Question about Toys
Looking for a replacement motor driver circuit board for the dorel pink corvette motorized car
3 Suggested Answers
Ironfist109
  • 3018 Answers
SOURCE: 12 volt replacement battery Dorel
I'd like to bring your attention to a CPSP (U.S. Consumer Product Safety Commission) recall on the battery for this item. http://www.cpsc.gov/cpscpub/prerel/prhtml06/06018.html So it looks like the battery is on the company itself this time. But just in case here is the link for the new battery itself http://www.safety1st.com/usa/eng/Products/Play-Relax/Toys/Details/2699-50800-Ride-On-Battery
  • Hazard: An electronic malfunction can occur in the ride-on vehicle's circuit board and/or battery connector, resulting in smoking and melting of components. This poses a vehicle fire hazard and a burn hazard to consumers if components are touched while malfunctioning.
  • Remedy: Consumers should take the recalled ride-on vehicles away from children immediately and contact the company for a free repair.
  • Consumer Contact: For additional information, contact Dorel Juvenile Group's Ride-On hotline toll-free at (866) 611-3022 between 8 a.m. and 4:30 p.m. ET Monday through Friday, or visit http://www.djgusa.com/usa/eng/
Regards, Tony
Posted on Apr 21, 2011
SOURCE: Where can I find a
Hello Arey,
http://www.kidtraxtoys.com/skin/frontend/kidtrax/default/pdf/Chevrolet_Corvette_English.pdf
http://www.kidtraxtoys.com/spare-parts
Posted on Apr 22, 2011
1990 corvette passenger window just stopped working
is the window switch in the locked position. Might not have on this vehicle.
remove the door panel.
might need to take off any handles that would get in the way.
find the motor and remove the connector.
check for any corrosion or discolored pins.
try the switch with a voltmeter connected between the pins.
should read battery voltage.
if not problem is in wiring.
fuses are the easiest to check.
next try putting connector back on motor to test wire.
hold switch on and very slowly open and close door.
if this makes the window move even a fraction of an inch replace wire.
if nothing happens take the motor out and have it tested.
replace motor if bad.
The window switches have a circuit board that can go bad also.
look for charred or cracked board and at connections to wire harness.
Feb 15, 2013 | 1990 Chevrolet Corvette
2002 corvette windows worked this AM, not this afternoon. i'm looking at the owners manual on line section 6-71 and 6-72 but don't see the circuit breaker for the windows. i tried mini fuse #33...
IF CIRCUIT BREAKERS AND MINI FUSES OK, MOST LIKELY THE MASTER SWITCH FAULTY. OR ONE OF THE BUTTONS IS STUCK, VERY RARE FOR BOTH WINDOW MOTORS TO FAIL AT SAME TIME, ALSO I THINK WINDOWS ALSO HAVE A MODULE EITHER IN THE DRIVERS DOOR PANEL OR UNDER DASH, THAT WOULD ALSO CAUSE PROBLEM.
Aug 27, 2011 | 2002 Chevrolet Corvette
Windshield wipers will not turn off until the fuse is taken out
I've diagnosed and repaired this problem twice on C5's. Both times I had to replace the wiper module (it's the printed circuit board mounted on the wiper motor).
Sep 18, 2010 | 1998 Chevrolet Corvette
My winshield wipers will not shut off on a 2002 corvette , any thoughts?
I had the same thing on my Vett, it turn out to be the wiper motor, the circuit broad was bad in the wiper motor it self, replace it.
Jul 19, 2010 | 2002 Chevrolet Corvette
My 2001 chevy corvette windshield wipers come on randomly, when the switch is in the off position while driving?? sometimes they stop, then come back on. thank you for any help in advance!
There was a recall a few years back for this issue to most of the GM cars. The circuit board in the wiper motor would crack and cause an internal short which can cause your wipers to work randomly and at other times will not work at all. Simple test is to lightly tap the wire harness at the wiper motor unit and see if there is any abnormalities in the function of the wipes.
If there is no issues, then it may be the wiper switch it self that may be faulty. But in most cases it's going to be the circuit board that will need to be replaced or re-soldered as to what GM has done to solve the problem.
Thank you for using fixya and be safe.
Jun 19, 2010 | 2001 Chevrolet Corvette
Driver headlight not getting power to headlight motor 88 corvette
check wire going to motor for proper voltage or open circuit
Oct 03, 2009 | 1988 Chevrolet Corvette
Wipers wont shut off
Check to make sure you are getting power to the wiper motors. Also check relay. Either one could be bad.
Jul 13, 2009 | 1998 Chevrolet Corvette
I have replaced wiper motor 4 times last three years, wipers come on by them self run minute or 2 shut off, and it seems to start after I use touchless car wash. After I replace motor wipers work fine for...
This is really an easy fix. The wiper motor assembly is on the firewall, just right of center. The wiring can be unplugged before the circuit board is removed, or afterward. I found it easier to unplug it after the circuit board was removed. There is a flat cover that is held on with three torx screws (T20). Remove those screws and remove the cover.
The circuit board will now be visible. Remove the circuit board by grasping the wiring connecter and gently pulling it towards the front of the vehicle. When the circuit board has fallen free, unplug it from the wiring harness if you haven't already done so.
The solder joints that connect the wiring socket to the board go bad on the board.  Just resoldered those and re-installed the circuit board.
Good luck and hope this helps. keep me posted, be glad to help.
Jun 15, 2009 | 1999 Chevrolet Corvette
My wipers just stoped working in my 2002 corvette. i checked the fuse and its fine. The washer fliud pumps and sprays but wipers dont move and make no noise...? Any help
Sounds like the wiper motor is shot. You can check for electric voltage at the motor using a meter to make sure it is getting power first.
May 04, 2009 | 2002 Chevrolet Corvette
The windshield wipers aren't working. Ground wire is good.
If you turn them and open hood and can hear the wiper motor running then something is stripped in the gearing, not very common. Otherwise check for power getting motor by unplugging motor and use test light.
Aug 03, 2008 | 1995 Chevrolet Corvette
Toys Logo
166 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
