Question about Microwave Ovens
Spacemakerxl microwave jvm1410 will not heat - Microwave Ovens
  • Anonymous Mar 26, 2009
    suddenly will not heat
  • Microwave Ovens Master
  • 9,086 Answers
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 23, 2008
Solution-GE spacemakerXL microwave oven model:JVM16505H01 mfg.date:feb.2005
Sounds like you have a bad smart board, you can try unplugging the unit for five minutes and then back in, if you are lucky this may correct the problem...good luck
Feb 18, 2014 | GE Microwave Ovens
I have a GE SpacemakerXL microwave that stopped working after I heard a loud pop. Everything else works, but it does not heat anything. Help?
From the descriptions it likely the magnetron has failed. If you have a digital multimeter post me a comment and I will give instructions to do a rough test.
Jun 06, 2012 | GE Profile Spacemaker Over-the-Range...
GE Microwave model JVM1440BD operates but does not heat
On most occasions, it is magnetron. If you on your oven and hear an humming noise, that usually confirms magnetron problem.
You could see how to test magnetron
http://www.gallawa.com/microtech/mag_test.html
Let me know, once you test this.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 11, 2011 | GE JVM1410 Microwave Oven
I have jvm1430bd01 microwave and it stoped heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ll
Apr 10, 2010 | GE JVM1410 Microwave Oven
GE SpacemakerXL Microwave Oven
heatman101
Apr 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL Microwave oven clicking noise
Spacemaker t/t motors are very easy to change. Removed the screws from bottom of microwave. the bottom panel will found towards wall. Mtr is in very center of unit. Should have 2 wires going to it
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Everything else works but will not heat anything. Clock works,glass plate turns,exhaust fan runs, lights work, just no heat.
Im assuming you dont have testing equipment. The best solution is to replace the capacitor and HV diode. Good chance that is the problem. If no heat still, replace the magnatron, definately will work correctly.(Sorry, to much to explaine otherwise relating to measurement and values). Let me know if still notright).
Sep 27, 2009 | GE JVM1410 Microwave Oven
Microwave Ovens Logo
85 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
