Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
What is error 93 - Intex Automatic Salt Water System for Above Ground Saltwater Pool
  • 297 Answers
93 is not an error
it is sleep mode after the hours that you set for run time has elapsed
If you leave it alone it will start the same time in 24 hours and do it again.
If you need more time for generating or less the next day just unplug your system plug it back in and it will go back to 88 Filtering only
Posted on Jul 12, 2010
  • mark Gianotto Aug 09, 2010
    would have been nice of you to use the rating system after the expert free help you received!
Como puedo aser para k se apage el chek trans de mi isuzu trooper 93
Check transmission lamp? my Isuzu trooper Apage 93 And disconnected plug, and even blinks stills
the lamp means transmission errors.
IS this car an automatic transmission.?
if yes, then some flash the OD lamp and others blink a check transmission warning lamp.
we find the car has TCM ? transmission brain and we scan it.
this old car has flash codes for TCM.
we insert the jump to the TCM DLC connector and it flashes out error codes, we write down and use to fix car.
translated
Compruebe la l?mpara de la transmisi?n? mi soldado Isuzu apage 93 Y enchufe desconectado, e incluso parpadea alambiques
la l?mpara significa errores de transmisi?n.
Este es un coche de una transmisi?n autom?tica.?
en caso afirmativo, a continuaci?n, algunos de flash El indicador OD y otros parpadear una luz de aviso de transmisi?n cheque.
Podemos encontrar el coche tiene TCM? cerebro de transmisi?n y escanearlo.
este viejo coche tiene c?digos de flash para TCM.
insertamos el salto al conector DLC TCM y destellos a cabo los c?digos de error, escribimos y usamos para fijar coche.
Oct 12, 2015 | Isuzu Cars & Trucks
What is Xerox 8570 ColorQube error 93 984.00:3683
93,984 means: Cyan obstructed, reservoir not filled
• Check for ink spills around the Printhead.
• Check the Ink Loader for bent melt tips.
• Check the Ink Loader power cable misrouting around melt tips.
• Check height of ink levels in the head reservoir.
Mar 15, 2015 | Xerox Office Equipment & Supplies
Display panel flashing 93 E
Warranty?? Call immediately Samsung Customer service if under warranty. according to: http://www.appliancerepairlesson.com/tag/samsung-refrigerator-error-codes/ e84 was a new error code in 2013 and covered under warranty.
Mar 13, 2015 | Samsung Refrigerators
Error code 93 on my Bosch washing machine front loader
Sorry,I cannot find code #93 for Bosch washer. I looked a LOT,too.
Nov 11, 2014 | Bosch Washing Machines
T-190 Bobcat shows error code 75-93 but that code isn't listed in the manual. What is it?
you need to call the Bobcat company and talk to a technical staff person. Or google it and get on their website and contact them. There may not be a lot of bobcat experts here.
Oct 28, 2014 | Cars & Trucks
Frigidaire oven error code
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuosly runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
Accessories For Audi
Jun 12, 2012 | Ovens
F93 error code
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 24, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Error code 93:11
System Error: 93:11
Description: Unable to pressurize the IDS.
Corrective Action: Try the following:
Remove ALL the Ink Cartridges and reinstall them one by one in to the Printer.
Replace the Ink Cartridges.
Replace the APS Assembly.
If the System Error continues, replace the Ink Supply Tubes and Trailing Cable.
Dec 29, 2008 | HP Designjet 4500 Pass-Through Scanner
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
194 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
