Question about T-Mobile Dash Smartphone
T mobile dash turns off
After a 24 hour charge, I began using my tmobile dash. Ive had it for two full days, and both days, at about 11pm the screen just turns off. Both times i took it out of my pocket, pressed the button to bring up the screen to unlock it but the screen would not turn on. I pressed every button but nothing would turn it on. The light still blinks as though its still on though. My initial thought was that it hibernated at night to save power, but now that i found nothing of that sort on my phone applications it leads me to believe thats not the case. is it defective
  • infinitwrx Apr 19, 2008
    btw, i got it working both times by taking the battery out and putting it back and restarting the phone
  • Anonymous Mar 11, 2009
    It does not matter if the battery is fully charge, the cellphone turns off in a middle of a conversation all by itself!
Suggest that if you got the phone through T-Mobile, return it and get a different brand altogether.
I have been having the same problem with my phone which I have had for about 14 months and since it is out of warranty, there is nothing that can be done. Suggestions from getting a new battery to getting a new charger have been made. I have replaced battery and charger and still no fix. To use, I have to be plugged in at all times. I am faced with having to buy a new phone.
Posted on Apr 20, 2008
Purchased Norelco shaver 7810XL. Instructions state to charge for 4 hours prior to first use. Green lights began blinking, indicating full charge, after less than 2 hours. Do I continue charging after...
Simply follow the instructions and charge for a full 4 hours the first time. On subsequent charges, unplug when the light blinks after about 1 hour
Dec 26, 2010 | Norelco Health & Beauty
I have ge model 15119 24 her timer and need help on how to set
GE 15119 timer is a 24-hour plug-in dial-type timer.
Dial rotates as time passes.
Plastic segments located around outer edge of dial control on-off operations.
Each segment represents 30 minutes of 24-hour day.
Timer comes with segments down.
Each segment can be lifted up using small screwdriver under edge of segment.
Segments down, timer is ON.
Segments up, timer is OFF.
So if you want timer to turn on at 7pm and turn off at 11pm, then lift all segments around dial except segments between 7 and 11.
Dial is divided into two parts > day and night.
Nighttime hours are shown by numbers with dark background >> notice small crescent moon where 12 midnight is located.
Daylight hours are shown by numbers with light background, and sun symbol shows at 12 noon
To set current time, so timer knows what time it is right now:
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
There is override switch located on one side of timer.
Move switch to Timer ON position and timer program will function.
If you want to turn lights ON using override switch, move switch to OUTLET ON.
Last steps:
Turn lamp on.
Plug lamp into timer.
Plug timer into wall.
Dec 01, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Clock is set properly. I want to turn on outdoor lights at 5PM everyday. In addition I want to turn off the lights each night at 11PM. Problem - When I go thru the process of turning on the lights it...
I answer questions for free.
I know timers and electrical devices, and have tested most of the brands.
You posted under the Woods 7-day timer 59018 or 59028.
Here is the manual:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
There are several programmable timers today that look like Woods, and each brand has different programming.
If you do not have Woods, add a comment and I will walk through programming your brand
1) You have the clock set correctly which implies the wiring is correct. Good job!
2) Programming review:
Each program requires ON time to be set, and then OFF time to be set
For example you set Program1 ON 5:00PM for ALL days.
And then you set Program1 OFF 11PM for ALL days.
3) Programming steps:
Press PROG button until Timer 1 ON appears on display
Use Hour button to set 5 PM
Use MIN button to set :00
Default selects ALL days
(If you want other days, press DAY button until display shows correct block of days)
Press PROG button again to save Program1 ON
4) Now for Program1 OFF
5) To set Program1 Off
Press PROG button until Timer 1 OFF shows in display.
Use Hour button to set 11 PM
Press PROG button again to save Program1 OFF
6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time.
If you want to set another program, press PROG button until Timer 2 ON displays
7) After setting programs, press Clock button so current time shows.
8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
If you need more assistance, add a comment.
If instructions help, give it a 4-thumb
Nov 10, 2010 | Woods InWall 7 Day Digital Programmable...
Bought a replacment battery for A30 and charging indicater does not show battery is charging
Im not sure what you are asking but I will try anyway.
You just want to see when you are charging?
Does the computer work when the charger is disconnected?
Most new batteries require hours to charge before they give any function.
How long will depend on the battery and charger. See the manual.
My battery took 2 days and I was angry. (24 hrs the manual said)
I put my wifes charger on and it began to function.
After that, my charger worked but not before...
Let it charge for 24 hours. Then see what happens.
Mar 16, 2010 | IBM ThinkPad A30 2652 Notebook
Creda Night Store Heater model 79154
The dial on the wall with 1-24 on it, with the red pins, is the timeswitch to turn the heater on for night-rate hours (when the electricity is cheapest). Hour 1 is 1am --> Hour 24 is midnight.
Set the red pins to turn the heater on from 11PM (23) to 7am (7). The 'on' symbol is normally a '1', with off being '0'. Otherwise, on can be symbolised with a staright line with circles on it, while off is like a little barrier-arm part up.
As for the knobs on the heater, one is for the amount of heat which goes in (how much the heater 'charges'), and the other is for how much it lets out.
Genrally in winter you set the input (nite-store, second knob) to full (6), but in spring or autumn you may reduce this as required.
The other knob (room temp) is for how much heat comes out of ther heater. If you work during the day, you will want to conserver the stored heat in the heater.
Turn the room temp knob down to about 3 when you leave for work, and wind back up to 6 when you get home. This will stop all the heat leaving the heater during the day (and maybe use less power to recharge at night).
Good luck with the time switch. Check your night-rate hours on your power account.
Apr 03, 2009 | Heating & Cooling
Tmobile dash Battery or sim?
I tried the new battery and thought it worked and posted it to this site...and, after about 30 hours the same thing happened. It's either the phone or the software, but, since the problem began 15 months after I bought the phone, I tend to think it's the phone, not the battery or the software. I'm going to try to contact HTC since T-Mobile is useless.
Feb 06, 2008 | T-Mobile Dash Smartphone
S-750DD
Not sure if this will help... however an altmeter will allow you to test along your electrics for any faults. You can check at the lights for example and throught the system.
Oct 11, 2007 | Transport Schwinn Rechargeable Portable ...
Tmobile Mda Wont Turn On
I would call them at 1-800-t-mobile to make sure your service is set up correctly (if it isn't it may explain why it takes so long to locate the network) or you could use their customer care site at http://www.t-mobile.com/Contact.aspx to find a store that will replace/repair it for you.
Oct 13, 2006 | T-Mobile MDA
T-Mobile Dash Smartphone Logo
102 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
