Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 235e will not stay running
Husqvarna 235e 16inch bar. Will not stay running. It takes quite a few pulls to get it started, and than will not stay running very long. from 5 seconds to maybe 2 min, I made sure the choke was in. just fuled it. Saw is brand new first time using it. not first time using chainsaw. I have a Husqvarna weed eater. It runs fine.
    Brigadier General:
  • 4,088 Answers
Take the saw back for warranty service. We have a Husky #435 that had starting problems when new last year--warranty service replaced the ignition module the first trip, then a little later, they replaced the carburetor--it has worked very well since. I suspect that Husqvarna has had problems with our ethanol blended fuels. Hope this helps!
Posted on Jul 14, 2010
What causes chain saw to die?
Sounds typically like a fueling problem 'starvation' check the fuel system from the fuel filter, fuel lines, and carb. could possibly need carb cleaning and gaskets replacing or could be a plugged fuel filter or split in a fuel line. I've attached the breakdown manual for you.
http://www.mediafire.com/view/7jkzri5m6fyk4fi
Jan 07, 2016 | Husqvarna Reconditioned 235E Chainsaw -...
How to remove the chain from a husqvarna 235e chainsaw?
Like this or pretty close.
  1. Cock brake while expanding chain brake binder by pulling brake handle towards left-hand (wrap-around) handle grip, hard, until it locks in place.
  2. Loosen 2 brake-asssembly-and- bar retaining nuts but do not remove yet.
  3. Unscrew (turn CCW) bar adjustment screw on front face of unit in order to shorten bar and slacken saw chain.
  4. Slip chain off bar over bar tip and towards inward side of bar.
  5. Remove two nuts loosened in step 2 and pull brake assembly and bar straight out and off bar mounting studs.
  6. While rotating clutch/brake-drum, maneuver saw chain off sprocket and around drum perimeter to remove from saw.
  7. Repeat/reverse steps 6 thru 1 in that order to reassemble.
25045742-0m3nstwfcb55vn4usb1qox2f-3-0.jpg 25045742-0m3nstwfcb55vn4usb1qox2f-3-2.jpg
Sep 01, 2014 | Husqvarna 14-Inch 34cc Gas Powered...
My Husqvarna 235e chain saw starts, runs, and cuts fine but will not idle without stalling. I notice a little air foam in the primer bulb and a few small air bubbles in the clear fuel line when running,...
sounds like you may need to make a very slight adjustment to the air fuel ratio try by turning your adjustment screws just a 1/4 turn in first then out...
Aug 09, 2014 | Garden
How do you replace a fuel filter for 235e husqvarna chain saw
They are kinda hard to get them out but it is in the fuel tank on the fuel line just get it out the gas tank filler hole then pull off and replace with new one..
Jul 15, 2014 | Husqvarna 235e 16-inch 34.4cc 2-stroke...
Brand new husqvarna 235 chainsaw will not start
is the kill switch on?check the spark plug it could have had the wire fall off in shipping
May 24, 2012 | Husqvarna Forest & Garden #952802239 235E...
How heavy duty is the Husqvarna 235E 14" Gas Chainsaw? can it take a larger bar?
The 235e chainsaw was a complete disaster, all sorts of problems too many to list, i would not put a longer bar on it.
Feb 27, 2011 | Husqvarna Garden
Husqvarna chainsaw 235e starts but the chain won't move. Maybe the brake is stuck??
Does the brake seem to 'snap-over' like it should? Pull it back to release position, and remove the drive cover. Check the entire brake for debris accumulation or bent/damaged brake band. Check the chain to see if it is being oiled. Remove the bar/chain and clean the entire assembly, particularly the small oil passages in the drive end of the bar. Start the engine and watch for oil oozing out of the small side port where the bar fits. If ok, reassemble the bar/chain. If no oil comes out, investigate the oil pump, lines, and filter/valve in the oil tank. Mount the side cover, but leave the fasteners finger tight. (The chain teeth cut toward you on the bottom run) Tighten the chain until the lower run comes up to the bar, but can still be turned by hand. Tighten the fasteners and recheck the tension. Trip the chain brake and make sure it locks the chain, then release it and make sure it turns freely. Check the chain oiling by running the bar tip at speed near some cardboard--it should leave a thin line of oil on the board. Hope this helps!
Jun 26, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chain oiler not working on my 235e saw
Manual de-mystification
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Nov 13, 2009 | Husqvarna Forest & Garden #952802239 235E...
Starts and then runs wide open.
SOUNDS LIKE THROTTLE NEEDLE STUCK OPEN CHECK THROTTLE LINKAGE STICKING OR RETURN SPRING
May 19, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
1,749 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
