We have a pt 56DLX76 tv we purchase through home shopping network fall of 2008. Serial # is h6aa10059 and just recently when you try to turn on the tv it shuts off after 30 seconds or so and green light turns to red. Then a red inidcator next to on/off switch turns on in red letters stating lamp and flashes? What is the problem?
  • 81 Answers
Sounds like either a lamp is out, or you need a new power supply in it.
Posted on Jul 12, 2010
TV was working fine earlier today. Now, when the TV is turned on, audio and video will be fine for the first 30 seconds, then everything goes black and audio cuts out. When this happens, a faint buzzi
this works for me.....hold down the off button on top of the tv for at least 5 seconds....(not the remote).....then try the remote on button
if it does not work the first time....try holding down the tv off button a bit longer
Jan 02, 2015 | Panasonic PT-56DLX76 Television
I have a DLP tv, model# pt56dlx76, which has a red x-ray like apperance screen.The picture is always red regardless in picture mode or on the menu screen. I have nothing attached to the tv and the same...
One of your color guns (Red, Green and Blue), have quit working correctly. It perhaps is the blue one and the red gun operating at it's usual level is washing out any other. You need all three guns to get the mix of colors, so repair is in order.
Apr 16, 2011 | Panasonic PT-56DLX76 Television
Lamp flashes red and tv just shut off
You may have a bad lamp. Open the door on the side & pull lamp. The part number is TY-LA2006. They cost about $200-225. BE SURE to reset the lamp timer. If you buy an original Panasonic TY-LA2006 lamp, it will have instructions to reset lamp timer.
Jan 21, 2011 | Panasonic PT-56DLX76 Television
Pt-56dlx76 panasonic light flashes red 3 times. I just changed lamp.
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired ofcourse) and found four bulged capacitors on the PSB. Many major electronics companiesPhilips/Magnavox, Sony, Panasonic, and others were sold capacitors that failedin 2-5 years instead of 10-20. Thecapacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices and cause a wide range of failure problems. Here are some options for you. 1. Have it fixed by a professional $$$$$$$??????? (Is itunder warranty?) Remember, TVs CONTAINHIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk. 2. Open your TV and find PSB. (The board that the power cordplugs into) Check for faulty caps. If you find some (bulged or leaking) bad capsreplace the entire board. The entireboard costs around $250 right now because they are in high demand right now.They can be found at tv-part.com but supplies are limited. I would definitely shop around though. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds. This may be your problem. If you determine that it might be. I have a Tip/How TO tutorialon this site that may also help. Itgives step by step instructions for replacing caps on PSB #715t2432-2. If this isyour board you are in luck. Here is theLink: Fixingthe Philips Turns/shuts off on its own problem. I'm working on uploading pictures to helpguide people though the process as well. Let me know if I can do anything to help. Hope this helps and if it does please rate itaccordingly. Good luck.Kaufman605
Dec 16, 2010 | Panasonic PT-56DLX76 Television
Resetting the timer for the lamp on a PT-56DLX76?
stephanie286,
Here is the porcedure:
The procedure is a little bit tricky so that you do not do it accidentally.
1. Turn on the television.
2. Press the volume down button on the TV display (not the remote)
3. While pressing the volume button, press the "split" or "PIP" button on the remote.
If it works you will see a message saying the lamp timer was reset to 0 and the indicator will turn off.
Thanks for using FixYa and for the great rating.
hardrocko
Nov 30, 2010 | Panasonic PT-56DLX76 Television
How to get serial number
Hello russhellfarr,
You have the software installed in one computer with the serial number ? You could try THIS app to retrieve your key.
If it doesn't work, contact Sony and send the date of purchase and all the data you can.
May 27, 2009 | Sony Acid Music Studio 7 Full Version for...
Hoover Z 700 Model U9145-900
Try going to hoover.com and either email them or there is a number that you can call, this is hoover direct, so someone there should be able to help you. Have your model and serial numbers and purchase date handy in case they ask. It also has a 2 year warranty on it. So if you bought it in the fall of 2006, then you have until the fall of 2008. I would take it to an warranty servicer and get it repaired before the warranty runs out.
Mar 18, 2008 | Vacuums
Televison & Video Logo
Top Televison & Video Experts
