Question about Volfenhag 1600 WATT CHROME AMP AMPLIFIER 2 CHANNEL Car Audio Amplifier
Hooking it up
Im new to car audio and just recently purchased a volfenhag amp and notice my wire clamps "the metal piece that connects the wire to the amp" are too big for this amp beacuse the connection is circular and small, too small for the clamps. i tried to bare wire it and it didnt turn on. pleeeeeeeaaassseee help me!!!! thanks for your time and knowledge
  • Volfenhag Master
  • 17,130 Answers
Not to worry, if you visit any electrical shops you will get the right size of the EYE TAGS that will fit your amplifier connection. You can carry you amplifier along to check this out. I am sure with patience identify and connect, check the connection leads carefully and your amp will power on. OK. Good day
Posted on Jul 13, 2010
How ot hook up speakers on this amp/
As far as I know, your sound will drastically improve if you run them +- and +-. Connect the one speaker correctly (+-) and then with the music still playing, try swapping the wires on the other speaker around and see which sounds better + to + or + to -
Hope this helps
May 20, 2010 | Volfenhag ZX-8300 Car Audio Amplifier
Zx-8100 amplifier is red lighting.
try wiring them differently. here is a link for u to go to http://www.crutchfield.com/learn/learningcenter/car/subwoofers_wiring.html . once there find your amp configuration (ie. mono, or 2 channel) then down to the type of subs an how many subs ( ie. 2 dvc (dual voice coil) 4 ohm subs) an that will show u how the subs should be wired and wired to the amp.
Mar 21, 2010 | Volfenhag ZX-8100 Car Audio Amplifier
If you have an amp thats mono block with 1 channel but two positives and two negatives what is the best way to hook it up for two 12in.
The fact that there are 2 output terminal sets are simply for convenience. You need to know your amps ratings, but it is probably rated to handle 2 ohms. In this case, (assuming your 2 speakers are single coil 4 oh,s each) just connect them one speaker per set of jacks. (the output terminals are electrically connected inside of the amp, and are the same piece of metal (both the positives are the same, and so are the negatives).
By connecting your 2 subs in this manner, your amp will be pushing 2 ohms with the power equally divided between the two woofers.
This is the best way to hook up, and will get the most power from your amp.
Jun 12, 2009 | Volfenhag ZX-4712 Car Subwoofer
Volfenhag ZX-7160 Car Audio Amplifier owners manual to adjust the frequency also wiring diagram diamartn64@gmail.com
its very easy to hook it up. your best bet is to join www.carstereo and ask your question there.but it is easy to set and hook up amp if you really need help email me
Mar 03, 2009 | Volfenhag ZX-7160 Car Audio Amplifier
Not working
maybe you should use 4 awg wire
Jun 24, 2008 | Rockford Fosgate Punch P5002 Car Audio...
Volfenhag ZX8300 on with radio, off with cd or mp3 player
You're using the wrong control wire. You're likely using a wire marked antenna control. You need to use the one marked amp control. They are both blue.
May 22, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
How to mount amp
Turn your amp over and you'll see 4 holes one in each corner and you should gotten 4 v shapped pieces of metal with 2 holes each and 4 screws.....you normally have to mount them on manually. I hope that helps.
Mar 17, 2008 | Volfenhag ZX-8300 Car Audio Amplifier
Hooking up DVC subs
The amp is rated to run a 2 ohm load on each channel. To do this, connect the voice coils of one sub in parallel (tie both "+" on the sub to each other and both "-" on the sub to each other), then connect that sub to one channel of the amp. Repeat this process for the other sub and connect it to the other channel on the amp. The subs will be in stereo and the amp will be outputting it's maximum power.
Mar 09, 2008 | Legacy 2CH 1000W AMP Car Audio Amplifier
Amp protection light
is the amp well grounded run a wire from amp hosing to metal of car hope it work cheers
Jan 15, 2008 | Volfenhag ZX-7180 Car Audio Amplifier
Volfenhag 1600 WATT CHROME AMP AMPLIFIER 2 CHANNEL Car Audio Amplifier Logo
56 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
hoyzee1
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
