Question about Timex 20011 Wrist Watch
Cost of Timex wrist watches.
What is the cost of : a Timex (X005) gents wrist watch and a Timex (CW02) ladies wrist watch in Kolkata, West Bengal, India ?
rellik227
  • 27 Answers
SOURCE: My Timex Expedition wrist watch losing time.
old battery perhaps?
Posted on Feb 06, 2009
escapement
  • 2338 Answers
SOURCE: Link removal on ladies indiglo timex
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Aug 10, 2009
cmcduncand
  • 714 Answers
SOURCE: I have a Timex indiglo wr 30m wrist watch and I can't set the day
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 10, 2010
  • 906 Answers
SOURCE: timex electric and dynabeat wrist watches
Good day Sir, If you own a Timex and it seems to be running a little slower than usual, visit the link below for their manufacturer watch battery replacement services.
replacement batteries
Posted on Jul 28, 2010
  • 125 Answers
SOURCE: The light in my watch stopped working. How do I
Most watches of this type have 2 batteries - 1 for the light and 1 for timekeeping. If you use the light a lot, you may have flattened the battery but the watch keeps going because it's running on the other battery. Take it to your local jewellers/watchmakers/watch repair shop and get them to test the battery and replace if flat. If the battery isn't flat and the light doesn't work then you have a faulty watch - if it's still under guarantee fine, if not buy yourself another watch if you can't put up with the fault.
Posted on Jul 29, 2010
Manual for a Timex T5K360 Ladies Marathon Watch
Google (timex)(T5K360)(manual) without parens.
May 26, 2018 | Timex Watches
I am looking for a white leather strap for my Timex ladies watch
Found a site where you can get a new timex ladies watch with white leather strap for $25...i think thats a great price. check it out.
http://www.amazon.com/Timex-Womens-T2H391-Reader-Nurses/dp/B000ROGWI8
Mar 01, 2011 | Watches
I have bought citizen watch JR3080-51L , and I need some more links because I got a watch that is good for 7" wrist and I need 8.5" wrist. Thanks
I've had to get extra links before, especially for ladies SS and gold bands. Sometimes a local dealer will have spares that will fit your watch. But, the best source I've found is Ebay. Let me know if you have the stock band or something else. I'll try to help you locate some extra links, or another replacement band at a modest cost. Thanks, Bill
Sep 06, 2010 | Citizen Eco-Drive JR3080-51L Wrist Watch
Need a new Rubber Wrist Band for my Timex 66801 Ironman Watch
Hi, Most Timex bands for this series can be found at this site:
http://www.watchbands.com/Category.aspx,,CategoryID,,4
They will cost you between 8 and 15 dollars.
If you need further help, call Timex in Little Rock, Arkansas, phone 1-800-448-4639.
I hope this helps you. Thanks, Bill
Sep 01, 2010 | Timex Sports Ironman Triathlon 100-Lap...
I have an older timex mens wrist watch and I would like to know where I can look to find the model number on it. It is a wind not battery powered. Thank you for your help.
mcdevito75 here, I just took a peak into my own Older Timex watch, even though it"s a ladies the model number was on the movement itself and only a 3 digit number. Since the older Timex watches were mass produced this is all you may have as far as serial numbers go, and Timex did all their own watches so a serial number may only be 3--4--5 digits long. Anyway, double check the entire watch with a magnifier glass for the serial number, then check inside the back cover and movement itself. Here is Timex contact info, 800-448-4639 if needed.
Aug 11, 2010 | Timex Watches
How to remove links from times watch band model #tx1282
mcdevito75 here, You"d need a special tool available on ebay called a link remover tool. But for fastest remedy and just about the same cost as buying and shipping the special tool, unless your going to do a few watches, your best bet is to look for a small watch repair shop in your area to remove these links, hold onto them just in case you need them later.
Jul 31, 2010 | Timex Casual Expansion Band 20061 Wrist...
I have a bulova 98m36 ladies watch and I need to know what size battery it takes
I advise you to take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving.
This is particularly true if you watch is sealed as replacing the back can be difficult.
Feb 18, 2010 | Bulova 98M36 Wrist Watch
I want to buy a Timex gents chronograph wristwatch immediately with alarm & indiglo.Please tell me various models available in this category so that I can choose one
Timex has a great selection of watches that fit your needs. Timex is Indiglo so all their watches have it. When it comes to chronograph your also looking at a large number of watches. Here is their website to help you narrow it down to more specifics.
http://www.timex.com/gp/node/n/238494011/190-6525554-2651024?ie=UTF8&timexBrand=core
Sep 19, 2009 | Timex Watches
I have a Timex Ironman 53151 watch but there is no sound. The light and everything else works except the sound. What is wrong with it?
got a new battery in ironman and the beep will not sound when i press the start and end button on while in stopwatch mode
Apr 19, 2008 | Timex Ironman 53151 Wrist Watch
Timex 20011 Wrist Watch Logo
Top Timex Watches Experts
Ross Keen
Jerry Greenberg
Jerry Greenberg
Dustin
Dustin
Are you a Timex Watch Expert? Answer questions, earn points and help others
