Is there a way to disable the self cleaning or reduce how often so that we aren't using so much ink
  • spsaheli Jan 01, 2009
    I'm going to guess a Brother. Mine is a Brother MFC-465CN. I barely use color printing but I have to change color cartridges because of the pointless self-cleaning schedule.
  • Cnythia Miller May 11, 2010
    hello rmjackson,
    What type of printer and model?
    Thank you
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 137 Answers
In most printers you can set these functions within the control panel or Toolbox of the Printer.Provide detail regarding the printer that you use Make, Model.
Regards
Posted on Apr 19, 2008
Whirlpool self-cleaning oven: RBD275PDB14 . . . I DO NOT want it to self-clean. Is there any way to DISABLE the self-cleaning feature?
Just don't use it. The finish in the oven is made to work with the self-cleaning operation; it naturally facilitates burn-off at high temperatures. It is normally impractical to remove and replace the finish, besides, it's harmless as far as I know. If you are worried about someone accidentally activating self-clean, you could tape a coin over the self-clean button. (If you have a curious child in mind, the coin may actually draw attention to the button and invite its operation - you know better than I who or what you are dealing with.)
There is no good way to disable the self-cleaning function without replacing the controller with a custom-built and programmed unit. The button is in a matrix with other buttons, so attempts to disconnect it would disable other buttons and generate a controller error that would prevent the range from operating.
Jul 08, 2017 | Whirlpool Ovens
My printer only prints magenta\
A color or photo cartridge is either low, clogged or has run out of one of the basic colors it mixes together to create the colors in your images. The printer cannot print correctly if it lacks one of the basic colors, even if it still contains some of the other colors. The cartridge may also be clogged. The cartridge must be replaced
This may help
You can try to clean the printer head manually. To clean the printer head, remove the ink cartridge from the printer. Moisten a cotton swab by dipping it in hot water or isopropyl alcohol, and then gently wipe the printer head. Do this repeatedly until it softens the dried ink.
For models where the printer head is located in the printer, you can put 7 to 10 drops of isopropyl alcohol in the ink receptacle where the ink flows from the cartridge to the head. Turn the printer to self-cleaning mode. You can also leave it for a few hours or overnight before repeating the self-cleaning mode.
If the print head is located in the cartridge, soak the print head in hot water and let it soak overnight. Dry the print head part using a paper towel and switch it to self-cleaning mode.
If the hot water soak does not work, place the cartridge printer head in isopropyl alcohol and let it soak overnight. Wipe off the soaked area and dry it carefully using a damp paper towel. Turn the printer to self-cleaning mode to remove any dried ink.
For more Help Source... Can You Fix Dry Ink Cartridge eHow
Thanks,
HP Phone Number
Jun 25, 2014 | HP Officejet Pro L7680 All-In-One InkJet...
Pictures have lines on them and the picture is blurred
Most likey cause of this is dirty print heads. The print head is the part of the catridge that the ink comes out of.
You should be able to get the software (HP toolbox) to tell the printer to do a self-clean...otherwise you can try a manual clean below
Remove the cartridge and inspect head. If clogged with ink then you can manually clean them with a wet cloth (lint free cloth). just use water ...no cleaning solution...as ink is water based.
I would recommend re-doing the self-clean after manual clean also.
hope this helps
Sep 02, 2011 | HP PSC 1210 All-In-One InkJet Printer
Problem with printhead please consult user guide
Use the printer's utility program to self-clean the printer. This process may need to be repeated as many as 5 to 10 times. Often this will resolve the problem.
Turn the printer off, preferably overnight, if the self-cleaning utility has not worked. The ink may need to soften before the self-cleaning utility will be successful. Turn the printer on and try the self-cleaning utility again several times.
Determine from the owner's manual where the print head is located. Epson printers, for example, are usually in the printer. Many other brands place the print head in the cartridge.
Remove the cartridge. For models where the print head is in the printer, drop seven to 10 drops of isopropyl alcohol (rubbing alcohol) down the ink receptacle area. This is the hole where the ink flows into the head from the cartridge. Run a few self-cleaning utilities. If necessary, allow to sit a few hours or overnight and repeat the self-cleaning utility.
Soak the cartridge print head in hot water if the print head is in the cartridge. Allow to soak overnight. Dry the print head area with a paper towel. Repeat the self-cleaning utility.
Place the cartridge print head in isopropyl alcohol if the hot water soak did not unclog the print head. Leave the print head covered in alcohol overnight. Use a damp paper towel to wipe off the print head area. Dry carefully. Try the self-cleaning utility again.
