Olevia LT-30HV (LCD). The screen is black but there is sound.
I have an Olevia LT-30HV (LCD). The screen is black but there is sound. I have already done the following: Turned tv off for 1 hr....picture still black. Turned tv off for 1 day...picture still black. Plugged tv into a surge protector.....tv came on!!! Picture lasted for the day, about 6 hrs. The next day it didnt, picture was back to black. The following day it worked again for several hours...the next day and every day since than the screen has been black. I saw a posting about troubleshooting but since I have no electronic experience whatsoever I quickly became lost. Any ideas on what part I need to replace in layman's terms would be greatly appreciated! Thank you!
  • felinefan Jul 21, 2010
    Thank you for your response! I have narrowed down the problem to the backlight inverter. Do you know where I can purchase one and how to install it? I have a Olevia LT 30 HV. Thanks!
  • 505 Answers
What likely happened is when you did a "hard boot" you reset the microprocessor (computer) inside and then it worked. A "soft boot" by just turning it off and on will not do a full reset. The hard boot was when you completely unplugged AC power from the wall and that is the only way to hard boot a tv. (atleast any modern tv).
So yes, you have an issue with the digital circuitry or micro in the tv set.. this usually resides on a "main" board, or "digital main" board...
there is a possibility that you have other bad parts like bad capacitors (caps) that could be causing it to malfunction, but they usually will just screw up when cold, then work fine when it gets warm. semiconductors - transistors,diodes, MICROs will malfunction when they get hot, this is likely your issue. I would first open it up an look for anything that is bad, bulging caps are easy to find and could cause this issue, although not quite run of the mill. Here is my tutorial on bad caps:
http://www.fixya.com/support/r5000889-repairing_tv_just_clicks_over_over
if you don't find bad caps, suspect the digital main board
or main board -- on shopjimmy.com theyre calling it a system board or main board
http://www.shopjimmy.com/catalogsearch/result/index/q/LT30HV/
i would check the numbers on your board and see what matches up.
There is a rare posibility that it is something else, I would run it until it malfunctions and then try the hard boot again, see if it works for another 6 hours or whatever... if it works and then it goes right out, something is overheating, and still hot. You can use some "freeze spray" found at tech parts distributors online like www.jameco.com to troubleshoot and "freeze" the board that you suspect is overheating.. when you get it to work again for some time, ie it cooled down, then you've found your bad part. the overheating is something that should be normally functionable, but when the parts fail they cannot handle the extreme temps anymore. Anyways, let me know what I can do to help. We can fix this for sure, but if you don't want to dive in, might want to call in a pro. Let me know..
Posted on Jul 12, 2010
  • thielectronick
    thielectronick Jul 22, 2010
    i'd usually use shopjimmy but the part is out of stock:
    http://www.shopjimmy.com/backlight-inver...
    you can check your numbers to see if they match and get more reference part numbers
    hey found one on ebay, its listed as another brand but they use the same part
    http://cgi.ebay.com/Darfon-V144-001-LCD-...
    check it out, see if it matches, if so should be your best bet
    make sure if you are not positive, that you can return the part if needed, or you may be taking a gamble, best of luck!
Lcd tv troubleshooting
Check for power supply trouble. The green LED on the front panel should light if power is getting to your TV. The "no signal" indication may mean no antenna or cable input is detected
Aug 21, 2013 | Televison & Video
I get a flash of blue screen when I power on the set.
I have the same problem.
"I get a flash of blue screen when I turn on the LT 30HV. Then the screen goes blank."
Jan 10, 2010 | Syntax LT30HV 30 in. HD-Ready LCD...
My tv has sound but the screen is black. At times
Ur LCD inverter board is dead.Must replaced the board.Usally a long board.
Jan 05, 2010 | Olevia LT27HVX 27 in. LCD Television
Syntax Olevia flat screen tv video goes off then on
Hi, Replace the bulging capasitors on the main power supply board. Thanks.
Sep 22, 2009 | Insignia 37" LCD Flat-Panel HDTV
LT 30 HV Olevia Syntax No picture - blue flash
Ur video converter board is dead.
Need to be change.
Aug 15, 2009 | Insignia 37" LCD Flat-Panel HDTV
Faint or no picture on olevia / syntax tv model LT-37HVS
When you tune to a station and get sound I presume the screen is black so do the following.
Place a bright flashlight against the screen. Look for an image around the edge of the flashlight.
If you see an image the problem is probably one of three causes.
1) Power to the inverter board is bad.
2) Inverter board has failed.
3) The CCFT(cold cathode fluorescent light) are dead.
Someone knowledgeable in electronics can diagnosis it.
Mar 05, 2009 | Olevia LT37HVS 37 in. LCD HDTV
My Olevia LT37HVS 37' was working fine all day and turned to black screen.
It is either the fluorescent backlight source for the LCD panel or its associated power supply failing.
Nov 10, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Syntax Olevia 30" LCD - blue screen, then black screen, sound is on
you have a broken inverter board. I have a LT30HV, and it had the same problem. The inverter board supplies power to the backlight. Swap it out with a good one, and you're back in business.
To test, take a bright flashlight and point it at the screen just an inch or so off the surface. If you can see your picture, then you have a blown inverter.
it may not be worth fixing it. Wait for a good sale on a new one. My inverter cost about 150, and it was a remanufactured part. Not as good as the original part as it flickers just a tad. I had to take the entire TV apart, with pieces literally everywhere. My cats loved it.
Oct 21, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LT 37 HVS HDMI PORT
You need to take the unit to an authorized repair shop to have it
check and correct it , looks like the power supply section got affected by the sudden change of voltage and damaged an internal part, hope this helps , AJ
Jul 02, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 32" LCD HD TV model 232-S13
I have had the same problem with my daughters Olevia...232-S13 out of the blue ti just decides to not turn on...blue light lit where the on/off button located but no sound and no picture....i guess the saying "you get what you pay for" stands clear here.......very upsetting.....
Jan 12, 2008 | Olevia LT32HVE 32 in. LCD Television
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
