Question about Sewing Machines
What type of grease do I need?
Just recently bought a used Husqvarna hedge trimmer E Tech II 326 HS 99 X series. What type of grease is recomended for these. Thanks
  • Sewing Machines Master
  • 1,388 Answers
You have somehow posted a hedge trimmer question amongst a sewing machine forum, so I would suggest a re-post in a different forum to maximise responses !
Posted on Apr 25, 2008
Cant lift the presure bar handle on viking 5000 series modle 5540
You will need to have it serviced by a Viking Service Tech. You can find a dealer near you by using the link 'Locate a Dealer' at the Husqvarna Viking Website - http://www.husqvarnaviking.com/us
Jun 27, 2014 | Husqvarna Sewing Machines
Model 2060
Sounds like some type of power surge and now either the control board or motor has gone bad. You will need to have it serviced by a Viking Service Tech. You can find a dealer near you by using the link 'Locate a Dealer' at the Husqvarna Viking Website - http://www.husqvarnaviking.com/us
Jun 13, 2014 | Husqvarna Sewing Machines
4D d-Card Reader/Writer Kit and Husqvarna Quilt Designer II
Assume you are loading your designs using Organizer? Yes? I have very limited experience of this, preferring to use Disk Manager (but you need to have this program which I am guessing you don't).
It is my understanding that Organizer will only load one design to an embroidery media, not a whole menu of various designs. However you obviously are not "seeing" even one design. Did a pre-loaded Husqvarna card come with your machine? I think it should have, but if it didn't then that doesn't help you very much either.
I am wondering if the D-card is not "formatted" for embroidery recognition. The Designer machines like to receive their designs in a certain file arrangement but I'm afraid I can't offer you advice on how to format the card - I do my formatting through Disk Manager.
However, while I was writing the above it did occur to me - are you loading designs that are the .shv format? Your machine will not recognize .hus, .vip, .vp3 or any other format. Please write back to this group and let me know if any of the above was useful to you. I belong to a Yahoo group that deals exclusively with Designer machines, so I will ask the group members if they can come up with any helpful advice.
Jul 01, 2010 | Husqvarna Designer I
Viking 6440, sticks in reverse. Hair dryer on high temp. fixes it until it cools off. How can I clean the old grease out and add new grease, myself? Repair is 425.00 at the shop.
You need to purchase a de-greaser spray to clean out the old grease. Im sorry but Im not an expert at this type of machine, but most of the inner workings are similar to all brands. You need to remove the top to expose the crankshaft device that is inside, and spray with a de-greaser. If you know the area where it sticks try that area first. A common de greaser is actually WD40. It lubricates and de greases, you could try this, if available in your area. You may have to use a lithium based grease for that machine I cannot say for certain. I do however have a link to the Husqvarna help site if that will help.. http://www.husqvarnaviking.com/us/2821_3079.htm
Mar 16, 2010 | Husqvarna Viking 1
The needle in my Viking 6440 is locked in on the left side and the machine will only sew in reverse. The reverse button cannot be moved in or out.
I'm trying to find a machine similar to yours and have done much research re: the older mech viking sewing machines 6000 series. They are GREAT machines, suffering only from problems such as yours caused by the old "lube/grease" they used when it was made @ factory. In their efforts of making a "never needs oil" mech sewing machine, the grease tends to harden & freeze up the gears & cams inside the machine. You need to have it serviced @ authorized Viking shop as you have to completely disassemble the machines & gears, clean, re-lube, & re calibrate the gears... I understand this s/b ~ $175. Money well spent considering if taken care of your beauty could be sewing for another 60 yrs!
Hope this helps!
Jan 22, 2010 | Husqvarna Viking 1
Machine sewing backwards only
If you machine was recently serviced, the service tech might have reversed the motor connections. If not, it could be the zero feeding mechanism is stuck. Try dropping your feeddogs, i.e. like sewing on a button. Then raise your feeddogs to see if the problem clears. What happens when you sew a buttonhole using the automated buttonhole accessory? If these do not work, it may be your pc board which has a 5 year warranty if you are the original purchaser from an authorized Husqvarna Viking dealer. If resetting feeddogs does not clear the problem, Will probably need service by an authorized Husqvarna Viking dealer. If the service tech cannot repair, they can send to Husqvarna Viking Service Technician for repair. Visit the Husqvarna Viking website for a list of dealers closest to you. http://www.husqvarnaviking.com/us Good luck.
Sep 23, 2009 | Husqvarna Viking 1
Machine stopped running, its getting power but wont run.
I would take it back to your service tech or choose another. It may be something simple that needs replacement, like a new cord. (or . . .)
Also, before thinking of buying a new machine, I would get another opinion.
Feb 17, 2009 | Husqvarna Viking 1
Problem with 40 old Elna Zigzag , V/NV/21, Type: 21cF347986
Um, sounds like the machine has seized from old, dry oil and it is dragging down the motor. Avoid using the machine until the issue is resolved so the motor is not damaged.
Depends what kind of oil & grease your husband used, as it could have complicated matters. Also, if the machine has been neglected for a long time, combining heat in the clean-up/lube process is sometimes very helpful. (Can't tell you the machines I've picked up that have had motor oil and grease applied!!! The old gunk needs to be cleaned out and then the appropriate lube applied.) Most machines do not use grease unless it is white lithium grease--perhaps on cams. Oil needs to be fresh, good quality sewing machine oil. I prefer liquid Tri-Flow Synthetic Lube from the hardware store. Do NOT use WD-40, 3-in-1, cooking oil, motor oil, etc. on your machine!
Wheel on right side that controls the needle up and down is very tight...
Mar 23, 2017 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
