Question about Gateway GT5228 (7156) PC Desktop
CD Rom Drive door closes when the button is pushed, but then within 5 seconds opens again. It just will not stay closed, but I couldn't see that there is anything obstructing it when I used a flashlight to check.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 32 Answers
It is highly probable that your CD ROM drive has malfunctioned and need to be replaced. I had the same problem with a drive in one of my PCs.
Posted on Jul 12, 2010
    Master:
  • 515 Answers
Inside the computer chass, if you can see the CDROM is connected to the same data cable as that of an hard drive or something, you might like to remove the CDROM to another data cable or make sure the jumper of the CDROM is set to master. That may fix it.
If you remember a software downloaded about coffee cup holder, there might be a virus issue on your computer. A virus scan may help.
http://onecare.live.com/site/en-us/default.htm
How can i open my cd drive to insert my cd?
If the button on the drive won't pop open the drive, then you need to find out what is causing it to stick closed. Most drives have a tiny hole on the door so you can push a paper clip in it to open the door.
Jun 17, 2015 | Computers & Internet
Gateway dx4200 09 dvd drive will not eject?
Unable To Eject DVD From DVD-ROM Drive With The Eject
The DVD-ROM drive will not open to release the DVD when the button is pushed on the drive. RESOLUTION:
  1. Shut down the program that you are installing or running that uses the DVD-ROM drive.
  2. Wait 10 to 15 seconds, and then open the DVD-ROM drive by pushing the eject button on the DVD-ROM drive.
  3. If the DVD-ROM drive door still does not open, do the following:
    • Insert a paper clip or small pointed object into the small hole near the button on the DVD-ROM door.
      Gently push in the paper clip until the DVD-ROM door opens.
    • Remove the CD from the drive.
To prevent the DVD-ROM drive from exhibiting this behavior again, follow these steps:
  1. From the Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the System icon.
  3. In the System Properties dialog box, click the Device Manager tab.
  4. On the Device Manager tab, double-click the CD-ROM category.
  5. Double-click Toshiba DVD-ROM.
  6. In the Toshiba DVD-ROM Properties dialog box, click the Settings tab.
  7. On the Settings tab, clear the Auto insertion notification check box, and then click OK.
  8. Click Close.
Dec 03, 2013 | Gateway DX4200-09 PC Desktop
My Toyota 2001 rav4 remote light stays on it does nt open the doors alarm does not activate
The light for the keyless remote fob stays on? If so the battery may need replaced.
Here is link to a remote - LINK.IF this is yours get a battery @ your grocery store.
-open the key fob w/a flat screwdriver
-note the battery's position - is the '+' or the '-' visible?
-replace the batter the same way
-snap the cover back on
To reprogram (should also be in the Owner's manual):
1. Start with the key out of the ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Perform these steps within 5 seconds.
A. Insert the key into the ignition(Do NOT Turn) Pull key out.
B. Insert the key into the ignition(Do NOT Turn) Pull key out.
3. Perform these steps within 40 seconds.
A. Close then open the drivers door.
B. Close then open the drivers door.
C. Insert the key into the ignition(Do NOT Turn) Pull key out.
4. Perform these steps within 40 seconds.
C. Close the drivers door
D. Insert the key into ignition and leave it in ignition.
E. Turn the ignition to ON (Do NOT Start) then back to OFF.
F. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically
indicating successful entry into programming mode.
Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remtoe simutaneously for 1.5 seconds.
B. Immediately after letting go of the lock and unlock buttons,
Press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door
locks should lock and then unlock once indicating successful programming. If
the door locks cycle twice, repeat steps A and B in step 6 as the remote was
not accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Open drivers door.
Oct 18, 2012 | Cars & Trucks
Cd rom drive door will not stay closed. i close it and then seconds later its back open again.
There's a little piece of plastic or metal that's connected to a sprin which clicks into place when you close the dvd drive and keeps it closed. Either the spring or the plastics is stuck or broken. They're very easy to replace and used ones don't cost much
Jan 15, 2011 | HP Pavilion G60-235DX notebook
Programming instructions for keyless remote Does anyone have the programming instructions for 1998 honda passport keyless remote (FCC #HYQ1512R)?
