Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
I also get 3 short beeps when I press the power button, and the only button that works is the Controls Lock/Unlock... The machine no longer can be powered up. The F70 an F71 error codes are stored up on the computer when i run the manual diagnostic. And I do not think there is a problem with the pump, I was cleaning the filter and i was able to freely spin the paddle inside. There was something stuck in the filter but I've cleaned that already.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F70 and F71 indicate no communication between the Central control unit and the user interface. To start with you’ll need to check continuity of the user interface harness and also check the wire harness connections. You can also try to rotate the drum, if the drum is rotating the User Interface should be replaced and if it wont move then the Central Control Unit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 12, 2010
How to get the childlock to unlock
Try holding the child lock button for 4 seconds (or until you hear the beep). This should toggle the lock on or off depending on the current setting.
I hope this helps. If this doesn't work, there is probably a problem with the control panel (keypad or the wiring).
(I've found that sometimes it feels like you have to hold the button for longer than the 4 seconds to toggle the lock off. So try holding the button for longer before trying to find a problem with the control panel.)
May 02, 2012 | Hotpoint Ultima WF860 Front Load Washer
The controls locked is displayed. what causes this and how do i get the controls unlocked.
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 11, 2011 | Whirlpool GEW9250 Electric Dryer
Push any button and 'loc' flashes seems to be locked out
Press Options and Select at the same time and hold for 10 seconds or until "LOC" is no longer displayed to unlock the controls. Press and hold the same buttons for 10 seconds until "LOC" is displayed alternately with the estimated cycle time to lock the controls. Unplug the machine for at least half an hour, if pressing the buttons does unlock the controls, to forcibly reset the machine control and eliminate the possibility of an electronic glitch.
Oct 31, 2010 | Frigidaire Affinity ATF7000E Front Load...
Control locked
If you want to enable the Controls Lock/Unlock Feature:-
To enable the Controls Lock feature when dryer is running: Press and hold the CONTROLS LOCK/UNLOCK button for 3 seconds. The control is locked when a single beep is heard and the Controls Lock status light is on. This feature allows you to lock your settings to avoid unintended use of the dryer. You can also use the Controls Lock feature to avoid unintended cycle or option changes during dryer operation.
■When the dryer is off, it is not necessary to press the Control On button before activating the Controls Lock feature.
For unlocking: Press and hold the CONTROLS LOCK/UNLOCK button for 3 seconds to turn this feature off.
NOTE:- When the dryer is running and Controls Lock is on, the dryer can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
Good Luck and have a nice day
Rating the solution is highly appreciated.
Jun 29, 2010 | Whirlpool GEW9250 Electric Dryer
Unlock the controls to start dishwasher
If the model number you listed this question under is correct, this model dishwasher has two locking features (both controlled by the same button).
There is a Control Lock which locks all the control buttons, so the dishwasher cannot be started. It is enabled by pressing and holding the lock button for about 3 seconds. To disable, press and hold the lock button until the light goes out. A single beep will be heard when the feature is turned on.
There is also a Keylock feature which locks the drawer shut and disables all the controls so the dishwasher cannot be opened or started. It is enabled by pressing and holding the lock button for about 5 seconds. To disable, press and hold the lock button until the lock light goes out. Two beeps will be heard when the feature is turned on.
Both these functions are safety features that enable the consumer to lock the dishwasher controls to prevent children from inadvertently starting the appliance.
These instructions are on page 12 of your owner's manual. If you no longer have a manual, you can obtain a FREE copy at managemylife.com. Just go to the site and type in your number under the "Manuals" link. These manuals are available in .pdf (Adobe) format that you can download or print for FREE.
If you have any questions, please post back and let me know. I hope this helps you.
Jun 27, 2010 | KitchenAid 23 in. KUDD01DPPA Stainless...
Saltware system from intex won't unlock
I'm not sure exactly what buttons you're pushing but you push the down button until it beeps, then the up button until it beeps. Then you set it. To lock it you push the down button until it beeps, then the up button until it beeps. Hope that helps and I apologize if those are the steps you're already taking.
May 27, 2010 | Intex Automatic Salt Water System for ...
My HE5t front loader not powering on
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 10, 2009 | Kenmore Washing Machines
Whirlpool Duet HT WFW9200SQ Ser CST50067K7 Power Problem
I have the same problem. Did you ever find the solution to this problem?
Dec 10, 2007 | Whirlpool GHW9200L Front Load Washer
Whirlpool Duet HT
Mine just did the exact same thing. I unplugged it, then plugged it back in, and it worked perfectly. Good luck!
Dec 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
215 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
