Question about LG ANWF100 Wireless dongle
Wireless TV failed to connect to my gateway. WHy is it? DHCP to be part of gateway - what does this means?
    Problem Solver:
  • 5 Answers
Try same gateway ip & DNS-server ip
Posted on Aug 20, 2010
  • Vpuri Oct 10, 2010
    It am facing the same problem... it does not seem to work. I am on virgin broadband and it fails to connect to the wireless gateway.
  • Carls_Wilson Feb 04, 2011
    I also have the same problem, won't connect to gateway, have tried removing password from router and no luck... Tv repairMan is here now
Major wireless problems.. I can connect to my wireless router (Thomson 585v8) but i cant connect to the internet. When it connects it says local only. How do i fix it so i can go on the internet..??
check if the ip address that you are getting begins with 192.169.x.x ( x = any number between 1 to 254) check that your router the DHCP service is enable and that there a network range set (example lets say your gateway ip is 192.158.0.1 then your dhcp by defult in most cases will look like this ip range 192.168.0.2 - 192.168.0.254 using a netmask of 255.255.255.0 that will give you 254 ips per network.)
if your ip start with 192.169.x.x the that means that your machine is not getting a real ip assigned to it all you get is an APIPA that is just a reseved ip by the system to fill out ethernet interfaces that don't have and static ip or are in a network without a DHCP server.
you can set a static ip in the client pc if you don't want to enable DHCP in the router.
when you see Local Only message it means that your pc hasn't detected a route to the outside network ( internet ) without a proper gateway you will not be able to get to the internet, your router ip is always your gateway.
example:
Router Client pc
IP 192,168.0.1 IP 192.168.0.2
subnet mask 255.255.255.0 subnet mask 255.255.255.0
default gateway 192.168.0.1
Mar 03, 2011 | Computers & Internet
Need to set up wireless router
you have two ways:-
  1. DHCP (Dynamic Host Control Protocol)
  2. Manual entry of settings in wireless adapter properties.
1.DHCP:-
In DHCP method you dont have to enter any settings on the wireless adapter. The wireless network which you are connecting will automatically assign an IP Address to you. But to use DHCP it must be supported by your wireless network.
This method is mostly used over wireless Connection in small networks connecting 2-200 computers. In this method you have to obtain the following information from your connection provider.
  • IP address (Its format is "xxx.xxx.xxx.xxx")
  • Default gateway address (very important)
  • Primary and secondary DNS (If not given then you can use "8.8.8.8" as primary DNS and "8.8.4.4" as Secondary DNS...thats free DNS service from google and its very fast)
  • Subnet Mask (not needed mostly...automatically generated)
Sep 25, 2010 | NetGear WNR2000 Wireless Router
Connection issues
To troubleshoot the issue follow the below steps
1.Try disbaling and enabling the wireless lan card
2.Check whether Ip addresses assigned in the wireless network card.If the address is assigned by dhcp and not assigned in network card means assign static ip in the range supported in the networkand ping the website or gateway.
3.If the ip is assigned already means try pinging the gateway and dns server .If ping is success means the connection between router and pc and internet is good .In that case you have to check whether authentication is successful if any authentication is used.
May 10, 2010 | D-Link DIR-625 (790069292637) Wireless...
I cannot get my laptop to connect to the internet either wirelessly or hard-wired. I have two other laptops, connected wirelessly, and a desktop connected via hardwire. It recognizes the router but says...
if you are trying through wireless, first unplug the wire from the laptop,
make sure that the wireless switch on your laptop is turned on.
click on start, control panel, network connections/network & internet/ Network and sharing center..
right click on wireless network connection Icon, if it says disable, it means it is enabled already.
then click on status..
from here the steps would differ from OS to OS
then click on Support tab (for XP)
check the address type, it should be "Assigned by DHCP"
and if you see the IP Address starts with 169., it is a bad IP and needs to disable the connection and enable it.
if the connection type is "Assigned Manually, right click on wireless network connection icon and click on properties and click Internet Protocol(TCP/IP) and click on properties, in this window, check the option "Obtain IP Address Automatically from DHCP"
click ok and OK ..
again right click on the wireless network connection icon and click on view available networks... click on your router name and click on connect..
now check the functionality.
if you are using windows 7 or vista,
click on status, click on details for the IP Address..
We see DHCP Enabled as YES or NO instead of "Adress type"in XP
if it says no, it means it is assigned manually. to change to DHCP , right click on Wireless Icon, select properties, click on IPV4 IP address and click properties, then select obtain automatic..
then try again..
hope this works,
Narendra Tirunahari
Feb 18, 2010 | Gateway 7330GZ Notebook
Unable to print wirelessly when using Uverse
you can connect your printer directly to the gateway of uverse: or the router of lthe uverse service
Jul 09, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Unable to connect wireless network to Blu-Ray player
TRY TO OPEN THESE PORTS VIA FIREWALL OF UR WINDOWS ALSO FOR UR ROUTER
Jun 08, 2009 | Computers & Internet
IP ADRESS FAILED ON XBOX 360. TRIED 2 DIFFERENT ROUTERS SAME ERROR
xbox configures the connection automatically as long as it is able to detect an internet connection(either wired or wireless). For wirless connections though, make sure xbox is using the correct security key or wep key for the wireless connection.
Mar 22, 2009 | Linksys Wireless-G WRT54G Router
Connecting 2wire modem./router to extra linksys router
to get this right you must make sure that the 2wire will be configured to be your gateway which means that the 2wire itself will be connected to the internet then set the linksys to DHCP mode because if you dont it will give you a router behind router error , make sure that the 2wire is properly authenticated and connected to the internet to make sure access the gui by typing gateway.2wire.net on your browser and run system set up wizard
Dec 11, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
2wire 1800hg random no internet/random access, repair/wait fixes
It seems that you said your computer gets the ip address from your router,, which means thru DHCP of the router but if you look at the DHCP settings of your wireless card inside your computer ---the DHCP is OFF -- check your ipconfig/all command as shown in your problem too,,, your wless card does not accept the new IP which comes from your router --as DHCP is OFF on your wless card and sticks with the old ip address whereas the router maintains a new ip for your computer in its table and a mismatch occurs and you loose the internet connection ,,,,thats why repair works and then again the IP changes in the router for your computer and your computer's wless card lags behind and use the old ip adress ..... DHCP--- IS DYNAMIC , WHICH MEANS IT RENEWS THE IP address after some time and you computer gets stuck to the old one ,,, hence mismatch. "you make the DHCP -ON on your wless card too. it will be fine."
Mar 06, 2008 | 2wire 1800HG Router (RG1800HG00)
PS3 can't obtain IP address through LAN switch
wonderful! that's always a good thing to hear - sometimes it is the "make sure you're power cord is plugged in" problem, eh :)
Jan 31, 2008 | Sony Playstation 3 (PS3) Console
LG ANWF100 Wireless dongle Logo
3,202 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