Purchase a new cartridge if the alcohol soak did not unclog the print head in the cartridge. This will provide new print heads that won't be clogged. Contact a service technician for repair of print heads in the printer if the alcohol did not unclog the print head.
Mar 01, 2011 | Office Equipment & Supplies
My printer won't print anything - only blank pages. However, both ink cartridges have ink. Please help!
If the self-cleaning cycle does not solve the problem, try turning the printer off overnight to allow the ink to soften. Turn the printer on the next day and try printing a test pattern to see whether the problem has either disappeared or become less noticeable. This ink-saving procedure can work effectively because sometimes the dried ink on the print head needs time to soften before the printer head can be cleaned completely. Try running the self-cleaning utility again one or more times.
Steps for Manually Cleaning the Printer Head
If the overnight cleaning still does not work, there may be a layer of thick ink that is blocking the holes of the printer's head. The next option is to manually clean the printer head. Follow these steps:
* Determine from the owner's manual where the print head is located.
* Remove the ink cartridge from your printer and then dip a cotton swab in hot water or isopropyl alcohol and rub it against the print head. This should loosen any crusted ink. NOTE: Be careful, especially if you use isopropyl alcohol to clean your print heads: Some printers use rubber gaskets, and if you get isopropyl alcohol on the gaskets it could dry them out.
* For models where the print head is in the printer, drop 7 to 10 drops of isopropyl alcohol (91% denatured isopropyl alcohol - not 'rubbing' alcohol) down the ink receptacle area where the ink actually flows from the cartridge into the head. Run a few self-cleaning utilities. If possible, allow the printer to sit a few hours or overnight and repeat the self-cleaning utility.
* If the print head is in the cartridge, soak the cartridge print head in hot water. Allow it to soak overnight. Dry the print head area with a paper towel. Repeat the self-cleaning utility.
* If the hot water soak did not unclog the print head, place the cartridge printer head in isopropyl alcohol and allow it to soak overnight. Use a damp paper towel to wipe off the print head area and dry carefully. Try the self-cleaning utility again.
* If the alcohol soak did not unclog the print head in the cartridge you may need to purchase a new cartridge. This will provide new print heads that won't be clogged. Contact a service technician for repair of print heads in the printer if the alcohol did not unclog the printer head.
Jun 09, 2010 | HP DeskJet 5150 InkJet Printer
When I use my self-cleaning on my oven it leaves a brown stain on the white plastic part outside my oven door. How do I clean the area that has browned?
Hello- The self-clean cycle heats the inside up to about 800deg. There is no existing plastic that can take the heat at the vent w/out discoloring. The stain is from the smoke produced when the stuff on the drip pan incinerates. Try some oxy-clean and a damp cloth. Try to predict or minimize spills with foil and drip pans. Techs call 'self-clean' the 'self-destruct' cycle. Using this function will reduce the life expectancy of any electric range. Let me know if this info helps-have more if needed- Thanks- ED
Jan 28, 2010 | GE 30" Self-Cleaning Freestanding Electric...
Carriage cycles normally but no ink on paper.(Stylus color 880)
Turn off printer. Open Case. Move head carriage to parking position. Do suction from outlet pipe of head cleaning mechanic. It's for checking head. is there ink out? If printer not used for long time, may be ink inside head dried. Utility screen just show estimated not actually. If head clog, and do head cleaning more 5 times, screen show ink nearly out, but actually ink tank nearly full.
Jun 28, 2009 | Epson Stylus Color 760 InkJet Printer
How do I use the steam clean self-cleaning oven?
The SteamClean option spot cleans the oven in 20 minutes and is recommended for cleaning light spills on the bottom of the oven cavity. When used routinely, the SteamClean option reduces the need for frequent self-clean cycle use. To use the SteamClean option, pour 12 ounces (1 1/2 cup) of water into the bottom of the oven cavity, close the oven door and push the SteamClean button. At the end of the cycle, consumers wipe out the bottom of the oven, easily removing oven soils. The steam cleaning option is eco-friendly and does not require frequent use of the self-clean cycle, which can create a strong odor. Read this in a post about the new whirlpool ranges
Apr 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Black Horizontal lines
hi!
Horizontal white lines usually indicate the ink cartridge is running out of ink or has some clogged ink nozzles. Try the following steps:
  1. Some of the ink cartridge ink nozzles may be clogged with dry ink. Use the ink cartridge cleaning service to try to clear them. Follow the steps below:
    1. check if there is plain white paper in the Input tray.
