Question about Dometic 57915531 Air Conditioner
Neither the fan or the a/c will come on. relay
Neither the fan or the a/c will come on. relay clicks when i turn thermostat to cool. checked all three relays from the inside and they are getting 120 volts. checked motor start and it showed 0 ohms. there is another capacitor but it did not show signs of oil or being swollen like it is bad. any help is greatly appreciated
    Problem Solver:
  • 5 Answers
If the the power is going thru the relay then we have a 120 volts. I would be looking at the neutral and ground to make sure, I have those. Its very unlikely that the fan and compressor would not work unless you were missing the 120 volt or neutral and ground. the problem could be in the breaker box as well. check for a loose or burn't neutral.
Posted on Aug 04, 2010
2002 4 ton Bryant air conditioner shuts off, fan still runs but not cooling is problem in the controls in the attic or in the AC unit or both?
With a non heat pump it is a simple 24 volt AC control circuit. In the attic there is a relay that is actuated via the fan control wire directly from the thermostat. On the thermostat there is an auto/man switch that controls the fan. Manual the fan runs all the time. Auto fan turns on and off with the outside compressor.
If the system is not calling for cool and the fan continues to run the fan relay is sticking. common problem. Sometimes after running for several days the relay will stop sticking if not, replace relay.
If the system is calling for cool and the compressor stops I would still expect the fan to run until thermostat tells the A/C to off. Some compressor units include a safety switch or high-pressure cut-out switch A blocked internal valve bad control board or external fan in outside unit defective no air flow in outside unit.
High pressure cut out not good,
Suggest turning temp max cool and observe. If acceptable cool and the compressor runs without interruption all is good, except for the blower in the attic. Safely check relay in attic blower circuit.
Hope this helps.
Jun 28, 2017 | Bryant Heating & Cooling
01 chrysler pt cruiser where is the cooling fan relay
It can be issue with faulty motor or its faulty fan control relay.
Both are to be inspected.
Test volt at fan relay and fan motor.
For more help, I suggest you to go through the troubleshooting link mentioned below:-----
Click the link below: ------
Engine Cooling Fan not Working http://technoanswers.blogspot.com/2012/11/overheating-radiator-fan-not-working.html
These will help.Thanks.
Dec 04, 2012 | 2001 Chrysler PT Cruiser
Remove radiator cooling fan from renault scenic 2001
Things to check before replacing the fan motor.
Relay Power Supply and Ground Unit
  • These are the first two components worth checking if your cooling fan is not turning on when you switch the air conditioning on -- which it should every time. As explained by AA1 Caricon1.png, a good relay coil will typically read 40 to 80 Ohms, but if the resistance is high, even if the coils still works, the relay will not, and you will see a failure in the system. It may also fail when the electrical load on the circuit is too high for it to cope, which is referred to as a "cut-out." When the coil has no resistance, the relay will need to be replaced with a new one because it will never work.
Thermostat Unit
  • The thermostat unit can stop cooling fan relays from working properly, since the two appear in series in the circuit, which means the electrical current moves directly between them so that when one is faulty, the other can be affected. If your relays are not performing well, you have the option to bypass the thermostat using a length of continuous wire. But the thermostat's function will then be lost if you cut it out of the circuit -- so bear this in mind before making final changes. Also check the integrity of the thermostat housing, which is responsible for temperature regulation as well, according to Car Tech Auto-parts.
Oct 26, 2012 | Cars & Trucks
Cooling fan on a Landrover LR2 2008 won't turn on. thermostat has been replaced. what could be cooling fan problem?
Hi belindacavey,
I have seen a few problems with the cooling fan on Land Rovers. Usually the relay portion of the fan fails. For a while Land Rover had fans on back-order because so many where failing. I would recommend having the fan/relay checked. FYI the relay module and the fan are usually one assembly.
Jun 26, 2011 | Land Rover LR2 Cars & Trucks
I have a 1994 chevy cavalier 2.2L engine. the engine fan does not turn on causing the car to over heat. What makes the fan turn on, is it a thermostat or a fuse?
REPLACE THERMOSTAT BUT IT SOUND LIKE FAULTY COOLANT TEMPERATURE SENSOR.BUT CHECK COOLING FAN FUSE AND RELAY.IF ALL IS GOOD HOT WIRE COOLING FAN IF COOLING FAN WORKS.PROBLEM COULD BE FAULTY COOLANT TEMPERATURE SENSOR. DAMAGE FAN WIRING OR FAULTY PCM.IF COOLING FAN DONT RUN WHEN HOT WIRED.REPLACE FAN AND MOTOR.
Feb 20, 2011 | 1994 Chevrolet Cavalier
Honeywell Chronotherm iv fan keeps running even when heat and cool turned off. How do I turn it off?
Assuming you have the fan switch of your thermostat in AUTO, it sounds like a stuck Fan Relay. If the fan relay is stuck, your fan will continue to run as long as there is line voltage being fed to your unit. This relay could be an independent component or it could be an integral part of your control board. Have an experienced, qualified service technician check it out.
Mar 19, 2010 | Honeywell Programmable Thermostat Heater
What would cause my radiator fans not to run
A lot of different things fall into this senario.Low coolant level,air in the cooling system,and a stuck thermostat,or,a bad coolant sensor,or even a bad cooling fan relay,or the cooling fans are bad.Turn the defrost on or the ac,the cooling fans should come on if the fans,and the relay are ok,if so,replace the thermostat,and coolant sensor,and bleed the cooling system of air.
Feb 01, 2010 | 1994 Toyota Camry
2001 Impala Cooling Fan not coming on ever and car running hot. Temp sensor on manifold has been replaced with a brand new one.What to check next?
Locate and replace the fan relay, you can purchase a electrical component locator which is packaged on cd repair manual at ebay motors $20.00.
Sep 18, 2009 | 2001 Chevrolet Impala
How would I fix this CLICKING sound?
You have a bad fan relay. You need to get it changed. Is this fan board. If so the intire board has to be changed. Safe side get a service tech to check it out ask for free estimate up front. Russ
Jul 21, 2009 | Heating & Cooling
Cooling fans dont engage! 1998 oldsmobile silhouette!
Your Problem Can VERY WELL BE with the Temp Sensor, As It Is the First in This Electrucal Circut . it Waits for 210-230 Degree Engine temp and Gives that Sygnal to the ECM then ECM Grounds out the Cooling FAN RELAY To Turn ON the FANS and the Temp Sensor is Usualy THE #1 Culpret Closley in front of the RELAY.
There are 2 Sensors On this Vehicle The One You Replaced and One Located At Trans Side of
Engine Closer to Front of Vehicle At the Head ,Thereis a 2 wire Plug On it and This Sensor Goes to the ECT witch CONTROLS COOLING FAN RELAY. Hope this Helps and if you Need A Diagram For this It Must be Emailed as FixYa Does NOT Support Large Picture Files. My Email Add. Is MY
Screen Name Here on FixYa @aol.com
Jun 15, 2009 | 1998 Oldsmobile Silhouette
Dometic 57915531 Air Conditioner Logo
74 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
