Question about GE Monogram ZISS480NRSS 48" Built-In Side-By-Side Refrigerator (ZIS-S480NRSS, ZIS S480NRSS)
On my 48 inch built-in Monogram ZISS48NCASS, the refrigerator
On my 48 inch built-in Monogram, the refrigerator side seems to have a high temperature differential between the top and bottom. At the top of the fridge, the temp is around 40 F while the bottom in the veggie drawers reads 18. The bottom freezes. I replaced the damper control with no change in performance. I also placed the old damper control in the fridge to see if the door was closing as it should and it did.
There are some vents on the bottom left of the fridge where I suspect too much cold air is coming from the freezer side. Should I attempt to block some of the vents to see if that increases temperature or is there a lower damper built into the dividing wall?
  • 760 Answers
I would assume the damper is operating since your upper temperature is normal. I believe there is a "thermodisk" near the top in the fresh food section, You didn't indicate how cold the freezer is. If the freezer section is way below zero try turning it slightly warmer.0 is normal for a freezer. You shouldn't have to block those vents, I also would assume the evaporator fan is running in the freezer.
Posted on Jul 12, 2010
  • bivman602 Jul 12, 2010
    Hello, additionally my fridge thermodisk / control is set to 1, warmest. The freezer disk is set to 6 and the temp ranges between 18 and 25. The freezer should probably be a little colder as the icemaker does not engage but the fridge side is already too cold.
  • bivman602 Jul 14, 2010
    Also, yes the evaporator fan is running, although it seems like there is a lot of heat that comes off the top. I have also considered attempting to install a few small CPU fans on the refrig side to better circulate the warm and cold air.
My GE Monogram side by side built in refrigerator will not freeze ice or keep food frozen. It stays just under the freezing temperature. The refrigerator portion seems to work. Can anyone help?
its possible that its either short of gas or the little fan motor in frezzer/fridge is not working,but if its only making ice now and then its sounds like a gas shortage
Aug 28, 2012 | GE Monogram ZISS420NRSS 42" Built-In...
GE ZIss48ncass Monogram side by side not cooling but freezing okay?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 09, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Monogram 48"
http://www.acmehowto.com/howto/appliance/icemaker/check/inletvalve.php
Nov 11, 2010 | GE Monogram Side by Side Refrigerator
48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfjfg
Aug 16, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Refrigerator is not getting COLD
clean the coils on the back of the fridge and make sure the condenser fan is free and running normally. that is the fan at the back of the unit on the bottom where the compressor is. if it cant ge rid of the heat, it wont cool. also make sure the the fan that supplys the cold from the freezer to the fridge is working.
Jul 21, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Refrigerators Logo
169 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