    2. Press Setup .
    3. Press < or >to select Tools and then press OK .
    4. Press < or > to select Clean Print Cartridge and then press OK . The unit prints a test page.
    5. Examine the test page. If the print quality of the page is good, stop here. If the print quality appears to be getting better, run the Clean Print Cartridge utility again
  2. If the self test appears better, Increase the copy quality setting (Normal or Best) and try copying again. If the quality is still poor, continue to the next step.
  3. If the quality is still poor, one or more of the cartridges may be low on ink or empty. Follow the steps below to check the ink levels.
    1. Open HP Solution Center .
    2. Click Settings .
    3. Click Print Settings .
    4. Click Printer Toolbox .
    5. Click the Estimated Ink Levels tab.
    6. Replace any ink cartridge that is low on ink.
  4. If the ink levels are not low, clean the cartridge face and electrical contacts at the back of the print carriage.
    1. Open the front of the unit to access the ink cartridges.
    2. After the ink cartridges are at the center, unplug the power cord from the back of the unit, and remove the ink cartridges. The power cord must be removed to ensure that the unit is not damaged during the cleaning process.
    3. Clean the cross-hatched area of the ink cartridge with a soft clean cloth that is slightly dampened with clean water to remove any build up. Avoid cleaning the ink cartridge nozzle plate. Cleaning this area can force foreign matter into the ink nozzles and plug them
    4. With a soft lint free cloth slightly dampened with clean water, clean the copper-colored contacts on the back of the ink cartridges.
    5. Allow the cartridges to dry before reinserting them.
    6. Close the unit, and plug the power cord back in.
    7. Print a self-test page to check the results. Follow the steps below to print a self-test page.
      1. Press Setup .
      2. Press <or > until Print Report displays and then press OK .
      3. Press < or > until Self-Test Report displays and then press OK . The self-test report prints.
    8. If the problem is not corrected by cleaning the ink cartridges, replace the ink cartridge(s).
- hope it will help to resolve you problem...
Jul 14, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Printer problem with 6210 all in one.
Try to print a self test page from the printer itself, do these:
  1. Press and hold the Cancel and the Color buttons at the same time.
  2. Release both buttons.
  3. The Self Test Report will be printed.
and check if it is the same output, if yes then follow the steps below:
  2. Verify that there is plain white paper in the Input tray.
  3. Press Setup .
  4. Press c00712200.gif or c00712201.gif to select Tools and then press OK .
  5. Press c00712200.gif or c00712201.gif to select Clean Print Cartridge and then press OK . The unit prints a test page.
  6. Examine the test page. If the print quality of the page is good, stop here. If the print quality appears to be getting better, run the Clean Print Cartridge utility again
  1. If the self test appears better, Increase the copy quality setting (Normal or Best) and try copying again. If the quality is still poor, continue to the next step.
  2. If the quality is still poor, one or more of the cartridges may be low on ink or empty. Follow the steps below to check the ink levels.
  3. Open HP Solution Center .
  4. Click Settings .
  5. Click Print Settings .
  6. Click Printer Toolbox .
  7. Click the Estimated Ink Levels tab
  • Replace any ink cartridge that is low on ink.
  • If the ink levels are not low, clean the cartridge face and electrical contacts at the back of the print carriage.
    3. Clean the cross-hatched area of the ink cartridge with a soft clean cloth that is slightly dampened with clean water to remove any build up. Avoid cleaning the ink cartridge nozzle plate. Cleaning this area can force foreign matter into the ink nozzles and plug them.
  • With a soft lint free cloth slightly dampened with clean water, clean the copper-colored contacts on the back of the ink cartridges.
  • Allow the cartridges to dry before reinserting them.
  • Close the unit, and plug the power cord back in.
  • Print a self-test page to check the results. Follow the steps below to print a self-test page.
    1. Press Setup .
    2. Press c00712200.gif or c00712201.gif until Print Report displays and then press OK .
    3. Press c00712200.gif or c00712201.gif until Self-Test Report displays and then press OK . The self-test report prints.
    IF THE SELF TEST REPORT IS CLEAN, THEN TRY TO PRINT FROM ANOTHER SOFTWARE LIKE PAINT, NOTEPAD AND IF THE OUTPUT IS OK THEN THE PROBLEM IS ON THE SOFTWARE THAT YOU ARE USING
    Dec 19, 2007 | HP OfficeJet 6210 All-In-One InkJet...
    163 people viewed this question
    jasbo
    jasbo
