Question about Audiopipe TXX-AP15-BL Car Subwoofer
What size box do i need? - Audiopipe TXX-AP15-BL Car Subwoofer
  • 17,130 Answers
Normally a speaker box with a 15- 20 litres capacity should be suffficient but it depends on the size of your car. I would not like to waste the boot area for filling up the subwoofer. hence you can compromise and make a tubular type subwoofer or if your vehicle is a sedan, cut out in the parcel tray. If you are able to make bass reflex, the port must be tuned with a sleeve. or else make an infinite baffle. sometimes this is very good for the low bass performance. design the size structure according to the car size, use good joints/ glue well or else it may sqeak with every bass beats. Hope this helps you. Good day
Posted on Jul 13, 2010
What size box doe i need for my Phoenix Gold TX12D 12" TantrumX Series?
The box recommendation should be in your manual for the sub. It will tell you optimal box size. and preferd box style. if you dont have a manual you can find one online. or even by writing the company.
Jan 08, 2015 | Phoenix Gold Car Audio & Video
Need some tips on building a subwoofer box.
Do some research on the model of subwoofer and find the recommended box size, subwoofers need the correct box size to work to its full potential, and size in meaning the volume of space inside the box so if you cant fit your box in your trunk cut it down to the size you need but make it bigger as much as you took of if you have more room say in night for eg.i hope the heaps otherwise there is so much online about sub enclosures.
Aug 06, 2014 | Car Audio & Video
Please teach me how to use my HPF4185 to print envelopes. Thanks.
Hi
Use the product software, also known as the printer driver, to change the print settings for your envelope size and type. Then, use the Envelopes and Labels tool in Microsoft Word to select your envelope size.
Step one: Adjust the print settings
-In Microsoft Word, click File , and then click Print .
-Make sure that your product is in the Name drop-down list box, and then click Properties .
-Click the Features tab, or the Paper/Quality tab.
-Select an envelope size from the Size drop-down list.
-If the required paper size is not in the drop-down list, follow these steps to create a custom paper size.
-Select Custom from the drop-down list.
-In the Custom Paper Size dialog box, type a name for the new custom size.
-In the Width and Height boxes, type the dimensions.
-Select the unit of measurement, and then click Save .
-Click OK to close the Custom Paper Size dialog box, and then click OK again to close the Properties dialog box.
NOTE: You must exit the Properties dialog box to apply your changes.
Open the Properties dialog box again, and select the new custom size from the Size drop-down list.
-Select the paper type.
-In the Paper Type or Type is drop down list, click More .
-Click the desired paper type, and then click OK .
-Select the paper source from the Paper Source drop-down list.
-Change any other settings, and then click OK to close the Properties dialog box.
Step two: Set the correct envelope size
-Set the correct envelope size in the Envelopes and Labels dialog box before printing envelopes.
-In Microsoft Word, click Tools , click Letters and Mailings , and then click Envelopes and Labels .
-In the Envelopes and Labels dialog box, click the Envelopes tab.
-Click Options .
-From the Envelope size drop-down list, select the required paper size. If you created a custom paper size, select the new custom paper size from the drop-down list.
-Click OK , and then click Close to close the Envelopes and Labels dialog box.
-Click File , and then click Print to print the envelope.
NOTE: When you finish printing the envelopes, return the paper size and the paper type settings to the defaults.
Regards
Riztech
Oct 30, 2010 | HP Deskjet F4140 All-In-One InkJet Printer
Do you hhave a wireing picture or plan to wire the load center
Here are links that show basic wiring inside a breaker box.
Please look at the images.
If you need more help, answer back and we'll go to the next step
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/240-v-water-heater-circuit.html
http://waterheatertimer.org/Circuit-breakers.html
http://waterheatertimer.org/Color-codewire2.html
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Breaker size:
15 amp breaker connects to 14 gauge wire
20 amp breaker connects to 12 gauge wire
30 amp breaker connects to 10 gauge wire
Home Depot and Lowes have a breaker and wire size size chart next to wire cutting machine
These stores have guys who know the basic breaker size for your big appliances
Each appliance has a name plate showing wattage and voltage.
The wattage tells you what size wire.
The voltage tells you what size breaker and whether you need a 120V breaker or 240V breaker.
To lay out your home wiring:
The kitchen microwave needs a 20Amp 120V 'dedicated' line that goes just to the microwave.
The rest of the kitchen plugs are served by another 20 amp 120V breaker
When laying out rest of house, figure how much wattage might be used in an area.
For example the den might have a big 500Watt TV, and 2 ceiling fans and 4 lights.
Add up the wattage and decide how many plugs and switches you want on each breaker.
Now let's say you have a 20Amp breaker which can carry 1920 Watts for the den.
Inside the breaker box you have a 12 gauge wire for the 20 Amp breaker.
The 12 gauge wire has a black, white and bare ground.
The black connects to breaker. The white and ground connect to Neutral busbar.
The 12 gauge wire leaves the breaker box and goes to the first box in the den.
This box is your junction box.
The junction box can be a switch box or a ceiling light box.
You cannot have any junction boxes that are covered by drywall.
Junction boxes must be accessible. All boxes must be accessible.
For example, you choose a ceiling box for your junction box.
The junction box is also the same box your ceiling light connect to.
From your junction box, you branch off a wire that goes to next box.
And then a wire branches off next box and goes to next box. And so on.
If you need more help, answer back and we can help.
Oct 24, 2010 | Gb Electrical 100 Amp GE Load Center
What type and size of box should i use with this
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. Box size will be 13 inches x 13 inches x 13 inches
May 26, 2010 | Phoenix Digital PD-131 Car Subwoofer
Need a box size for a powerbase 15" zs subwoofer h+w+d of the box or for ported box
If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long Box size will be 16 inches x 16 inches x 16 inches
Apr 20, 2010 | Car Audio & Video
What size box do i need for two 12'' infinity
14" Cubed box, sealed, not ported.
Dec 28, 2009 | Car Audio & Video
Picture too big
Normallly, if the picture size button on the remote for the television1.gif ( If it has a picture size or format button) does not achieve the desired affect, then, a cable box or a satelite box is where the change4.gif needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Jan 27, 2008 | Televison & Video
Picture size
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
Hope this helps.
Jan 05, 2008 | Toshiba 50H82 50" Rear Projection...
The picture is too big for my screen
press zoom on the remote control to get the normal size
Dec 24, 2007 | Toshiba 35A44 35" TV
Audiopipe TXX-AP15-BL Car Subwoofer Logo
186 people viewed this question
Top Audiopipe Car Audio & Video Experts
Martin Clarke
Martin Clarke
bigdawg7299
Are you an Audiopipe Car Audio and Video Expert? Answer questions, earn points and help others
