Question about Volfenhag ZX-4715 Car Mid-Range
How do I wire 2 volfenhag zx- 4715 dual voice coil 15's to 1ohm?
I have 2 volfenhag zx-4715 dvx dual voice coil speakers and a planet audio class d mono block 1600watt amp . how do I wire the subs down to 1 ohm to get the most performance?
5 Suggested Answers
BEERbrooklyn
  • 101 Answers
SOURCE: wiring
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
This should help you;rating please./
Posted on Jan 27, 2008
jpenn1192
  • 58 Answers
SOURCE: how to wire a volfenhag dual coil sub
U HAVE TWO COILS ONE ONE EACH SIDE OF THE WOOFER, ALL U DO IS HOOK UP ONE COIL TO THE OTHER, THEM HOOK THEM UP TO THE TERMINALS IN THE BOX.
Posted on Oct 26, 2008
  • 245 Answers
SOURCE: does two 1ohm woofer = 2 ohm
if you buy the 4 ohm subs you can drop each of them to 2 ohm and then down to 1 ohm between the two of them. going with the 2 ohm no matter how you wire them you will either get 2 ohms 4 ohms or 8 ohms. hope this helps by the way the 4 ohm solobaric and the 2 ohm are both the same price.
Posted on May 21, 2009
  • 8 Answers
SOURCE: how to wire kenwood amp to kicker cvr 12"
If it is a Kenwood Kac 9105d it factory specs say it is not 1 ohm stable.
Posted on Dec 03, 2011
I need to wire 3 woofers but 2 are dual voice coil and one is single voice coil
sure, if you wish to wire them all together, wire the first dual voice coil subs first voice coil negative to 2nd voice coil positive, second voice coil negative to single voice coil sub positive, and single voice coil negative to 2nd dual voice coil subs 1st voice coil positve (again with the second dual voice coil sub, run the first voice coil negative to the 2nd voice coil positve) your speaker leads will be attatched to first dual voice coils 1st voice coil positive, and 2nd dual voice coils 2nd voice coil negative)
Apr 01, 2013 | Kenwood KAC-8104D - 1000 Watts Class D...
Brand new volfenhag 15 1500 wattsblew on 1200 watt amp why
There are a couple of reasons why this might have happened. Subwoofers are finicky. I always recommend to my clients that you don't apply full power to your sub until you have had one week of playing it at low volume. This helps to condition the voice coil. When at full power the voice coils heat up rapidly. To go from cold to heat fast will warp the coil. The bad news is that this would fall under the "abuse" category for refunds. Then again, you might get lucky with a return unless you bought it from an individual. The other thing might be how it was wired. If your amp is 4 ohm stable and you wired to a 2 ohm load, it may have shorted something. But you would think that would be the amp. Not sure this answered the question, but just a few ideas to think about.
Aug 16, 2011 | Volfenhag ZX-4715 Car Mid-Range
How to wire the dual voicecoil
if you have a 2 channel amp, just wire each coil to each channel....If its a mono amp or you are bridging amp, hook up one channel like usual (+ and -) then use a jumper wire from the positive to the other positive on the speaker and do the same for the negative....
Sep 17, 2010 | Volfenhag ZX-4712 Car Subwoofer
Zx-8100 amplifier is red lighting.
try wiring them differently. here is a link for u to go to http://www.crutchfield.com/learn/learningcenter/car/subwoofers_wiring.html . once there find your amp configuration (ie. mono, or 2 channel) then down to the type of subs an how many subs ( ie. 2 dvc (dual voice coil) 4 ohm subs) an that will show u how the subs should be wired and wired to the amp.
Mar 21, 2010 | Volfenhag ZX-8100 Car Audio Amplifier
Best way to connect a 15'' kicker cvr15 4 ohm dvc [single sealed box] and a volfenhag zx-4712 1000w 12'' 4ohm+4ohm dvc to my pyle 885 1000w 4 ch. bridgeable amp and how to wire the voice coils that are in...
best way is to just run the volfenhag with a set of wires for 2 channells(one set per coil) left and right @ 4 ohms per channell. The CVRs you can parallel the coils(2 ohms) and run a set from each sub to the amp in stereo left and right. This will give the kickers a little more juice than the 12 but should be fine.
Jan 25, 2010 | Rockford Fosgate Car Audio & Video
Speaker aint hitting like it should and i smell something burning from the speaker what could this be and how can i fix it
sounds like you are frying the voice coil! Push the centre of the cone in and if you hear a crackle then time to buy new speakers.. sounds like they are on way out if you can smell burning!
Apr 19, 2009 | Volfenhag ZX-4715 Car Mid-Range
12"volfenhag subwoofers
use a 9volt battery, touch both wires to the battery connections, if the speaker jumps upward and away from the magnet, the wire on the positive (+) terminal of the nine volt is positive (Red), if the speaker jumps inward towards the magnet, then the wire on the positive (+) terminal of the nine volt is negative (Black). CAUTION: only TAP the wires to the nine volt terminals briefly, if you hold them on there it may damage the speakers voice coils, (or other parts.) best of luck!
Oct 25, 2008 | Volfenhag ZX-4712 Car Subwoofer
How to wire a volfenhag dual coil sub
Oct 12, 2008 | Volfenhag ZX-4812 Car Subwoofer
Help
ALL U HAVE 2 DO IS RUN UR MAIN SPEAKER WIRE TO ONE SIDE THAN TAKE MORE AND CONNECT THE 2 COILS TOGETHER.
Aug 26, 2008 | Volfenhag ZX-4812 Car Subwoofer
Dual voice coil wiring to class d amp
The easiest way to think of wiring voice coils and subs is this:
  • Two items of the same impedance in parallel = Half of the impedance
    • 4 ohms in parallel with 4 ohms = 2 ohms
    • 8 ohms in parallel with 8 ohms = 4 ohms
  • Two items of the same impedance in series = Double the impedance
    • 4 ohms in series with 4 ohms = 8 ohms
    • 8 ohms in series with 8 ohms = 16 ohms
In this case, you want to wire two subs, each with dual 4 ohms voice coils, so that the total equals 2 ohms. Your options are:
  • DVCs in parallel, 2 subs in series = 4 ohms
  • DVCs in series, 2 subs in parallel = 4 ohms
  • DVCs in parallel, 1 sub = 2 ohms
With two, dual 4 ohm subs, you can only have 1 ohm or 4 ohm total impedance.
Mar 16, 2008 | Car Audio & Video
Volfenhag ZX-4715 Car Mid-Range Logo
128 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
Professor_V
Professor_V
Electro Med Services...
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
