Question about Acer Aspire One PC Notebook
Both mains and battery power OK with green power light on but nothi8ng happening...blank screen. Can hear hard drive working.
    Sniper:
  • 78 Answers
There may be a pinched wire somewhere or a soldering joint that melted away, thereby cutting the power off to the monitor. If you can't take apart the laptop by yourself, bring it to a technician. If you choose to get rid of the laptop, remember that you can connect a standard monitor cable to it, and bypass the laptop monitor altogether.
Posted on Jul 12, 2010
HP Compaq 6735s Laptop screen was blank when turned on
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Mar 26, 2012 | Computers & Internet
I have 10 months old Toshiba Satellite 555L laptop. Recently upgrade RAM to 8Gb. Problem: when starting laptop I have 3 green lights on and can hear working sound, however screen doesn't starting and stays...
Try running with one memory stick in. Presume you are using 2 x 4gb sticks. I wonder what "A Working sound" is? Does the hard drive sound like it is booting? Do you see the HDD light flashing? When you removed the memory cover did you accidently knock a cable loose?
Remove the battery with the mains unplugged and wait ten mins. Put the battery back on and see what happens.
Apr 23, 2011 | Computers & Internet
Nothing comes on picture blank
Ok
A few things to try
1.) Check the laptop on an external monitor, do you get a picture
2.) Is there power to the laptop from the battery and the charger? Try to see if the charger indicator lamp is blinking green rather than steady green
3.) Can you hear hard drive / fan noises and are there any lights on the laptop?
If the charger is blinking, indicates that power is not making the circuit, check tightness of charging port, if tight, assume fault on motherboard / blown main fuse
If picture on external monitor and not on laptop, assume backlight on screen dead or possibly the inverter
If no noises from HDD or Fan and No lights on laptop, then fault with motherboard
If you do get fan noises etc, but get BLINKING lights on laptop, assume possible fault with graphics chip, repost with details of blinking lights / colour and specific model of laptop
Jan 12, 2011 | Samsung Computers & Internet
With the laptop plugged into the power cord, pushing the power on button only illuminates three small green lights near the power button and the screen remains blank. Removing and replacing the battery...
Reseat the ram. Listen to see if the hard drive is engaging. If you hear the hard drive try replacing the cmos battery. consult manual for location of battery. I've replaced a couple in different models recently this fixed Them all. They use some cheap battery that didn't even test to 3.0 volts. Good luck
Jan 25, 2010 | Sony VAIO Notebook
Completely blank screen when power is on.
do a hard reset....remove charger>remove peripherals>remove battery> press and hold the power button for about 30secs, while batt and charger is removed> then plug in the charger only and turn ON!
Please vote, thanks!
Jun 27, 2009 | Acer Aspire One Netbook 8.9" Notebook
I have no POST or screen power when I turn on the laptop
Try this.
Remove the main battery and power the laptop up - if it works connect the battery - no need to shutdown.
Next thing to try.
Remove the main battery and the BIOS battery wait 1/2 + hour, insert BIOS battery but not main battery - power up, configure BIOS Date & Time setting if OK connect main battery.
If none of this work, you have a large paper weight.
You can salvage the hard disk and insert it into an USB hard drive adapter case and use it as an external USB hard drive.
Apr 14, 2009 | Gateway M285-E Notebook
Compaq c500 blank screen, can heard hard drive running
You should replace the power supply, and clan out dust, and tighten connectors
Mar 11, 2009 | HP Compaq Presario C500t Notebook
Computer wont boot
Try disambling the system. Clean it with a wind blower. Check BIOS battery capacity. Replace if possible. Power on the laptop. Do you hear humming sound from hard disk ? If you hear sssssssshhhhh sound from hard disk; it's OK. Replace RAM with new one. If problem still exists Than change main board. Hope that not happen. Keep informing.
Feb 02, 2009 | Compaq Evo N1020V Notebook
HP dv6000 screen is blank
Video chip failure on the main board join the hundreds with the same problem need a new mother \Board and it may still happen again to that one
Dec 09, 2008 | HP Pavilion dv6000z Notebook
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
