Question about Sharp CV-P10MC Dehumidifier
Won't pump out water from drain on Sharp Air Conditioner CV-P10MC
Will not pump out water from upper drain when full, have to drain all water from bottom drain, about 2 quarts, why?
Our new Santa-Fe Classic dehumidifier is leaking water from the bottom of the unit. It's also sending a small amount of water correctly through the tube for dispersal. We've only had it for two...
The classic model drains thru the clear hose using gravity. The drip pan in that unit is about 1/2 way up in the cabinet. Make sure the drain hose exits the unit and runs flat or downhill. If the drain hose is coiled vertically or run up hill causing water to trap within the hose it can cause water to back up in the dehumidifier drip pan and overflow causing your problem. If your drain is higher than the base of the dehumidifier, you can raise the dehumidifier or you can purchase a condensate pump kit that will allow the drain water to be pumped up to 15 feet above the dehumidifier.
The drain hose may have become disconnected from the drip pan as well. To check, turn off the humidistat to stop the dehumidifier from running. Next disconnect the cord from the power supply. Remove the six screws holding the cabinet side (with the label) from the cabinet and remove the cabinet side. The drain hose connects to a nipple on the bottom of the drip pan.
Contact Therma-Stor service for further inquiries at 1-800-533-7533 - they are located in the USA and are very helpful.
Sep 07, 2011 | Therma-Stor Santa Fe Dehumidifier
I have a De Longhi 8C70 Dehunidifyer. It is approximately seven years old. The pump is broken, when I flip the pump switch to the on position, the water no longer goes through the tube but drips into the...
Think the problem is with a clogged tube running to the drain, rather than a faulty pump.
To test this theory, first turn the unit OFF & unplug it. Using an 18" long, appropriately sized, plastic Zip Tie. Carefully insert it into the drain hole tubing and continue to push it in unitil you reach a bend in the tubing. Gingerly work it past this bend until the Zip Tie bottoms out or your run out of usable Zip Tie. Then slowly pull it back out while rotating (twisting) it. This will help break up any clogs. As you reach the tip of the Zip Tie, be prepared as some water may follow. Plug the unit back in and turn the unit ON. Set the control to Pump Mode and monitor the drain for water flow.
I hope this helped you and thanks for choosing FixYa.
Aug 03, 2011 | DeLonghi DN40G Dehumidifier
Attached a pump to drain collected water. The
the water should still collect into the tank. the dehumidifier had a float switch that shut the unit off when the tank is full. In turn it should have a second switch, probably a float switch that turns the pump on and off so that the pump doesnt continue to run when there is no moisture in the tank
Nov 26, 2009 | Frigidaire FDL50R1 Dehumidifier
Have portable a/c with dehumidifier. what is the drain in the middle of the unit for with a dial that shows a water drop and a snowflake, and what is the drain on the very bottom for?
The fully clockwise setting is the coldest (three snowflakes). The ... Water-cooling increases compressor capacity when the weather is very hot. Switch off ... Drain all water from the pump, sea strainer, hoses and water coil in the BD housing ...
Aug 21, 2009 | Fedders Dehumidifiers
Dehumdifier won't drain
You just need to get the water flowing and start the siphoning process by taking out the water bucket while it's full of water and raising it up high enough to start the water flowing. Once the water starts flowing, you can put the bucket back and the water will keep flowing (by capillary action). If the bucket empties completely, you may have to do it again periodically to get the water flowing again.
Sep 17, 2008 | Kenmore 54701 Dehumidifier
Kenmore 54501 Dehumidifier
Clean the hose (it's full of black gunk)
Jun 30, 2008 | Kenmore 54501 Dehumidifier
Internal pum hose connection?
I just fixed the same problem on my DE-500P. The pump filter was blocked and there was a layer of scummy lint-like stuff in the bottom of the pump reservoir (not the main - or overflow tank) also blocking flow down through the filter to the pump. Repair steps are as follows:
1. Remove the overflow water tank and the two side covers (five screws in each). Note that as you go through the removal of all the covers and other procedures, there are two lengths of screws; don't switch them. If you lose track, the rule of thumb is use the short screws for going through a single layer of plastic into metal.
