Question about Dishwashers
I have a modle GSD5130Dooww I can't find my manaul and I am have a leak it looks like it is coming from the mortor shaft that go's to a plastic housing can you help me
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 16 Answers
Common problem the seal on pump leaks you have to rebuild pump or replace it sorry you need service
Posted on Apr 20, 2008
I need an oners manaul for a air compressor modle#919.175251
Gayle because i dont know what is the exact product you need the manual for . but you can either go to fixya.com and search for the product here http://www.fixya.com/support/browse
or just go to http://www.manualsonline.com/
to find the manual you are looking for. hope this helps. cheers.
Aug 06, 2013 | Computers & Internet
I have a Hayward sand filter and its leaking from the bottom. I know this because water is collecting under the stand it sits on. I can't move because of the plumbing. What do I do.
Depending on how close the pump is to the filter, you may be getting tricked and the shaft seal in the pump is leaking. If the bottom of the filter is leaking, it's either the drain plug, which is obvious and you can see it. Or the tank is cracked because it wasn't winterized properly, depending on your situation. There is nothing else underneath that filter that will leak. You need to locate exactly where that water is coming from. If it is the shaft seal in the pump, it is hard to see but look underneath your pump where the plastic housing meets the motor, the shaft seal is in that area, although you can't see it because it is inside the pump, but if it is leaking, that is where you will see it. Need an update after you check that stuff out.
Jul 13, 2010 | Hayward SAND FILTER, PRO SERIES
HOTPOINT WASHING MACHINE - BELT IS RUBBING AGAINST BACK OF DRUM & WEARING BELT + INTO PLASTIC DRUM CASING. I HAVE TRIED MOVING THE BELT TO THE FRONT EDGE OF THE MOTOR PULLEY DRIVE, BUT AFTER A FEW...
if you have gotten that far your good
now try to look at the motor it sounds like your belt might be a lil off track on the mortor shaft
there is a adjustment srew on the top left of the motro its hidden under things but its there
you can looses this and swing the motor
make sure you have it lined up on the motor shaft and it should stay aligned on the pully
Oct 08, 2009 | Hotpoint Aquarius WD63 Front Load...
Need owners manaul for a craftsman tablesaw modle 113-241680
Check out the sears.com website....you can usually find and download the owners manual there.
Sep 04, 2009 | Craftsman Saws
My hayward superpump for the pool in leaking
normally this is not a crack in the housing. It is usually a shaft seal.
David
May 14, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Whirlpool 8255e Super Capacity: How to replace drain pump?
Sounds like the drain pump has been leaking from the seal where the motor shaft goes into it. Usually you pop off the 2 metal clips, and pull the drain pump off the motor shaft.
If yours won't come off easily, chances are the motor shaft has expanded from corrosion, seizing the drain pump onto it. You can try prying it off by wedging a screw driver between it and the motor (be careful not to damage the motor). Last resort is to break the drain pump into pieces to remove it.
You will likely have to sand or file the motor shaft back into shape to install the new drain pump.
Let me know if you need more help.
Mar 13, 2009 | Whirlpool Washing Machines
Oil coming from gearcase,looks like it is weeping out of the bottom center plug. modle la9500xt
it is most likely leaking from the seal on the side and leaking down to the bottom. 2ad94fc.jpg
Aug 01, 2008 | Whirlpool Washing Machines
Maytag Dishwasher-pdb2430awx-Leaking
I believe that you must buy the plastic pump housing.....And that vinyl type shaft seal comes with that..I think!!!!
I have the same problem.....I changed the regular seal kit at a cost of $30.00 CND....Which is like what? 100.00 American.
Anyways mine still leaks after all that. Turns out there is so much rust between the nylon seal that is attached to the motor shaft, that water works its way down there. Funny that seal does not come with the common seal replacement kit. Im going to check tomorrow to see If I can get that seal alone. My concern is that after I drive for another hour one way to get that seal. Am I only going to put it on just to find out that the shaft is pitted to much by the rust to seal again? I am so tired of buyin ****!!!!!!
May 22, 2008 | Dishwashers
Dishwashers Logo
97 people viewed this question
Top Dishwashers Experts
