Question about Homelite Curved Shaft Trimmer Bump Feed Replacement Line
How do I remove the cutting head on my homelite HLT=15
How do I remove the cutting head on my Homelite HLT-15
  • 333 Answers
Http://www.ereplacementparts.com/homelite-hlt15-ut20602-string-trimmer-parts-c-18807_20299_21185.html
Here is a diagram of it. It is reverse threaded so you have to turn it like you was tightening it to loosen it. Clockwise looking at it from the bottom of the head. But there is a clutch that will let the whole thing turne. The best way is to remove the shaft from the weedeater and hold the shaft with some vice grips. Or you may be able to hold it right above the head, before the shaft tube.
Posted on Jul 12, 2010
Homelite gas edger cuts off after running about 10-15 seconds
The fact that is runs slightly longer on full choke may point still to a fuelling issue.. Does it actually Rev in those 10 seconds or does it just want to bog down and stall.?
May 18, 2016 | Homelite Garden
Weedeater and Homelite shafts interchangeable?
Just give it a try. Some different brands will interchange. I have done this with a Toro and it is still running.
May 18, 2014 | Homelite Garden
What is the part number for a choke cover for homelite
you will have to go to www.homelitetools.eu
you need p/n 5131001732
copy and paste this link to a new browser
http://uk.services.homelitetools.eu/materiel.asp?zzz=1&materiel=HLT26CD&serie=1&DBRequestOnlyOneKEY=HLT26CD%231
hope that helps
regards
Jan 13, 2013 | Homelite Mighty Lite Lawn Trimmer
Changing the spool/ need to place more cutting thread on.
Unable to download your exact model (Mighty Lite) manual. Here are the instructions for stringing a different model with hopefully the same type string head. See pages 14 & 15 of this manual. You will need Adobe Reader installed on your computer to view this.
http://dl.owneriq.net/e/e795beb6-5dd6-4dbd-a82f-57b8d1a69355.pdf
Apr 09, 2011 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite 26CS Model21004D
Once you have the string wound onto the spool, place the spool onto the shaft and pull the strings out of the slots so that the string feeds through the holes without going through the slots. Good luck...Lee
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
This homelite chainsaw is bran new
Remove the spark plug and check for blue and snappy spark. If weak or nothing, try another spark plug. If still improper spark, return the machine for replacement under warranty. Make sure you have followed all instructions for re-start. Good luck!
May 24, 2010 | Homelite ZR10926 16 Chain Saw
How to remove plastic limiter cap on (H) carburetor adjustment
If plastic cap is present, it should just pop off with a thin sharp hook. Look carefully at the screw heads--they may be 'D' heads which require a special screwdriver and are supposed to keep owners from moving the screws (thank the EPA for these). Only authorized saw servicing dealers have access to these tools and therefore are the only folks allowed to adjust these saws. Being nonconformist, I made my own by drilling the center of a 1/4" rod, sawed off one side somewhat and welded a flat across the cut. Hope this helps!
May 09, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
The cable that spins the trimmer head is broken on my d725cd homelite string trimmer
That cable can be purchase at any good Lawn Equipment dealer. Sometimes they have to be cut to length,so take the peices with you.
U can save a little by installing it yourself.
Oct 21, 2009 | Homelite Garden
Homelite Curved Shaft Trimmer Bump Feed Replacement Line Logo
1,310 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
