Question about HP Photosmart 2575 All-In-One InkJet Printer
Since an 'hp update a couple of months ago, IJT compatible cartridges HP344 are repeatedly rejected under the guise of "Printer cartridge problem - remove, check and replace colour cartridge" - all to no avail. I am wondering if, as the rejections started happening on the part used cartridge and also on a new one, HP may have injected a worm, or whatever you call it in the last update so that 'Compatible' colour cartridges are rejected. I should be grateful for any advice. please, because up until now the 'all in one' printer has served me well, and I am reluctant to bin it. With thanks, John Budden
    Scholar:
  • 103 Answers
Remove Hp update from add & remove programs.
Posted on Jul 12, 2010
I have an HP f 380 printer. it displayed the E and a message appeared on my computer screen saying the tri colour cartridge has a problem. i know it's not the cartridge, because i put it in anotherHP f...
Recognition of cartridges depends on several issues. Check and clean the metal contact points on the printer cartridge slot. Use rubbing alcohol on a q-tip and pat dry. Do the same on the ink cart. Any oil/film on the contacts can interfere with the communication network of the printer. Sometimes, printers just reject cartridges, mainly if you use off brand products. Naturally HP wants you to use their cartridges! Other than that, you must use HP Software updates for the computer and also, update each HP Printers FIRMWARE. Lots of folks forget that!
Jan 12, 2018 | HP DeskJet F380 All-In-One Printer
Tip
How to solve the print cartridge errors ?
After you install a print cartridge, the attention light begins toflash red. The printer will not print. One of the following messagesmay appear on the control panel:
* Color or Right Print Cartridge is not compatible
* Incorrect Print Cartridge(s)
* Print Cartridge Problem
* Incorrectly Installed Cartridge(s)
* Black or Color Cartridge(s) Failed
Cleaning the connection and reconnecting may solve the issue
Solution :
To solve the problems related to Cartridge Errors we can do the following 4 steps. Which could help us to get the issue resolved
Step 1: Remove, inspect, and reset the problem cartridge
Step 2: Clean the problem cartridge contacts
Step 3: Repeat repeating and cleaning steps
Step 4. CONTACT TO HP SUPPORT
Step : Remove, inspect, and reseat the problem cartridge and Clean the problem cartridge contacts..
a) Make sure the printer is on. Press the Power button if it is not lit.
b) Open the printer cover, then wait until the print cartridge carriage is idle and silent
c) Press down lightly on the end of the problem cartridge to release it.
d) Slide the cartridge out and inspect it:
* Check the Copper electrical contacts (the Copper Part which touch the Connector inside)
* Clean it with the pirit or wet cotton)
* Check the Nozzles - Clean it with the worm wet cotton
* Wait for 2 to 5 min befour you connect them back
* Clean the contacts in the carriage, inside the product (Printer)
* Reinstall the cartridge.
* Reconnect the product to the electrical outlet.
* Close the product cover.
NOTE : you can also check the print cartridge label and make sure it iscompatible with your printer. Compatible print cartridges are listed inthe Printer Reference Guide supplied with your printer.
Note : If the cartridge is compatible, reinstall it in the printer:
* Cartridges marked with a triangle go into the left carriage slot.
* Cartridges marked with a square or pentagon go into the right carriage slot.
If issue not resolves Repeat repeating and cleaning steps
final Step : CONTACT TO HP SUPPORT
on Jan 04, 2010 | Office Equipment & Supplies
Bypass expired message cartridge. Cartridge is less than six months old & nearly full.
Every cartridge will have its own ID and Expiry date, please check the Cartridge expiry date, if its really expired then printer will reject it even-though the cartridge is full.
We cannot bypass cartridge errors for single cartridge in INK-JET printer, because they work in TIJ technology (Thermal Ink Jet) which needs all cartridges to be functional unlike Laser-jet printers.
Regards
Riztech
Jan 13, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
New Cartridges - not all color ink printing!
It sounds that the ink inside the cartridge has partly dried up.
This can happen to my printer when I don't use it for a couple of months too.
Hope this helps!
Feb 04, 2010 | HP PhotoSmart C4180 All-in-One Color...
I bought an HP C6180 all in one wireless printer 18 months ago while I was living in the US. It uses HP 02 cartridges which can not be sourced in the UK.There is a simalar 363 cartridge HP 363 but it is...
Oh yes HP can regionalize the printer for you. You need to call the UK HP and speak to their tech people. There is a specific reset that can be done and once it's complete you are able to use the 363 cartridges.
0844 369 0369 is there number and they do not charge for support for regionalization calls even if printer is out of warranty.
Jan 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
I recenlty had the ink cartridge #57 and #58 refilled at my local walgrens and when i went to insert the refilled cartridges the printer screens reads: remove and check cartridges.....what do you think...
Check the Connection and Clean them
Jan 04, 2010 | HP PSC 2210 All-In-One InkJet Printer
Replaced ink cartridge but keeps saying replace
Solution :
To solve the problems related to Cartridge Errors we can do thefollowing 4 steps. Which could help us to get the issue resolved
Jan 04, 2010 | HP Business InkJet 2800 Printer
Cartidge error
Problem : An error occurred while communicating with scanning device
After you install a print cartridge, the attention light begins to flash red. The printer will not print. One of the following messages may appear on the control panel:
Solution :
Step 1: Remove, inspect, and reseat the problem cartridge
Step 3: Repeat reseating and cleaning steps
Step 1: Remove, inspect, and reseat the problem cartridge and Clean the problem cartridge contacts..
NOTE : you can also check the print cartridge label and make sure it is compatible with your printer. Compatible print cartridges are listed in the Printer Reference Guide supplied with your printer.
final Step 4) CONTACT TO HP SUPPORT
Jan 04, 2010 | HP Officejet 5610 All-In-One InkJet...
Missing yellow when printing/even after many cleaning attempts!
new ink cartridge is much advisable. but for expriment basis i will tell you to place the ink cartridge in the bowl of water only the head from where the ink comes out in the water for nearly 24 hours.then remove the cartridge and clean it completely.then check. hope this helps............
thanks.
Nov 08, 2008 | HP Photosmart 4180 All-in-One Printer
Cartridge 57 failed
Brenda Walker on August 18, 2009
I think I may have solved this problem. What I did was take out the #56 cartridge and hit the print button. It started to calibrate and then said it was printing on reserve or something? Yup, it printed with only one (#57 cartridge). After that, I stuck in a new #56 cartridge and so far so good for it only happened yesterday.
I hope this solves your cartridge #57 failed problem. Let me know if it does.
Aloha from Hawaii
May 01, 2008 | HP PhotoSmart 7660 InkJet Printer
HP Photosmart 2575 All-In-One InkJet Printer Logo
79 people viewed this question
Ben Johnson
