red, White, OR SVHS, OR SCART, from the VCR, connect these leads color to color to the DVD's AV whatever, IN.. Press Play on VCR, and "Record" on CVD that should do it.
Jan 31, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
SLOW DOWN PLAYBACK MODE
You cannot play SVHS tapes on a standard VHS machine. Your solution is to either:
1. Buy an SVHS Home unit (not a great idea)
2. Use regular VHSC tapes in your camcorder (these will playback fine in your existing home unit).
3. Hook your camcorder directly into your TV and use the camera as a playback device.
May 02, 2009 | Televison & Video
We bought the new high definition digital t.v.
Yes of course there is, you can buy dvd recorders, or Hard drive recorders or just a normal VCR
Feb 24, 2009 | Samsung DVD/VHS/MP3/SVHS Playback
JVC HR-S7600U VCR. Playback issues with VHS & SVHS tapes.
super vhs tapes has an extra hole on the side where you lift the flap to see the tape the pin inside the machine must be stuck.I have had no problems with this as i have jvc super vcr s as they are great machines also take the lid off and clean the heads around the drum see how you go.
Jan 25, 2009 | Pioneer VSX-D710S Receiver
Recording tv from a vhs player
sound like you have a dirty video head, try cleaning the head with some isopropyl alchol. if it does not fix your problem, then you will have a bad video head. good luck
Feb 15, 2007 | Samsung DVD/VHS/MP3/SVHS Playback
No chroma on playback
Bad heads may produce a loss of color in playback. If you have a spare head, swap it out and confirm this.
Nov 15, 2006 | JVC BR-S822DXU VHS/S-VHS playback VCR
Jvc 200u problem recording to vhs video tape, from camcorder
Yes, if the camera is a US camera then it is NTSC. That would be your problem, you are trying to record an NTSC signal to a PAL video. THe frame rates and resolutions are all wrong. I am even surprised that it is playing back on your TV okay...
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Televison & Video Logo
194 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
