Question about Fisher and Paykel GWL11 Top Load Washer
Fault code 37,what does indicate. - Fisher and Paykel GWL11 Top Load Washer
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.This error code is called PUMP BLOCK ERROR.Now please look under the machine for me to the front right.You should see a red or black fan,This is your pump.Now turn the fan clockwise and anticlockwise a few times to loosen it up if it is jammed.The fan should turn freely.Now put the machine back on its feet and select a spin cycle.The machine should start to drain.Please reply to tell me how you got on or if it still does not drain or if you have the other type of pump.Good luck
Posted on Jul 12, 2010
F/P smart drive pride 5.5 all lights on but machine doesnt respond
Posted on Jul 15, 2010
  • MiracleX Aug 11, 2011
    Had Problem with Spin Cycle Lights 5 and 8 was blinking and beeping. Problem now solved with this solutions Thank You.
3 Suggested Answers
SOURCE: top loading intuitive washer says fault code 37
Thank you BrisbaneTony - your clear instructions helped me check and clear the blockage in my pump. I did not disconnect the water hoses though - simply tipped the machine backwards against the wall so that I could access the pump underneath
Posted on May 09, 2010
rickyrt441
  • 4399 Answers
SOURCE: washing machine stopped working and
Thanks for choosing FixYa and welcome to the site. The code is for a draining issue. You can try unplugging it to reset it first. If not, if it is filled, you will need to drain it. You probably have something blocking the pump. The pump should only have 4 screws to take off. Look there and see if it is blocked. Make sure the drain hose is not blocked also.
Posted on Apr 10, 2011
My Phillips model number 27PT6441/37 tv doesnt come on when u push power. Instead power indicator flashes a total of six times. 2 flashes,then 3 flashes,and then 1 flash. What does this indicate?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jan 04, 2017 | Televison & Video
Temp display on door is giving wrong display
this is a fault code.. take a picture of the panel and post it here also picture of the model and serial tag.....I can find the fault codes with the info asked for............ ken
Sep 30, 2014 | Refrigerators
I have a philips 37 lcd tv will not turn on no sound no pic light goes green then blinks 8 timmes pause 8 times pause etc any ideas
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Feb 23, 2014 | Philips 37PF7321 37 in. LCD Television
Philips 37PF5521D green light flashes 1 long then 9 short
The fault code is '19'. Counting the flashes to philips TVs are given in detail by the link given below. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/ You can get details about the fault codes, blinking codes etc:
Nov 14, 2013 | Philips 37PF5521D 37 in. HD-Ready LCD...
Green light continues to blink
These blinks are fault indications, called blinking codes. To count the blinking codes to Philips brand Televisions are some what different. It cannot be counted directly. If you wish to get more details about how to count the blinking codes, and convert it into fault codes, check the site linked here. It is very difficult to type in all here by this window. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 09, 2013 | Philips 32PT6441/37 32" TV
Fisher Paykel Intuitive Eco Washer IWL12 fault code 37
Pump Ohms to low will smell like burning enamal
The pump will need replacing,
Apr 06, 2013 | Fisher and Paykel Washing Machines
I DONT KNOW WHAT MY TRUCK IS TELLING ME MY ENGINE LITE BLINKS CODES 1-2 3-7 5-1 5-5 MY1995DODGERAM4X45.9L RUNNING ROUGH SURGES BAD GAS MILAGE BLOWING RAW FUEL
The 12 is No. of Key-ons since last fault or since faults were erased. 37 refers to torque convertor. 51 refers to Lean F/A condition, Oxygen sensor signal. 55 is NA. You will always get the 12 to start and 55 that indicates that the code reading has went through the cycle. Here is a site that might help on the code 37. http://www.youtube.com/watch?v=eWINl2zAt1I Good luck.
Jun 21, 2011 | Dodge Ram Pickup 1500 Cars & Trucks
Hi My F&P washer has been doing a error 51 for a couple of weeks, havent had a chance to get someone to kook at it, I stop it and restart it and it washes all the way through the cycle only did this on...
Error code 37 indicates a blocked or not working drain pump but the slight burning smell likely indicates a burned out drain pump motor. Do not use the machine unless the drain pump problem is addressed as it will result in the damage of the motor controller module. It has been found that electrical problem in the drain pump motor leads to the burning out of the motor controller module.
Error code 51 indicates a blocked or damaged diverter valve. It is where the drain pump and the recirculation pump inlet hoses are attached from. It works in directing (diverting) water to the recirculation pump during the wash stage and to the drain pump during the drain and spin stages. Click on the link below for the troubleshooting details of this problems.
Troubleshooting Fault Code 37 on Fisher and Paykel SmartDrive and EcoSmart Top Load Washing Machines
Mar 17, 2011 | Washing Machines
Needs serves code 37
To my knowledge error code 37 indicates fault "pump blocked"
Corrective procedures would require checking the drain pump, drain hose, drain filter. Particular attention must be given to the drain pump impeller as they have been known to stop due to safety pin, plastic and any foreign debris.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 20, 2008 | Fisher and Paykel Washing Machines
Fault code
arrwup.gifDescription An error has occurred related to the Electronics Module 50 V Power Supply. The clutches operate at 50 V. The Head Maintenance, Deskew, and Pick clutches are drawing too much power indicating a short in the supply or one of the components connected to it.
Mar 13, 2008 | Xerox Phaser 8500/DN Printer
Fisher and Paykel GWL11 Top Load Washer Logo
244 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
