Question about Fisher E522BLX Stainless Steel
The compressor is working on our Fisher Paykel E522B- the lower freezer can maintain -15degC but the upper refrigerator section doesn't fall below 7-8degC nomatter what setting on Smart control. Do I need to replace the smart thermostat control and if so, can you suggest source for parts and advise on repair method? Regards Greg Mann
    Guru:
  • 468 Answers
Hi Greg,
Before you replace Thermostat control, please try the below steps:
Things You'll Need:
Screwdriver
Volt-Ohm Multi-tester
Notebook
Pencil
Flashlight
Step 1 Check the easiest and most common potential causes first, which is the best course of action in any troubleshooting case. With a freezing refrigerator, this means checking the thermostat itself to see if it is set at the right temperature.
Sometimes, other family members may accidentally turn the dial, so just make sure that the dial is not turned to the coldest setting. If the setting is correct and you are still having your foods frozen, then you may have to troubleshoot the workings of the thermostat.
Step 2 Unplug your refrigerator. Next, locate the control panel where the thermostat is located and remove all of the items near it so you can work.
The thermostat is located directly behind the dial. You may need the flashlight to help you see inside the refrigerator.
Step 3 Remove the plastic cover that protects the controls. Some covers are screwed into place while others are held in place by plastic clips. Depending on your make and model refrigerator, you may have to first remove the dial before you can take the cover off.
Step 4 Turn the dial to the coldest setting. Remove the two leads (wires) on the thermostat.
Note: It helps to write down which lead goes where for when it's time to replace everything.
Step 5 Set the volt-ohm multimeter to RX1 and probe the terminals. By "probe," I mean touch one of the multimeter's probes to one terminal on the thermostat and the other probe to the other terminal.
You should be getting a reading of zero. If you get a zero reading, then move on to Step 6. If you do not get a zero reading, then remove the thermostat and take it to an appliance store for a replacement.
Step 6 Remove the thermostat from the refrigerator entirely. Set the dial on the thermostat to the warmest setting and place the thermostat in a working freezer for 30 minutes.
After the 30 minutes are up, reprobe the terminals and look for a reading of infinity. If you get the infinity reading, then the thermostat is fine. Simply reinstall it, plug the refrigerator back in and look for another cause of your freezing problem, like dirty coils.
If you do not get an infinity reading (sideways "eight"), you should replace the thermostat with a new one.
I also advise you to visit the below link:
http://www.ehow.com/how_2167621_troubleshoot-refrigerators-thermostat.html
Posted on Jul 12, 2010
  • gjmann Jul 12, 2010
    In your proposed solution to my problem, you have answered a question different from the one I asked. My refrigerator is not freezing in the refigerator area, but is in fact not getting cold enough in that area. Also the Fisher Paykel E522B has an electronic "Active Smart" control not the older style thermostat control to which your response relates.
    Please reconsider my question and your response.
    Greg Mann
What are the temperatures for fridge and freezer compartments on a fisher paykel E522B
Keep the refrigerator temperature at or below 40° F (4° C). The freezer temperature should be 0° F (-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Feb 21, 2015 | Fisher and Paykel Active Smart E522B...
E522B throws circuit after being on for short time. Compressor?
Possibly but more likley the defrost element in the freezer, not a job a handyman can do, get a qualified technician to do it, about a $50 part.
Nov 27, 2011 | Fisher and Paykel Active Smart E522B...
I have a Fisher & Paykel E522B fridge that has suddenly stopped cooling.....it appears that the compressor is still working but both the fridge and freezer are warm.....as we live in a remote area of...
Check fans in freezer and near compressor. Is compressor running continuously or clicking on and off? If fans are running and compressor is running continuously, your problem is most likely within sealed system. That would require a technician and may not be cost effective to repair.
Sep 23, 2017 | Fisher and Paykel Active Smart E522B...
Fridge compartment not cooling. Freezer seems OK. Fisher & Paykel - model E522B
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 07, 2011 | Fisher and Paykel Icon E522B Bottom...
Fault Code F24
fisher paykel fridge model e522b fridge section is freezing up
Mar 31, 2010 | Fisher and Paykel Active Smart E522B...
I have a Fisher and Paykel E522B Fridge and the
hello sir/mam
after replacing the tempreture probe have u checked the compressor so that it should get the signals for cutt in and cutt off if not please check it.if this is not happening please change the temperature sensor.
Sep 14, 2009 | Fisher and Paykel Active Smart E522B...
How do you manually start timer on fisher paykel
We disconnected the refrigerator and took the back of the freezer apart. There we noticed ice had built up on the coils. After removing all the food, we let the freezer defrost for 3.5 hours. Then we connected it, and it started to cool down immediately. After 1 1/2 to 2 hours, the refrigerator was down below 40 degrees. All food was replaced, and now the refrigerator is working properly All of this was down to the Fisher Paykel Model E522BRM.
Aug 31, 2009 | Fisher and Paykel Active Smart E522B...
Refrigerator
the compressor might have had it
Dec 16, 2007 | Fisher and Paykel Active Smart E522B...
Fisher E522BLX Stainless Steel Logo
20 people viewed this question
Top Fisher Refrigerators Experts
Charles T Nevin
Charles T Nevin
Joseph Hoffmann
John Tripp
John Tripp
Are you a Fisher Refrigerator Expert? Answer questions, earn points and help others