2. Remove the rear cover (take out the screws along the bottom and on the sides). It will still be attached to the front top cover at the top with tab fasteners. Gently pull out the bottom of the cover while depressing the top of it on both sides with your thumbs (about an inch and a half inside the trim ridges) to clear the tabs. Ease the top part of the cover back and remove it (it will have to tilt to one side, don't forget this when putting it back on).
3. Remove the top cover, not forgetting the two screws on top by where the back cover attached (go gently, there's a wiring harness) and turn it to the side. There was enough slack to leave the wires connected; just be careful to not damage them.
4. The filter looks like a small transparent in-line gas filter. Remove the pump filter, leaving the short tube attached to the top of it. I quickly atttached a length of tubing to drain the reservoir into a bucket. I couldn't find a replacement filter, so I filed a slot in the side of the bottom half of it to remove the gunk using the wire from a twist tie (the upper half had some tabs inside that would have been in the way). Afterwards, I wrapped it tightly with stretchy electrical tape and put a wire tie over the tape at the slot to keep the tape from being able to creep loose over time. Don't use a fuel filter, the paper element is too fine (you need a screen) and the paper will fall apart in water.
4. Remove the float and bracket from the pump reservoir. The reservoir screws are not all apparent; there's also a screw way over on the left and one coming in from the right. I used a 12 inch #2 phillips screwdriver with a magnetized tip for most of this. Remove the pump reservoir and clean out the scummy stuff in the bottom and where the tubes attach. When removing the reservoir, you'll have to detach the vent line that goes through the bulkhead to where the big tank was and pull the tab above it down slightly while easing the tank out.
5. Clean out any dirty tubes, paying particular attention to the coupling for the drain hose and the long drain hose itself.
6. Put the reservoir back in and hook up all the tubes and filter. It does make a difference in which direction the filter goes back in. You want the water from the reservoir to go through the filter from the outside of the little screen; that leaves the maximum room for crud build-up before it plugs up the screen again.
7. Depending on your confidence level, at this point you may want to plug in the dehumidfier, put the overflow tank in, turn it on, turn on the pump, and fill the pump reservoir to check for functioning and leaks. If you do this, just remember that the circuits are hot and not all are insulated.
8. If all is OK, unplug the dehumidifier and put the covers back on. Total time was about an hour.
Jun 28, 2008 | DeLonghi DE500 Dehumidifier
Pump failure
Jun 26, 2008 | DeLonghi DE500 Dehumidifier
The pump doesnt work
I just fixed the same problem on my DE-500P. The pump filter was blocked and there was a layer of scummy lint-like stuff in the bottom of the pump reservoir (not the main - or overflow tank) also blocking flow down through the filter to the pump. The line you tried to plug is probably the vent line for the pump reservoir. It attaches to a fitting on the removable tank side of the bulkhead. Unstop the vent. Repair steps are as follows:
4. The filter looks like a small transparent in-line gas filter. Remove the pump filter, leaving the short tube attached to the top of it. I quickly atttached a length of tubing to drain the reservoir into a bucket. I couldn't find a replacement filter, so I filed a slot in the side of the bottom half of it to remove the gunk using the wire from a twist tie (the upper half had some tabs inside that would have been in the way). Afterwards, I wrapped it tightly with stretchy electrical tape and put a cable tie over the tape at the slot to keep the tape from being able to creep loose over time. Don't use a fuel filter, the paper element is too fine (you need a screen) and the paper will fall apart in water.
6. Put the reservoir back in and hook up all the tubes and filter. It does make a difference in which direction the filter goes back in. You want the water from the reservoir to go through the filter from the outside of the little screen; that leaves the maximum room for crud build-up before it plugs up the screen again. Newer ones have a flow direction arrow; point it away from the reservoir.
Jun 01, 2008 | DeLonghi DE500 Dehumidifier
Shows water container full and it is empty
We've had dozens of these in for more serious work but I noticed that the drain container on them has to be shoved in all the way in order to satisfy the control. What I do to get some peace while working on them is shove a small piece of styrofoam into the opening on the upper right where the tab in drain container goes in. Alternatively, if the mechanism needs adjustment you could bend the metal actuator bracket forward just a bit
Dec 23, 2007 | Maytag M7DH45B2A Dehumidifier
Sharp CV-P10MC Dehumidifier Logo
93 people viewed this question
Top Sharp Dehumidifiers Experts
Bill Long
Gil Shultz
Marvin
Marvin
Are you a Sharp Dehumidifier Expert? Answer questions, earn points and help others
