Question about Vatical Entertainment SeaDoo HydroCross 2001 for PlayStation 1
I have a 1997 Seadoo SP that won't keep running. Wil start using starting fluid but will not keep running. Any help?
  • 6,826 Answers
Specifications SP Type Two stroke, twin cylinder Bombardier Rotax Displacement 718 cc Bore x Stroke 82mm x 68mm Compression ratio 6.5:1 Carburetion (1) Mikuni BN 38-34 Lubrication Variable Rate Oil Injection Propulsion System Bombardier Formula water jet pump Dry Weight 387 lbs/174 kg Fuel Capacity (inc. reserve) 9 US gal/34L Rider capacity 1 or 2 Length 100"/254cm Width 41.5"/105cm Height 36"/92cm
I see it has a Mikuni carburetor in it. If it won't start without starting fluid, I always check the fuel supply to the motor.
Probably if it has been sitting around for awhile it is in need of rebuilding and cleaning to get the engine running again.
Posted on Jul 12, 2010
Starts starting fluid only
Take carb. off clean the bowel and jets. If the carb has a plug in the bottom with 4 holes in it then this is your main jet. Take a needle or syringe and make sure its clean and unobstructed by trash. Use starter fluid to clean every part.
May 20, 2013 | Tecumseh Garden
1992 Toyota celica starts and dies
Could be a sensor. Have it scanned would be my suggestion.
Aug 15, 2012 | 1992 Toyota Celica
My car won't start. The battery is good and the starter is doing it's job. The fuel filter has been replaced. The car will start with starter fluid and run when revved but won't start o
check fuel pump fuse and relay also the fuel injection fuse and ecu fuse, if they are ok remove the back seat and you will see a cover remove the cover and check for voltage at the pump plug and ground, you hear the pump work if not need new pump
Apr 07, 2012 | 1997 Toyota Corolla
1997 mazda 626 won't start.
Are the plugs wet with fuel?
Check for spark. No spark? it may be the ignition module.
Plugs dry and spark present? No fuel?Spray a little starting fluid and see if it will run on that.
Then check pump fuses and for fuel pump noise.
Jun 01, 2017 | 1997 Mazda 626
Why wont car shift into gear
Hello and welcome to FixYa!
You may want to start adjusting the brake pedals. If it detects that you are not stepping on the brake then it won't shift into gear.
If the gear is moving but won't shift gears while running then you may want to start on replacing the transmission fluid. It can be burnt that's why it's not operating properly.
Hope this helps and thank you for using FixYa! Have a good one!
Aug 14, 2011 | 1997 Ford Escort
Replaced ctm unit and truck won`t stay running.
there are 2 sensor on the carb . you may need to replace both to find out whiche one it is . try this also give it gas while starting and when it starts you will have to keep your foot on the gas a little to keep it running if it runs that way its one of the 2 senors .
Jan 20, 2009 | 1997 Dodge Dakota
1997 chev s 10
the intial issue would be that the fuel is not being injected into the cylinders on start up. check injectors and fuel pump for defects
Oct 23, 2008 | 1997 GMC Safari
Vatical Entertainment SeaDoo HydroCross 2001 for PlayStation 1 Logo
170 people viewed this question
Top Vatical Entertainment Video Game Consoles & Games Experts
James Wishart
Are you a Vatical Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
