Question about Frigidaire Freezers
Used extension cord on freezer then it stopped getting cold.
Ran freezer on an extension cord and after sometime, the freezer stop getting cold. Did the compressor die out?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
Never use a extension cord unless it is of a larger gauge wire size eg: #12. as opposed to standard #16 or #14. the compressor/motor will not get needed power and burns out.
Posted on Jul 13, 2010
Woods chest freezer C0501W3. Where can I get an extension cord?
LOweS,HOME DEPOT MENARDS . any good hardware ask for an appliance extension cord .
Jan 05, 2016 | Woods Freezers
My refrigerator is warm but the light inside turns on and i have it set to cold, it just stopped working today
Have you unplugged the fridge sir? checked for any electrical disconnections? dust clogging your tubules in the back? Enough space between the wall and fridge in the back? sometimes these will do it. Your fridge needs air to oxygenate the tubules so that it does not overheat and not work.
Jan 07, 2014 | Danby DFF282WDB 10.0 cu. ft. Freestanding...
The freezer is cold, but, ice is melting. Its running and the run and power lights are lit up. I removed ice(very little) around the top edge to make sure the door closes shut. It was just fine last n
All I can offer for advice is to ask if it is on an extension cord. Is the freezer plug in good shape and not blistered? Make sure that the cord is a heavy enough gauge to carry the current needed to run the compressor. An extension cord can break down over time and cause the compressor to overheat or fail. Wish I could be more help. Good luck!
May 02, 2012 | Magic Chef Chest Freezer MCCF5WBX
Freezer not working
  • Make sure the freezer is plugged in
  • Check for a blown fuse or tripped circuit breaker
  • Test the power outlet for voltage
  • Inspect the electrical cord for damage
  • Eliminate use of an extension cord, if any is being used
  • Check the outage votageIf power is reaching the electrical outlet, trace the freezer wiring and test components as you go. Either there is a short, which must be located and repaired, or the freezer has sustained electrical damage.
Thanks.
Jun 26, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
My freezer is getting cold but the fridge is not getting that cold what do i need to do? the motor is working
Hi, Try to defrost the fridge. Sometimes air flows stops due to access of ice in the freezer. Try to defrost it and see if it works.
Regards, polysandy
Apr 24, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Freezer model LFFH2067DW2 - shut the door on an extension cord that left the door cracked open overnight. The alarm was on and has not cleared after four hours. How do I clear the alarm?
Hi, It likely will tell you in your owners manual, but if you push & hold the alarm button it should stop after several moments ( I think it may actually be 30-60 sec.) That should reset the alarm. However, if the thermistor senses the temp. to be too warm the alarm will return. Hope that helps, let me know. Good luck.
Nov 12, 2009 | Electrolux 21.0 Cu. Ft. Upright Freezer -...
Problem with Maytag Chest Freezer model MQC1557aew.
First make sure than the condensing coil in the freezer is clean of dust and dirt(it is behind the grill vent in the bottom side of the freezer where the compresor is) If it is clough brush the dirt off after you unplugit.When is clean wait a few minutes ,5, and plugg it back at the GFI outlet and see if work If still tripped the outlet you may have to replace it.
Apr 04, 2009 | Maytag 14.8 cu. ft. / 419 liter Chest...
Freezer and fridge stop working when home temp is cold
ketner1 what you are looking for is an old style freezer. They ran so hot that they didn't care what the temps in the garage was. Here is a suggestion. I am not sure what kind of freezer you have had, but look for one that doesn't have a coil on the back of it. Freezers with the condenser in the cabinet work well at the temps you are looking for, however they don't work well in garages at 90 degrees, then they just transfere the heat to the inside of the freezer. This is the style my parents use and theirs is in a storage shed with no heat.
Feb 02, 2008 | Freezers
Used frigidaire
look around the back of the freeze and at the bottom you will see a small black compressor .Put your hand on it and if it is running you will feel it vibrating. If it vibrating but running very hot them it means you have no gas in the system so the freezer won't freeze. If the compressor is cold and not running then it could be eaither the relay on the compressor or the board on the front either way you will need to get an engineer in
Dec 11, 2007 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezers Logo
179 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
John Tripp
John Tripp
Justin Duby
Justin Duby
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