Get into your passport and unlock all doors. Leave drivers door open. Put key into ignition. Turn to ON (not start), then OFF three times within 5 seconds. Close and open the drivers door twice. Turn key to ON then OFF 5 times within 5 seconds. Close then open the drivers door. Press either the lock or unlock button on the remote. Doors will lock then unlock. Press the button again. Doors will lock then unlock again. Close door to finish programming. If it doesnt work, try it again but turn the key faster. You have to do it all pretty quick, but I had it done on the second try.
Oct 03, 2009 | 1998 Honda Passport
Power Door Light Stays on after battery was changed by a service department
follow this to reinitialize
1. Push the “MAIN” power switch to the “OFF” position.
The “MAIN” power switch is located on the instrument panel, left of the
steering column.
2. Confirm doors are closed, lights are OFF, and the key is out of the ignition.
3. Disconnect the negative (–) battery terminal and wait 60 seconds.
4. Reconnect the negative (–) battery terminal.
5. Push the “MAIN” power switch to the “ON” position and wait 3 seconds.
6. Push the “DOOR R” switch to open the right door and wait 3 seconds after the door
is completely opened.
7. Push the “DOOR R” switch to close the right door and wait 3 seconds after the door
is completely closed.
8. Push the “DOOR R” switch to open the right door and wait 3 seconds after the door
9. Push the “DOOR R” switch to close the right door and wait 3 seconds after the door
10. Push the “DOOR L” switch to open the left door and wait 3 seconds after the door is
completely opened.
11. Push the “DOOR L” switch to close the left door and wait 3 seconds after the door is
completely closed.
12. Push the “DOOR L” switch to open the left door and wait 3 seconds after the door is
completely opened.
13. Push the “DOOR L” switch to close the left door and wait for the door to
completely close.
With ignition in the “ON” position and both power sliding doors in the fully closed
position, the “PWR DOOR” indicator on the dash should NOT illuminate.
14. Confirm proper operation of both doors using the dash, B-pillar switches, and the
transmitter button
Aug 12, 2009 | 2001 Toyota Sienna
Cd rom drive door
Best guess is that a small plastic catch broke. My cousin has similar doors on his CD trays. I personally would take the doors off. As far as repair, again best guess without seeing it, is that you'll need a new door panel.
Feb 20, 2009 | HP GX613AA Pavilion A6300F Desktop PC
Cd/dvd drive won't stay shut
I have the dv9000z. If I do NOT push the DVD drive tray all the way in until it CLICKS shut, then it OPENS again after 1-2 seconds. This is normal. I have found that most times when I close the DVD tray drive, I am not pushing it in far enough, because the top of the DVD tray is rubbing against the laptop's case. If I just press down VERY SLIGHTLY and push the DVD tray in, the tray will fully close and CLICK shut. This works for me. Good luck.
Jun 30, 2008 | HP Pavilion dv9000z Notebook
CD Rom
Well...first lets make sure the drive still can physically open.
http://i36.photobucket.com/albums/e40/freddyhard/CD13.jpg
There in the picture will show you where the manual eject button is. Use a paperclip and push the button in the hole. Once the drive is open enough for you to pull the tray, go ahead and pull it as far as it will come out. It will stop, and it shouldn't come all they way unattached from the rest of the unit.
Go ahead and take any cd or dvds that was in the drive out and turn your computer back on.
Once into windows, push the regular eject button and the drive should close the door itself. Let it sit for a second or two, and try hitting the eject button again. 9 times out of 10, that usually fixes my drives.
Hope this helps!
Jan 15, 2008 | Memorex 32023252 Internal 52x CD-ROM Drive
How can I fix this. (The door won't stay closed)
The problem can be fixed but probably not at your end. Get it done bya trained technician.
Oct 06, 2007 | Lite On Lite-On 52x32x52 CD-R/CD-RW IDE...
Gateway GT5228 (7156) PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
